qCC_db version 2.13.alpha (Qt) - 31 May 2022
CloudCompare 3D entities
Array of RGB colors for each point. More...
#include <ccAdvancedTypes.h>
Public Member Functions | |
ColorsTableType () | |
Default constructor. | |
CC_CLASS_ENUM | getClassID () const override |
Returns class ID. More... | |
ColorsTableType * | clone () override |
Duplicates array (overloaded from ccArray::clone) More... | |
Public Member Functions inherited from ccArray< ccColor::Rgb, 3, ColorCompType > | |
ccArray (QString name=QString()) | |
virtual Base * | clone () |
Duplicates array. More... | |
bool | copy (Base &dest) const |
Copies the content of this array in another one. | |
bool | reserveSafe (size_t count) |
Reserves memory (no exception thrown) | |
bool | isAllocated () const |
Returns whether some memory has been allocated or not. | |
bool | resizeSafe (size_t count, bool initNewElements=false, const ccColor::Rgb *valueForNewElements=nullptr) |
Resizes memory (no exception thrown) | |
virtual CC_CLASS_ENUM | getClassID () const override |
virtual bool | isShareable () const override |
Returns whether object is shareable or not. More... | |
virtual bool | isSerializable () const override |
Returns whether object is serializable of not. More... | |
ccColor::Rgb & | getValue (size_t index) |
const ccColor::Rgb & | getValue (size_t index) const |
void | setValue (size_t index, const ccColor::Rgb &value) |
void | addElement (const ccColor::Rgb &value) |
void | fill (const ccColor::Rgb &value) |
unsigned | currentSize () const |
void | clear (bool releaseMemory=false) |
void | swap (size_t i1, size_t i2) |
Public Member Functions inherited from ccHObject | |
ccHObject (const QString &name=QString(), unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID) | |
Default constructor. More... | |
ccHObject (const ccHObject &object) | |
Copy constructor. | |
~ccHObject () override | |
Default destructor. | |
bool | isGroup () const |
Returns whether the instance is a group. | |
ccHObject * | getParent () const |
Returns parent object. More... | |
virtual QIcon | getIcon () const |
Returns the icon associated to this entity. More... | |
void | addDependency (ccHObject *otherObject, int flags, bool additive=true) |
Adds a new dependence (additive or not) More... | |
int | getDependencyFlagsWith (const ccHObject *otherObject) const |
Returns the dependency flags with a given object. More... | |
void | removeDependencyWith (ccHObject *otherObject) |
Removes any dependency flags with a given object. More... | |
void | removeDependencyFlag (ccHObject *otherObject, DEPENDENCY_FLAGS flag) |
Removes a given dependency flag. More... | |
virtual bool | addChild (ccHObject *child, int dependencyFlags=DP_PARENT_OF_OTHER, int insertIndex=-1) |
Adds a child. More... | |
unsigned | getChildrenNumber () const |
Returns the number of children. More... | |
unsigned int | getChildCountRecursive () const |
Returns the total number of children under this object recursively. More... | |
ccHObject * | getChild (unsigned childPos) const |
Returns the ith child. More... | |
ccHObject * | find (unsigned uniqueID) const |
Finds an entity in this object hierarchy. More... | |
unsigned | filterChildren (Container &filteredChildren, bool recursive=false, CC_CLASS_ENUM filter=CC_TYPES::OBJECT, bool strict=false, ccGenericGLDisplay *inDisplay=nullptr) const |
Collects the children corresponding to a certain pattern. More... | |
void | detachChild (ccHObject *child) |
Detaches a specific child. More... | |
void | detachAllChildren () |
Removes a specific child. More... | |
void | removeChild (ccHObject *child) |
void | removeChild (int pos) |
Removes a specific child given its index. More... | |
void | removeAllChildren () |
Removes all children. | |
int | getChildIndex (const ccHObject *aChild) const |
Returns child index. | |
