Classes | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ccCameraSensor Class Reference
Camera (projective) sensor. More...
#include <ccCameraSensor.h>
Inheritance diagram for ccCameraSensor:
Inheritance graph
Collaboration diagram for ccCameraSensor:
Classes
struct  FrustumInformation
 Frustum information structure. More...
struct  IntrinsicParameters
 Intrinsic parameters of the camera sensor. More...
struct  UncertaintyParameters
 Parameters ion order to correct lens distortion. More...
 ccCameraSensor ()
 Default constructor.
virtual ~ccCameraSensor ()
 Destructor.
bool frustrumIsDrawn () const
 Returns whether the frustum should be displayed or not.
void drawFrustrum (bool state)
 Sets whether the frustum should be displayed or not.
bool frustrumPlanesAreDrawn () const
 Returns whether the frustum planes should be displayed or not.
void drawFrustrumPlanes (bool state)
 Sets whether the frustum planes should be displayed or not.
const ccGLMatrixgetProjectionMatrix () const
 Returns the camera projection matrix.
bool fromLocalCoordToGlobalCoord (const CCVector3 &localCoord, CCVector3 &globalCoord) const
 Computes the coordinates of a 3D point in the global coordinate system knowing its coordinates in the sensor coordinate system. More...
bool fromGlobalCoordToLocalCoord (const CCVector3 &globalCoord, CCVector3 &localCoord) const
 Computes the coordinates of a 3D point in the sensor coordinate system knowing its coordinates in the global coordinate system. More...
bool fromLocalCoordToImageCoord (const CCVector3 &localCoord, CCVector2i &imageCoord) const
bool fromImageCoordToLocalCoord (const CCVector2i &imageCoord, CCVector3 &localCoord, bool withLensCorrection, float depth=0) const
bool fromGlobalCoordToImageCoord (const CCVector3 &globalCoord, CCVector3 &localCoord, CCVector2i &imageCoord) const
 Computes the coordinates of a 3D point in the image knowing its coordinates in the global coordinate system. More...
bool fromImageCoordToGlobalCoord (const CCVector2i &imageCoord, CCVector3 &localCoord, CCVector3 &globalCoord, bool withLensCorrection, float depth=0) const
 Computes the global coordinates of a 3D points from its 3D coordinates (pixel position in the image) More...
bool fromRealImCoordToIdealImCoord (const CCVector2i &real, CCVector2i &ideal) const
 Apply the Brown's lens correction to the real projection (through a lens) of a 3D point in the image. More...
bool computeUncertainty (const CCVector2i &pixel, const float depth, Vector3Tpl< ScalarType > &sigma) const
 Knowing the ideal projection of a 3D point, computes what would be the real projection (through a lens) More...
bool computeUncertainty (CCLib::ReferenceCloud *points, std::vector< Vector3Tpl< ScalarType > > &accuracy) const
bool isGlobalCoordInFrustrum (const CCVector3 &globalCoord) const
 Tests if a 3D point is in the field of view of the camera. More...
void filterOctree (ccOctree *octree, std::vector< unsigned > &inCameraFrustrum)
 Filters an octree : all the box visible in the frustum will be drawn in red. More...
 Returns class ID. More...
virtual ccBBox getMyOwnBB ()
void computeGlobalPlaneCoefficients (float planeCoefficients[6][4], CCVector3 ptsFrustrum[8], CCVector3 edges[6], CCVector3 &center)
 Compute the coefficients of the 6 planes frustrum in the global coordinates system (normal vector are headed the frustrum inside), the edges direction vectors and the frustrum center. More...
