Public Member Functions | Protected Member Functions | List of all members
ccChunkedArray< N, ElementType > Class Template Reference
Shareable 'chunked' array that can be properly inserted in the DB tree. More...
#include <ccChunkedArray.h>
Inheritance diagram for ccChunkedArray< N, ElementType >:
Inheritance graph
Collaboration diagram for ccChunkedArray< N, ElementType >:
 ccChunkedArray (QString name=QString())
 Default constructor.
virtual ccChunkedArray< N,
ElementType > *
clone ()
 Duplicates array.
 Returns class ID. More...
 Default constructor. More...
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
virtual ccBBox getMyOwnBB ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Save own object data. More...
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
template<int N, class ElementType>
class ccChunkedArray< N, ElementType >
Member Function Documentation
virtual bool ccChunkedArray< N, ElementType >::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
inlineprotectedvirtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccHObject.
virtual CC_CLASS_ENUM ccChunkedArray< N, ElementType >::getClassID ( ) const
inlinevirtual
Returns class ID.
Returns
class unique ID
Reimplemented in TextureCoordsContainer, ColorsTableType, NormsTableType, and NormsIndexesTableType.
virtual bool ccChunkedArray< N, ElementType >::isShareable ( ) const
inlinevirtual
Returns whether object is shareable or not.
If object is father dependent and 'shared', it won't be deleted but 'released' instead.
virtual bool ccChunkedArray< N, ElementType >::toFile_MeOnly ( QFile &  out) const
