Static Public Attributes | List of all members
CC_TYPES Class Reference
CloudCompare object type flags. More...
#include <ccObject.h>
static const CC_CLASS_ENUM OBJECT = 0
static const CC_CLASS_ENUM HIERARCHY_OBJECT = CC_HIERARCH_BIT
static const CC_CLASS_ENUM POINT_CLOUD = HIERARCHY_OBJECT | CC_CLOUD_BIT
static const CC_CLASS_ENUM MESH = HIERARCHY_OBJECT | CC_MESH_BIT
static const CC_CLASS_ENUM SUB_MESH = HIERARCHY_OBJECT | CC_MESH_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM MESH_GROUP = MESH | CC_GROUP_BIT
static const CC_CLASS_ENUM FACET = HIERARCHY_OBJECT | CC_FACET_BIT
static const CC_CLASS_ENUM POINT_OCTREE = HIERARCHY_OBJECT | CC_OCTREE_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM POINT_KDTREE = HIERARCHY_OBJECT | CC_KDTREE_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM POLY_LINE = HIERARCHY_OBJECT | CC_POLYLINE_BIT
static const CC_CLASS_ENUM IMAGE = CC_HIERARCH_BIT | CC_IMAGE_BIT
static const CC_CLASS_ENUM CALIBRATED_IMAGE = IMAGE | CC_LEAF_BIT
static const CC_CLASS_ENUM SENSOR = CC_HIERARCH_BIT | CC_SENSOR_BIT
static const CC_CLASS_ENUM GBL_SENSOR = SENSOR | CC_GROUND_BASED_BIT
static const CC_CLASS_ENUM CAMERA_SENSOR = SENSOR | CC_CAMERA_BIT
static const CC_CLASS_ENUM PRIMITIVE = MESH | CC_PRIMITIVE_BIT
static const CC_CLASS_ENUM PLANE = PRIMITIVE | CC_PLANE_BIT
static const CC_CLASS_ENUM SPHERE = PRIMITIVE | CC_SPHERE_BIT
static const CC_CLASS_ENUM TORUS = PRIMITIVE | CC_TORUS_BIT
static const CC_CLASS_ENUM CYLINDER = PRIMITIVE | CC_CYLINDER_BIT
static const CC_CLASS_ENUM CONE = PRIMITIVE | CC_CONE_BIT
static const CC_CLASS_ENUM BOX = PRIMITIVE | CC_BOX_BIT
static const CC_CLASS_ENUM DISH = PRIMITIVE | CC_DISH_BIT
static const CC_CLASS_ENUM EXTRU = PRIMITIVE | CC_EXTRU_BIT
static const CC_CLASS_ENUM QUADRIC = PRIMITIVE | CC_QUADRIC_BIT
static const CC_CLASS_ENUM MATERIAL_SET = CC_MATERIAL_BIT | CC_GROUP_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM CHUNKED_ARRAY = CC_ARRAY_BIT
static const CC_CLASS_ENUM NORMALS_ARRAY = CC_ARRAY_BIT | CC_NORMAL_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM NORMAL_INDEXES_ARRAY = CC_ARRAY_BIT | CC_COMPRESSED_NORMAL_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM RGB_COLOR_ARRAY = CC_ARRAY_BIT | CC_RGB_COLOR_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM TEX_COORDS_ARRAY = CC_ARRAY_BIT | CC_TEX_COORDS_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM LABEL_2D = HIERARCHY_OBJECT | CC_LABEL_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM VIEWPORT_2D_OBJECT = HIERARCHY_OBJECT | CC_VIEWPORT_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM VIEWPORT_2D_LABEL = VIEWPORT_2D_OBJECT | CC_LABEL_BIT
static const CC_CLASS_ENUM CLIPPING_BOX = CC_CLIP_BOX_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM TRANS_BUFFER = HIERARCHY_OBJECT | CC_TRANS_BUFFER_BIT | CC_LEAF_BIT
static const CC_CLASS_ENUM CUSTOM_H_OBJECT = HIERARCHY_OBJECT | CC_CUSTOM_BIT
static const CC_CLASS_ENUM CUSTOM_LEAF_OBJECT = CUSTOM_H_OBJECT | CC_LEAF_BIT
Member Data Documentation
const CC_CLASS_ENUM CC_TYPES::CUSTOM_H_OBJECT = HIERARCHY_OBJECT | CC_CUSTOM_BIT
static
Custom objects are typically defined by plugins. They can be inserted in an object hierarchy or displayed in an OpenGL context like any other ccHObject. To differentiate custom objects, use the meta-data mechanism (see ccOBject::getMetaData and ccOBject::setMetaData). You can also define a custom icon (see ccHObject::getIcon).
It is highly advised to use the ccCustomHObject and ccCustomLeafObject interfaces to define a custom types. Carefully read the ccCustomHObject::isDeserialized method's description and the warning below!
Warning: custom objects can't be 'fully' serialized. Don't overload the 'ccSerializableObject::toFile' method for them as this would break the deserialization mechanism! They can only be serialized as plain ccHObject instances (CC_TYPES::HIERARCHY_OBJECT). Hierarchical custom objects (CC_TYPES::CUSTOM_H_OBJECT) will be deserialized as ccCustomHObject instances. Leaf custom objects (CC_TYPES::CUSTOM_LEAF_OBJECT) will be deserialized as ccCustomLeafObject instances.