void | swapChildren (unsigned firstChildIndex, unsigned secondChildIndex) |
Swaps two children. | |
int | getIndex () const |
Returns index relatively to its parent or -1 if no parent. | |
void | transferChild (ccHObject *child, ccHObject &newParent) |
Transfer a given child to another parent. | |
void | transferChildren (ccHObject &newParent, bool forceFatherDependent=false) |
Transfer all children to another parent. | |
ccHObject * | getFirstChild () const |
Shortcut: returns first child. | |
ccHObject * | getLastChild () const |
Shortcut: returns last child. | |
bool | isAncestorOf (const ccHObject *anObject) const |
Returns true if the current object is an ancestor of the specified one. | |
virtual ccBBox | getOwnBB (bool withGLFeatures=false) |
Returns the entity's own bounding-box (with local/shifted coordinates) More... | |
virtual ccBBox | getBB_recursive (bool withGLFeatures=false, bool onlyEnabledChildren=true) |
Returns the local bounding-box of this entity and it's children. More... | |
virtual GlobalBoundingBox | getOwnGlobalBB (bool withGLFeatures=false) |
Returns the entity's own global bounding-box (with global/non-shifted coordinates - if relevant) More... | |
virtual bool | getOwnGlobalBB (CCVector3d &minCorner, CCVector3d &maxCorner) |
virtual GlobalBoundingBox | getGlobalBB_recursive (bool withGLFeatures=false, bool onlyEnabledChildren=true) |
Returns the global bounding-box of this entity and it's children. More... | |
virtual ccBBox | getDisplayBB_recursive (bool relative, const ccGenericGLDisplay *display=nullptr) |
Returns the bounding-box of this entity and it's children WHEN DISPLAYED. More... | |
virtual ccBBox | getOwnFitBB (ccGLMatrix &trans) |
Returns best-fit bounding-box (if available) More... | |
virtual void | drawBB (CC_DRAW_CONTEXT &context, const ccColor::Rgb &col) |
Draws the entity (and its children) bounding-box. More... | |
void | draw (CC_DRAW_CONTEXT &context) override |
Draws entity and its children. More... | |
bool | getAbsoluteGLTransformation (ccGLMatrix &trans) const |
Returns the absolute transformation (i.e. the actual displayed GL transformation) of an entity. More... | |
virtual bool | isDisplayed () const |
Returns whether the object is actually displayed (visible) or not. | |
virtual bool | isDisplayedIn (const ccGenericGLDisplay *display) const |
Returns whether the object is actually displayed (visible) in a given display or not. | |
virtual bool | isBranchEnabled () const |
Returns whether the object and all its ancestors are enabled. | |
ccHObject_recursive_call1 (setSelected, bool, setSelected_recursive) ccHObject_recursive_call1(setDisplay | |
ccGenericGLDisplay setDisplay_recursive | ccHObject_recursive_call1 (removeFromDisplay, ccGenericGLDisplay *, removeFromDisplay_recursive) ccHObject_recursive_call0(prepareDisplayForRefresh |
ccGenericGLDisplay setDisplay_recursive prepareDisplayForRefresh_recursive | ccHObject_recursive_call1 (refreshDisplay, bool, refreshDisplay_recursive) ccHObject_recursive_call0(resetGLTransformationHistory |
ccGenericGLDisplay setDisplay_recursive prepareDisplayForRefresh_recursive resetGLTransformationHistory_recursive | ccHObject_recursive_call0 (toggleActivation, toggleActivation_recursive) ccHObject_recursive_call0(toggleVisibility |
ccGenericGLDisplay setDisplay_recursive prepareDisplayForRefresh_recursive resetGLTransformationHistory_recursive toggleVisibility_recursive | ccHObject_recursive_call0 (toggleColors, toggleColors_recursive) ccHObject_recursive_call0(toggleNormals |
ccGenericGLDisplay setDisplay_recursive prepareDisplayForRefresh_recursive resetGLTransformationHistory_recursive toggleVisibility_recursive toggleNormals_recursive | ccHObject_recursive_call0 (toggleSF, toggleSF_recursive) ccHObject_recursive_call0(toggleShowName |