- Public Member Functions inherited from ccSensor
 ccSensor (QString name)
virtual CC_SENSOR_TYPE getType () const
 Returns the sensor type. More...
virtual uchar checkVisibility (const CCVector3 &P) const
 Returns the "visibility type" of a point. More...
ccIndexedTransformationBuffergetPositions ()
 Returns associated positions.
void setPositions (ccIndexedTransformationBuffer *positions)
 Sets associated positions.
bool addPosition (ccGLMatrix &trans, double index)
 Adds a new position (shortcut) More...
bool getAbsoluteTransformation (ccIndexedTransformation &trans, double index) const
 Returns the absolute transformation between the world and the "optical" center (shortcut) More...
bool getActiveAbsoluteTransformation (ccIndexedTransformation &trans) const
 Gets currently active absolute transformation.
bool getActiveAbsoluteCenter (CCVector3 &vec) const
 Gets currently active absolute position.
bool getActiveAbsoluteRotation (ccGLMatrix &rotation) const
 Gets currently active rotation matrix (without translation)
virtual void setRigidTransformation (const ccGLMatrix &mat)
 Sets the rigid transformation between this sensor and its associated positions. More...
virtual ccGLMatrixgetRigidTransformation ()
 Returns the rigid transformation between this sensor and its associated positions.
virtual const ccGLMatrixgetRigidTransformation () const
 Returns the rigid transformation between this sensor and its associated positions (const version)
void getIndexBounds (double &minIndex, double &maxIndex) const
 Gets index boundaries (shortcut)
double getActiveIndex () const
 Sets currently active index (displayed position, etc.)
void setActiveIndex (double index)
void setGraphicScale (PointCoordinateType scale)
 Sets the sensor graphic representation scale.
PointCoordinateType getGraphicScale () const
 Returns the sensor graphic representation scale.
 Default constructor. More...
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
void computeProjectionMatrix ()
 Compute the projection matrix (from intrinsic parameters)
void computeFrustumCorners ()
 Computes the eight corners of the frustrum.
 Save own object data. More...
- Protected Member Functions inherited from ccSensor
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
IntrinsicParameters m_intrinsicParams
 Camera intrinsic parameters.
UncertaintyParameters m_uncertaintyParams
 Lens distortion parameters.
FrustumInformation m_frustrumInfos
 Frustrum information structure. More...
ccGLMatrix m_projecMatrix
 Intrinsic parameters matrix.
- Protected Attributes inherited from ccSensor
ccIndexedTransformationBufferm_posBuffer
 Positions buffer (optional)
ccGLMatrix m_rigidTransformation
 Rigid transformation between this sensor and its associated positions. More...
double m_activeIndex
 Active index (for displayed position, etc.)
Vector3Tpl< colorType > m_color
 Color of the sensor. More...
PointCoordinateType m_scale
 Sensor graphic representation scale.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
Member Function Documentation
void ccCameraSensor::computeGlobalPlaneCoefficients ( float  planeCoefficients[6][4],
CCVector3  edges[6],
CCVector3 &  center
planeCoefficientscoefficients of the six planes
edgesdirection vectors of the frustrum edges (there are 12 edges but some of them are colinear)
ptsFrustrumthe 8 frustrum corners in the global coordinates system
centercenter of the the frustrum circumscribed sphere
bool ccCameraSensor::computeUncertainty ( const CCVector2i &  pixel,
const float  depth,
Vector3Tpl< ScalarType > &  sigma
) const
Warning
The first pixel is (0,0) and the last (width-1,height-1)
[in]ideal2D coordinates of the ideal projection
[out]realwhat would be the real 2D coordinates of the projection trough a lensComputes the uncertainty of a point knowing its depth (from the sensor view point) and pixel projection coordinates
pixelcoordinates of the pixel where the 3D points is projected –> !! Note that the first index is (0,0) and the last (width-1,height-1) !!
depthdepth from sensor center to 3D point (must be positive)
sigmauncertainty vector (along X, Y and Z)
Returns
operation has succeded (typically, errors occur when the initial pixel coordinates are not into the image boundaries, or when the depth of the 3D point is negative)
bool ccCameraSensor::computeUncertainty ( CCLib::ReferenceCloud *  points,
std::vector< Vector3Tpl< ScalarType > > &  accuracy
) const
pointsthe points we want to compute the uncertainty
accuracyto get back the uncertainty TODO lensDistortion if we want to take the lens distortion into consideration
Returns
success
void ccCameraSensor::filterOctree ( ccOctree octree,
std::vector< unsigned > &  inCameraFrustrum
octreeOctree
inCameraFrustrumindices of points in the frustrum
bool ccCameraSensor::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
protectedvirtual
Loads own object data.
