Classes | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ccCalibratedImage Class Reference
Image associated to 3D calibration information. More...
#include <ccCalibratedImage.h>
Inheritance diagram for ccCalibratedImage:
Inheritance graph
Collaboration diagram for ccCalibratedImage:
Classes
struct  KeyPoint
 Key point. More...
 ccCalibratedImage ()
 Default constructor.
 Returns unique class ID.
void setFocal (float focal_pix, bool deduceFOV=true)
 Sets camera focal (in pixels) More...
float getFocal () const
 Returns focal (in pixels)
void setFov (float fov_deg)
 Sets camera f.o.v. (field of view) value in degrees.
float getFov () const
 Returns camera f.o.v. (field of view) value in degrees.
void setCameraMatrix (const CCVector3 &axis, float angle_rad, const CCVector3 &t)
 Sets camera matrix (orientation as an axis + angle) More...
void setCameraMatrix (const ccGLMatrix &mat)
 Sets camera matrix (rotation + translation) More...
const ccGLMatrixgetCameraMatrix () const
 Returns camera matrix.
void setDistortionCoefficients (float k1, float k2)
 Sets distortion coefficients.
void getDistortionCoefficients (float &k1, float &k2) const
 Returns distortion coefficients.
bool undistort ()
 Applies undistortion coefficients. More...
ccPointCloudorthoRectifyAsCloud (CCLib::GenericIndexedCloud *keypoints3D, std::vector< KeyPoint > &keypointsImage) const
 Projective ortho-rectification (as cloud) More...
ccImageorthoRectifyAsImage (CCLib::GenericIndexedCloud *keypoints3D, std::vector< KeyPoint > &keypointsImage, double &pixelSize, double *minCorner=0, double *maxCorner=0, double *realCorners=0) const
 Projective ortho-rectification (as image) More...
bool computeOrthoRectificationParams (CCLib::GenericIndexedCloud *keypoints3D, std::vector< KeyPoint > &keypointsImage, double a[], double b[], double c[]) const
 Computes ortho-rectification parameters. More...
- Public Member Functions inherited from ccImage
 ccImage ()
 ccImage (const QImage &image, const QString &name=QString("unknown"))
 Constructor from QImage.
bool load (const QString &filename, QString &error)
 Loads image from file. More...
virtual void setImage (const QImage &image)
 Sets image. More...
unsigned getW () const
 Returns image width.
unsigned getH () const
 Returns image height.
virtual void setAlpha (float value)
 Sets image texture transparency.
virtual float getAlpha () const
 Returns image texture transparency.
virtual const QImage & data () const
 Returns coresponding QImage.
void setAspectRatio (float ar)
 Manually sets aspect ratio.
float getAspectRatio () const
 Returns aspect ratio.
 Default constructor. More...
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
virtual ccBBox getMyOwnBB ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
static bool OrthoRectifyAsImages (std::vector< ccCalibratedImage * > images, double a[], double b[], double c[], unsigned maxSize, QDir *outputDir=0, std::vector< ccImage * > *orthoRectifiedImages=0, std::vector< std::pair< double, double > > *relativePos=0)
 Projective ortho-rectification for multiple images. More...
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
void setFovFromFocal (float focal_pix)
 Computes f.o.v. from focal value (in pixels)
- Protected Member Functions inherited from ccImage
virtual bool unbindTexture ()
 Unbinds texture from currently associated GL context.
virtual bool bindToGlTexture (ccGenericGLDisplay *win, bool pow2Texture=false)
 Binds texture to a GL context (and creates texture if necessary) More...
 Sets parent object.
 Save own object data. More...
 Returns flag state.
 Sets flag state. More...
float m_fov_deg
 Camera field of view (in degrees) More...
float m_focal_pix
 Focal distance (in pixels)
CCVector3 m_pos
 Camera position (optic center)
ccGLMatrix m_trans
 Camera matrix (orientation + translation)
float m_k1
 1st radial distortion coefficient (k1)
float m_k2
 2nd radial distortion coefficient (k1)
- Protected Attributes inherited from ccImage
unsigned m_width
 Image width (in pixels)
unsigned m_height
 Image height (in pixels)
float m_aspectRatio
 Aspect ratio w/h. More...
float m_texU
 Texture coordinate (width) of bottom-right pixel.
float m_texV
 Texture coordinate (height) of bottom-right pixel.
float m_texAlpha
 Texture transparency.
unsigned m_textureID
 Texture GL ID.
ccGenericGLDisplaym_boundWin
 Currently bound GL window.
QImage m_image
 Image data.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
Member Function Documentation
bool ccCalibratedImage::computeOrthoRectificationParams ( CCLib::GenericIndexedCloud *  keypoints3D,
std::vector< KeyPoint > &  keypointsImage,
double  a[],
double  b[],
double  c[]
) const
Requires at least 4 key points! Collinearity equation: x'i = (a0+a1.xi+a2.yi)/(1+c1.xi+c2.yi) y'i = (b0+b1.xi+b2.yi)/(1+c1.xi+c2.yi)
keypoints3Dkeypoints in 3D
keypointsImagecorresponding keypoints in image
aa0, a1 & a2 parameters
bb0, b1 & b2 parameters
cc0(=1), c1 & c2 parameters
Returns
success
ccPointCloud * ccCalibratedImage::orthoRectifyAsCloud ( CCLib::GenericIndexedCloud *  keypoints3D,
) const
Returns
ortho-rectified image as a point cloud
ccImage * ccCalibratedImage::orthoRectifyAsImage ( CCLib::GenericIndexedCloud *  keypoints3D,
double &  pixelSize,
double *  minCorner = 0,
double *  maxCorner = 0,
double *  realCorners = 0
) const
pixelSizepixel size (auto if -1)
minCorner(optional) outputs 3D min corner (2 values)
maxCorner(optional) outputs 3D max corner (2 values)
realCorners(optional) image real 3D corners (4*2 values)
Returns
bool ccCalibratedImage::OrthoRectifyAsImages ( std::vector< ccCalibratedImage * >  images,
double  a[],
double  b[],
double  c[],
unsigned  maxSize,
QDir *  outputDir = 0,
std::vector< ccImage * > *  orthoRectifiedImages = 0,
std::vector< std::pair< double, double > > *  relativePos = 0
static
imagesset of N calibrated images
a{a0, a1, a2} triplets for all images (size: 3*N)
b{b0, b1, b2} triplets for all images (size: 3*N)
c{c0(=1), c1, c2} triplets for all images (size: 3*N)
maxSizeoutput image(s) max dimension
outputDiroutput directory for resulting images (is successful)
[out]orthoRectifiedImagesresulting images (is successful)
[out]relativePosrelative positions (relatively to first image)
Returns
true if successful
void ccCalibratedImage::setCameraMatrix ( const CCVector3 &  axis,
float  angle_rad,
const CCVector3 &  t
axisview axis
angle_radrotation angle around view axis (in radians)
ttranslation
void ccCalibratedImage::setCameraMatrix ( const ccGLMatrix mat)
mat4x4 transformation matrix
void ccCalibratedImage::setFocal ( float  focal_pix,
bool  deduceFOV = true
focal_pixfocal expressed in pixels
deduceFOVautomatically deduce f.o.v. from focal value and image height
bool ccCalibratedImage::undistort ( )
Correction: r(p) = 1.0 + k1 * ||p||^2 + k2 * ||p||^4. Be sure to call setFocal & setDistortionCoefficients first!
Member Data Documentation
float ccCalibratedImage::m_fov_deg
protected
Equivalent to OpenGL 'fovy' (see gluPerspective)