ccGenericGLDisplay setDisplay_recursive prepareDisplayForRefresh_recursive resetGLTransformationHistory_recursive toggleVisibility_recursive toggleNormals_recursive toggleShowName_recursive | ccHObject_recursive_call0 (toggleMaterials, toggleMaterials_recursive) inline virtual void transferDisplay(ccGenericGLDisplay *oldDisplay |
Transfers the entity from one display to the other. | |
void | applyGLTransformation_recursive (const ccGLMatrix *trans=nullptr) |
Applies the active OpenGL transformation to the entity (recursive) More... | |
virtual void | notifyGeometryUpdate () |
Notifies all dependent entities that the geometry of this entity has changed. | |
bool | toFile (QFile &out) const override |
Saves data to binary stream. More... | |
bool | fromFile (QFile &in, short dataVersion, int flags, LoadedIDMap &oldToNewIDMap) override |
Loads data from binary stream. More... | |
bool | fromFileNoChildren (QFile &in, short dataVersion, int flags, LoadedIDMap &oldToNewIDMap) |
Custom version of ccSerializableObject::fromFile. More... | |
virtual bool | isShareable () const |
virtual void | setSelectionBehavior (SelectionBehavior mode) |
Sets selection behavior (when displayed) More... | |
virtual SelectionBehavior | getSelectionBehavior () const |
Returns selection behavior. | |
virtual unsigned | getUniqueIDForDisplay () const |
Returns object unique ID used for display. More... | |
virtual const ccGLMatrix & | getGLTransformationHistory () const |
Returns the transformation 'history' matrix. More... | |
virtual void | setGLTransformationHistory (const ccGLMatrix &mat) |
Sets the transformation 'history' matrix (handle with care!) | |
virtual void | resetGLTransformationHistory () |
Resets the transformation 'history' matrix. | |
bool | pushDisplayState () override |
Pushes the current display state (overridden) More... | |
void | popDisplayState (bool apply=true) override |
Pops the last pushed display state (overridden) More... | |
Public Member Functions inherited from ccObject | |
ccObject (const QString &name=QString(), unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID) | |
ccObject (const ccObject &object) | |
virtual CC_CLASS_ENUM | getClassID () const =0 |
virtual QString | getName () const |
Returns object name. More... | |
virtual void | setName (const QString &name) |
Sets object name. | |
virtual unsigned | getUniqueID () const |
Returns object unique ID. | |
virtual void | setUniqueID (unsigned ID) |
Changes unique ID. More... | |
virtual bool | isEnabled () const |
Returns whether the object is enabled or not. More... | |
virtual void | setEnabled (bool state) |
Sets the "enabled" property. More... | |
virtual void | toggleActivation () |
Toggles the "enabled" property. | |
virtual bool | isLocked () const |
Returns whether the object is locked or not. More... | |
virtual void | setLocked (bool state) |
bool | isLeaf () const |
bool | isCustom () const |
bool | isHierarchy () const |
bool | isKindOf (CC_CLASS_ENUM type) const |
bool | isA (CC_CLASS_ENUM type) const |
QVariant | getMetaData (const QString &key) const |
Returns a given associated meta data. More... | |
bool | removeMetaData (const QString &key) |
Removes a given associated meta-data. More... | |
void | setMetaData (const QString &key, const QVariant &data) |
Sets a meta-data element. More... | |
void | setMetaData (const QVariantMap &dataset, bool overwrite=false) |
Sets several meta-data elements at a time. More... | |
bool | hasMetaData (const QString &key) const |
Returns whether a meta-data element with the given key exists or not. More... | |
const QVariantMap & | metaData () const |
Returns meta-data map (const only) | |
Public Member Functions inherited from ccSerializableObject | |
virtual | ~ccSerializableObject ()=default |
Destructor. | |
virtual bool | isSerializable () const |
