Classes | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
cc2DLabel Class Reference
2D label (typically attached to points) More...
#include <cc2DLabel.h>
Inheritance diagram for cc2DLabel:
Inheritance graph
Collaboration diagram for cc2DLabel:
Classes
struct  PickedPoint
 Picked point descriptor. More...
 cc2DLabel (QString name=QString("label"))
 Default constructor.
 Returns object name.
 Returns class ID. More...
QString getRawName () const
 Returns 'raw' name (no replacement of default keywords)
bool addPoint (ccGenericPointCloud *cloud, unsigned pointIndex)
 Adds a point to label. More...
QStringList getLabelContent (int precision)
 Gets label content (as it will be displayed) More...
virtual bool acceptClick (int x, int y, Qt::MouseButton button)
 Called on mouse click.
virtual bool move2D (int x, int y, int dx, int dy, int screenWidth, int screenHeight)
 Called on mouse move (for 2D interactors) More...
void setPosition (float x, float y)
 Sets relative position.
const float * getPosition () const
 Returns relative position.
void clear (bool ignoreDependencies=false)
 Clears label.
unsigned size () const
 Returns current size.
void setCollapsed (bool state)
 Whether to collapse label or not.
bool isCollapsed () const
 Returns Whether the label is collapsed or not.
void setDisplayedIn3D (bool state)
 Whether to display the label in 3D (title only)
bool isDisplayedIn3D () const
 Returns whether the label is displayed in 3D (title only)
void setDisplayedIn2D (bool state)
 Whether to display the label in 2D.
bool isDisplayedIn2D () const
 Returns whether the label is displayed in 2D.
const PickedPointgetPoint (unsigned index) const
 Returns a given point.
 Default constructor. More...
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
virtual ccBBox getMyOwnBB ()
 Returns selection behavior.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
- Public Member Functions inherited from ccInteractor
virtual bool move3D (const CCVector3 &u)
 Called on mouse move (for 3D interactors) More...
 Save own object data. More...
virtual void drawMeOnly2D (CC_DRAW_CONTEXT &context)
 Draws the entity only (not its children) - 2D version.
virtual void drawMeOnly3D (CC_DRAW_CONTEXT &context)
 Draws the entity only (not its children) - 3D version.
void updateName ()
 Updates the label 'name'.
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
std::vector< PickedPointm_points
 Picked points.
bool m_showFullBody
 Whether to show full label body or not.
int m_labelROI [4]
 label ROI More...
float m_screenPos [2]
 close button ROI More...
int m_lastScreenPos [2]
 Label position at last display (absolute)
bool m_dispIn3D
bool m_dispIn2D
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
Member Function Documentation
bool cc2DLabel::addPoint ( ccGenericPointCloud cloud,
unsigned  pointIndex
Adding a point to a label will automatcillay make it 'mute'. 1 point = 'point' label (point position, normal, color, etc.) 2 points = 'vector' label (vertices position, distance) 3 points = "triangle/plane' label (vertices position, area, normal)
Returns
false if 'full'
bool cc2DLabel::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
protectedvirtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccHObject.
virtual CC_CLASS_ENUM cc2DLabel::getClassID ( ) const
inlinevirtual
Returns class ID.
Returns
class unique ID
QStringList cc2DLabel::getLabelContent ( int  precision)
precisiondisplayed numbers precision
Returns
label body (one string per line)
bool cc2DLabel::move2D ( int  x,
int  y,
int  dx,
int  dy,
int  screenWidth,
int  screenHeight
virtual
Returns
true if a movement occurs
Reimplemented from ccInteractor.
void cc2DLabel::onDeletionOf ( const ccHObject obj)
protectedvirtual
This method is called when another object is deleted.
For internal use.
bool cc2DLabel::toFile_MeOnly ( QFile &  out) const
protectedvirtual
Member Data Documentation
int cc2DLabel::m_labelROI[4]
protected
label ROI
ROI is displayed relatively to m_screenPos (projected in displayed screen space). m_screenPos corresponds to its top-left corner. So ROI[1] is the distance to the upper border and ROI[3] is the distance to the lower border (relatively to m_screenPos).
float cc2DLabel::m_screenPos[2]
protected
close button ROI
Label position (percentage of screen size)