ininput file
dataVersionfile version
various parameters (dataVersion>=35)
Reimplemented from ccSensor.
bool ccCameraSensor::fromGlobalCoordToImageCoord ( const CCVector3 &  globalCoord,
CCVector3 &  localCoord,
CCVector2i &  imageCoord
) const
globalCoordglobal coordinates of the 3D point
localCoordto get back the local coordinates of the 3D point
imageCoordto get back the image coordinates of the projected 3D point –> !! Note that the first index is (0,0) and the last (width-1,height-1) !! TODO withLensError if we want to simulate what the projection would be with an imperfect lens
Returns
if operation has succeded (typically, errors occur when the projection of the initial 3D points is not into the image boundaries, or when the 3D point is behind the camera)
bool ccCameraSensor::fromGlobalCoordToLocalCoord ( const CCVector3 &  globalCoord,
) const
globalCoordglobal coordinates of the 3D point (input)
localCoordcorresponding local coordinates of the 3D point (output)
bool ccCameraSensor::fromImageCoordToGlobalCoord ( const CCVector2i &  imageCoord,
float  depth = 0
) const
imageCoordimage coordinates of the pixel (input) –> !! Note that the first index is (0,0) and the last (width-1,height-1) !!
localCoordlocal coordinates of the corresponding 3D point (output)
globalCoordglobal coordinates of the corresponding 3D point (output)
withLensCorrectionif we want to correct the initial pixel coordinates with the lens correction formula
depthif known, depth of the input pixel, in order to recover third coordinates (must be positive) ; if depth is 0.0, then the reprojection is made in the focal plane
Returns
if operation has succeded (typically, errors occur when the initial pixel coordinates are not into the image boundaries)
bool ccCameraSensor::fromImageCoordToLocalCoord ( const CCVector2i &  imageCoord,
float  depth = 0
) const
depthif known, depth of the input pixel in meters, in order to recover third coordinates (must be positive) ; if depth is 0.0, then the reprojection is made in the focal plane
Returns
bool ccCameraSensor::fromLocalCoordToGlobalCoord ( const CCVector3 &  localCoord,
) const
localCoordlocal coordinates of the 3D point (input)
globalCoordcorresponding global coordinates of the 3D point (output)
bool ccCameraSensor::fromLocalCoordToImageCoord ( const CCVector3 &  localCoord,
) const
imageCoordimage coordinates of the projected point on the image (output) –> !! Note that the first index is (0,0) and the last (width-1,height-1) !! TODO: withLensError if we want to simulate what the projection would be with an imperfect lens
Returns
bool ccCameraSensor::fromRealImCoordToIdealImCoord ( const CCVector2i &  real,
CCVector2i &  ideal
) const
realreal 2D coordinates of a pixel (asumming that this pixel coordinate is obtained after projection through a lens) (input) !! Note that the first index is (0,0) and the last (width-1,height-1) !!
idealafter applying lens correction (output) –> !! Note that the first index is (0,0) and the last (width-1,height-1) !!
virtual CC_CLASS_ENUM ccCameraSensor::getClassID ( ) const
inlinevirtual
Returns class ID.
Returns
class unique ID
ccBBox ccCameraSensor::getMyOwnBB ( )
virtual
Children bboxes are ignored.
Returns
bounding-box
Reimplemented from ccHObject.
bool ccCameraSensor::isGlobalCoordInFrustrum ( const CCVector3 &  globalCoord) const
globalCoordglobal coordinates of the 3D point TODO withLensCorrection if we want to take the lens distortion into consideration
Returns
bool ccCameraSensor::toFile_MeOnly ( QFile &  out) const
protectedvirtual
Member Data Documentation
FrustumInformation ccCameraSensor::m_frustrumInfos
protected
Used to draw it properly.