virtual bool | toFile (QFile &out) const |
virtual bool | fromFile (QFile &in, short dataVersion, int flags, LoadedIDMap &oldToNewIDMap) |
Public Member Functions inherited from ccDrawableObject | |
ccDrawableObject () | |
ccDrawableObject (const ccDrawableObject &object) | |
virtual void | draw (CC_DRAW_CONTEXT &context)=0 |
virtual bool | isVisible () const |
Returns whether entity is visible or not. | |
virtual void | setVisible (bool state) |
Sets entity visibility. | |
virtual void | toggleVisibility () |
Toggles visibility. | |
virtual bool | isVisibilityLocked () const |
Returns whether visibility is locked or not. | |
virtual void | lockVisibility (bool state) |
Locks/unlocks visibility. More... | |
virtual bool | isSelected () const |
Returns whether entity is selected or not. | |
virtual void | setSelected (bool state) |
Selects/unselects entity. | |
virtual void | getDrawingParameters (glDrawParams ¶ms) const |
Returns main OpenGL parameters for this entity. More... | |
virtual bool | hasColors () const |
Returns whether colors are enabled or not. More... | |
virtual bool | colorsShown () const |
Returns whether colors are shown or not. | |
virtual void | showColors (bool state) |
Sets colors visibility. | |
virtual void | toggleColors () |
Toggles colors display state. | |
virtual bool | hasNormals () const |
Returns whether normals are enabled or not. More... | |
virtual bool | normalsShown () const |
Returns whether normals are shown or not. More... | |
virtual void | showNormals (bool state) |
Sets normals visibility. More... | |
virtual void | toggleNormals () |
Toggles normals display state. | |
virtual bool | hasDisplayedScalarField () const |
Returns whether an active scalar field is available or not. More... | |
virtual bool | hasScalarFields () const |
Returns whether one or more scalar fields are instantiated. More... | |
virtual void | showSF (bool state) |
Sets active scalarfield visibility. | |
virtual void | toggleSF () |
Toggles SF display state. | |
virtual bool | sfShown () const |
Returns whether active scalar field is visible. | |
virtual void | toggleMaterials () |
Toggles material display state. More... | |
virtual void | showNameIn3D (bool state) |
Sets whether name should be displayed in 3D or not. | |
virtual bool | nameShownIn3D () const |
Returns whether name is displayed in 3D or not. | |
virtual void | toggleShowName () |
Toggles name in 3D display state. | |
virtual bool | isColorOverridden () const |
Returns whether colors are currently overridden by a temporary (unique) color. More... | |
virtual const ccColor::Rgba & | getTempColor () const |
Returns current temporary (unique) color. | |
virtual void | setTempColor (const ccColor::Rgba &col, bool autoActivate=true) |
Sets current temporary (unique) More... | |
virtual void | setTempColor (const ccColor::Rgb &col, bool autoActivate=true) |
virtual void | enableTempColor (bool state) |
Set temporary color activation state. | |
virtual void | removeFromDisplay (const ccGenericGLDisplay *win) |
Unlinks entity from a GL display (only if it belongs to it of course) | |
virtual void | setDisplay (ccGenericGLDisplay *win) |
Sets associated GL display. | |
virtual ccGenericGLDisplay * | getDisplay () const |
Returns associated GL display. | |
virtual void | redrawDisplay () |
Redraws associated GL display. | |
virtual void | prepareDisplayForRefresh () |
Sets associated GL display 'refreshable' before global refresh. More... | |
virtual void | refreshDisplay (bool only2D=false) |
Refreshes associated GL display. More... | |
virtual void | setGLTransformation (const ccGLMatrix &trans) |
Associates entity with a GL transformation (rotation + translation) More... | |
virtual void | enableGLTransformation (bool state) |
Enables/disables associated GL transformation. More... | |
virtual bool | isGLTransEnabled () const |
Returns whether a GL transformation is enabled or not. | |
virtual const ccGLMatrix & | getGLTransformation () const |
Returns associated GL transformation. More... | |
virtual void | resetGLTransformation () |
Resets associated GL transformation. More... | |
virtual void | rotateGL (const ccGLMatrix &rotMat) |
Multiplies (left) current GL transformation by a rotation matrix. More... | |
virtual void | translateGL (const CCVector3 &trans) |
Translates current GL transformation by a rotation matrix. More... | |
virtual void | removeAllClipPlanes () |
Removes all clipping planes (if any) | |
virtual bool | addClipPlanes (const ccClipPlane &plane) |
Registers a new clipping plane. More... | |
virtual void | toggleClipPlanes (CC_DRAW_CONTEXT &context, bool enable) |
Enables or disables clipping planes (OpenGL) More... | |
virtual bool | pushDisplayState () |
Pushes the current display state. More... | |
virtual void | popDisplayState (bool apply=true) |
Pops the last pushed display state. More... | |
virtual void | applyDisplayState (const DisplayState &state) |
Applies a display state. | |
Additional Inherited Members | |
Public Types inherited from ccArray< ccColor::Rgb, 3, ColorCompType > | |
typedef ccArray< ccColor::Rgb, N, ColorCompType > | Base |
Base type. | |
Public Types inherited from ccHObject | |
enum | DEPENDENCY_FLAGS { DP_NONE = 0 , DP_NOTIFY_OTHER_ON_DELETE = 1 , DP_NOTIFY_OTHER_ON_UPDATE = 2 , DP_DELETE_OTHER = 8 , DP_PARENT_OF_OTHER = 24 } |
Dependency flags. More... | |
enum | SelectionBehavior { SELECTION_AA_BBOX , SELECTION_FIT_BBOX , SELECTION_IGNORED } |
Behavior when selected. | |
using | Container = std::vector< ccHObject * > |
Standard instances container (for children, etc.) | |
using | Shared = QSharedPointer< ccHObject > |
Shared pointer. | |
using | SharedContainer = std::vector< Shared > |
Shared instances container (for children, etc.) | |
using | GlobalBoundingBox = CCCoreLib::BoundingBoxTpl< double > |
Global (non-shifted) bounding-box. | |
Public Types inherited from ccSerializableObject | |
enum | DeserializationFlags { DF_POINT_COORDS_64_BITS = 1 , DF_SCALAR_VAL_32_BITS = 2 } |
Deserialization flags (bit-field) More... | |
typedef QMultiMap< unsigned, unsigned > | LoadedIDMap |
Map of loaded unique IDs (old ID --> new ID) | |
Static Public Member Functions inherited from ccHObject | |
static ccHObject * | New (CC_CLASS_ENUM objectType, const char *name=nullptr) |
Static factory. More... | |
static ccHObject * | New (const QString &pluginId, const QString &classId, const char *name=nullptr) |
Static factory (version to be used by external plugin factories) More... | |
Static Public Member Functions inherited from ccObject | |
static unsigned | GetCurrentDBVersion () |
Returns current database version. | |
static void | SetUniqueIDGenerator (ccUniqueIDGenerator::Shared generator) |
Sets the unique ID generator. | |
static ccUniqueIDGenerator::Shared | GetUniqueIDGenerator () |
Returns the unique ID generator. | |
static unsigned | GetNextUniqueID () |
Returns a new unassigned unique ID. More... | |
static unsigned | GetLastUniqueID () |
Returns last assigned unique ID. More... | |
static CC_CLASS_ENUM | ReadClassIDFromFile (QFile &in, short dataVersion) |
Helper: reads out class ID from a binary stream. More... | |
Static Public Member Functions inherited from ccSerializableObject | |
static bool | WriteError () |
Sends a custom error message (write error) and returns 'false'. More... | |
static bool | ReadError () |
Sends a custom error message (read error) and returns 'false'. More... | |
static bool | MemoryError () |
Sends a custom error message (not enough memory) and returns 'false'. More... | |
static bool | CorruptError () |
Sends a custom error message (corrupted file) and returns 'false'. More... | |
Public Attributes inherited from ccHObject | |
ccGenericGLDisplay setDisplay_recursive prepareDisplayForRefresh_recursive resetGLTransformationHistory_recursive toggleVisibility_recursive toggleNormals_recursive toggleShowName_recursive ccGenericGLDisplay * | newDisplay |
Protected Member Functions inherited from ccArray< ccColor::Rgb, 3, ColorCompType > | |
virtual | ~ccArray () |
Destructor (protected) More... | |
virtual bool | toFile_MeOnly (QFile &out) const override |
Save own object data. More... | |
virtual bool | fromFile_MeOnly (QFile &in, short dataVersion, int flags, LoadedIDMap &oldToNewIDMap) override |
Loads own object data. More... | |
Protected Member Functions inherited from ccHObject | |
virtual void | setParent (ccHObject *anObject) |
Sets parent object. | |
virtual void | drawMeOnly (CC_DRAW_CONTEXT &context) |
Draws the entity only (not its children) More... | |
virtual void | applyGLTransformation (const ccGLMatrix &trans) |
Applies a GL transformation to the entity. More... | |
virtual bool | toFile_MeOnly (QFile &out) const |
virtual bool | fromFile_MeOnly (QFile &in, short dataVersion, int flags, LoadedIDMap &oldToNewIDMap) |
virtual void | drawNameIn3D (CC_DRAW_CONTEXT &context) |
Draws the entity name in 3D. More... | |
virtual void | onDeletionOf (const ccHObject *obj) |
This method is called when another object is deleted. More... | |
virtual void | onUpdateOf (ccHObject *obj) |
This method is called when another object (geometry) is updated. More... | |
Protected Member Functions inherited from ccObject | |
virtual bool | getFlagState (CC_OBJECT_FLAG flag) const |
Returns flag state. | |
virtual void | setFlagState (CC_OBJECT_FLAG flag, bool state) |
Sets flag state. More... | |
Reimplemented from ccSerializableObject::fromFile. More... | |
Protected Attributes inherited from ccHObject | |
ccHObject * | m_parent |
Parent. | |
Container | m_children |
Children. | |
SelectionBehavior | m_selectionBehavior |
Selection behavior. | |
std::map< ccHObject *, int > | m_dependencies |
Dependencies map. More... | |
ccGLMatrix | m_glTransHistory |
Cumulative GL transformation. More... | |
bool | m_isDeleting |
Flag to safely handle dependencies when the object is being deleted. | |
Protected Attributes inherited from ccObject | |
QString | m_name |
Object name. | |
unsigned | m_flags |
Object flags. | |
QVariantMap | m_metaData |
Associated meta-data. | |
Protected Attributes inherited from ccDrawableObject | |
bool | m_visible |
Specifies whether the object is visible or not. More... | |
bool | m_selected |
Specifies whether the object is selected or not. | |
bool | m_lockedVisibility |
Specifies whether the visibility can be changed by user or not. | |
bool | m_colorsDisplayed |
Specifies whether colors should be displayed. | |
bool | m_normalsDisplayed |
Specifies whether normals should be displayed. | |
bool | m_sfDisplayed |
Specifies whether scalar field should be displayed. | |
ccColor::Rgba | m_tempColor |
Temporary (unique) color. | |
bool | m_colorIsOverridden |
Temporary (unique) color activation state. | |
ccGLMatrix | m_glTrans |
Current GL transformation. More... | |
bool | m_glTransEnabled |
Current GL transformation activation state. More... | |
bool | m_showNameIn3D |
Whether name is displayed in 3D or not. | |
CCVector3d | m_nameIn3DPos |
Last 2D position of the '3D' name. | |
bool | m_nameIn3DPosIsValid |
Whether the last 2D position of the '3D' name is valid or not. | |
ccGenericGLDisplay * | m_currentDisplay |
Currently associated GL display. | |
ccClipPlaneSet | m_clipPlanes |
Active clipping planes (used for display only) | |
std::vector< DisplayState::Shared > | m_displayStateStack |
The stack of pushed display states. | |
inlineoverridevirtual |
Reimplemented from ccArray< ccColor::Rgb, 3, ColorCompType >.
Returns class ID.
