CloudCompare 3D entities
Public Types | Public Member Functions | Static Public Member Functions | Static Public Attributes | Protected Member Functions | Protected Attributes | List of all members
ccColorScale Class Reference
Color scale. More...
#include <ccColorScale.h>
Inheritance diagram for ccColorScale:
Inheritance graph
Collaboration diagram for ccColorScale:
Public Types
using Shared = QSharedPointer< ccColorScale >
 Shared pointer type.
using LabelSet = std::set< double >
 Type of a list of custom labels.
 ccColorScale (const QString &name, const QString &uuid=QString())
 Default constructor. More...
 ~ccColorScale () override=default
 Destructor.
ccColorScale::Shared copy (const QString &uuid=QString()) const
 Creates a copy of this color scale (with a specified unique id)
const QString & getName () const
 Returns name.
void setName (const QString &name)
 Sets name.
const QString & getUuid () const
 Returns unique ID.
void setUuid (const QString &uuid)
 Sets unique ID.
void generateNewUuid ()
 Generates a new unique ID.
bool isRelative () const
 Returns whether scale is relative or absoute. More...
void setRelative ()
 Sets scale as relative.
void setAbsolute (double minVal, double maxVal)
 Sets scale as absolute.
void getAbsoluteBoundaries (double &minVal, double &maxVal) const
 Get absolute scale boundaries. More...
bool isLocked () const
 Returns whether scale is locked or not.
void setLocked (bool state)
 Sets whether scale is locked or not.
LabelSetcustomLabels ()
 Returns the list of custom labels (if any)
const LabelSetcustomLabels () const
 Returns the list of custom labels (if any - const version)
void setCustomLabels (const LabelSet &labels)
 Sets the list of custom labels (only if the scale is absolute) More...
int stepCount () const
 Returns the current number of steps. More...
ccColorScaleElementstep (int index)
 Access to a given step.
const ccColorScaleElementstep (int index) const
 Access to a given step (const)
void insert (const ccColorScaleElement &step, bool autoUpdate=true)
 Adds a step. More...
void remove (int index, bool autoUpdate=true)
 Deletes a given step. More...
void clear ()
 Clears all steps. More...
void update ()
 Updates internal representation. More...
double getRelativePosition (double value) const
 Returns relative position of a given value (wrt to scale absolute min and max) More...
const ccColor::RgbgetColorByValue (double value, const ccColor::Rgb *outOfRangeColor=nullptr) const
 Returns color by value. More...
const ccColor::RgbgetColorByRelativePos (double relativePos, const ccColor::Rgb *outOfRangeColor=nullptr) const
 Returns color by relative position in scale. More...
const ccColor::RgbgetColorByRelativePos (double relativePos, unsigned steps, const ccColor::Rgb *outOfRangeColor=nullptr) const
 Returns color by relative position in scale with a given 'resolution'. More...
const ccColor::RgbgetColorByIndex (unsigned index) const
 Returns color by index. More...
bool saveAsXML (const QString &filename) const
 Saves this color scale as an XML file.
 Destructor.
static ccColorScale::Shared Create (const QString &name)
 Creates a new color scale (with auto-generated unique id) More...
static Shared LoadFromXML (const QString &filename)
 Loads a color scale from an XML file.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
static constexpr unsigned MIN_STEPS = 2
 Minimum number of steps.
static constexpr unsigned DEFAULT_STEPS = 256
 Default number of steps for display.
static constexpr unsigned MAX_STEPS = 1024
 Maximum number of steps (internal representation)
void sort ()
 Sort elements.
QString m_name
 Name.
QString m_uuid
 Unique ID.
QList< ccColorScaleElementm_steps
 Elements.
ccColor::Rgb m_rgbaScale [MAX_STEPS]
 Internal representation (RGB)
bool m_updated
 Internal representation validity.
bool m_relative
 Whether scale is relative or not.
bool m_locked
 Whether scale is locked or not.
double m_absoluteMinValue
 'Absolute' minimum value More...
double m_absoluteRange
 'Absolute' range More...
LabelSet m_customLabels
 List of custom labels.
Color scale.
A color scale is defined by several 'steps' corresponding to given colors. The color between each step is linearly interpolated. A valid color scale must have at least 2 steps, one at relative position 0.0 (scale start) and one at relative position 1.0 (scale end). Steps can't be defined outside this interval.
For faster access, an array of interpolated colors is maintained internally. Be sure that the 'refresh' method has been called after any modification of the scale steps (position or color).
◆ ccColorScale()
ccColorScale::ccColorScale ( const QString &  name,
const QString &  uuid = QString()
namescale name
uuidUUID (automatically generated if none is provided) Scale are 'relative' by default (can be changed afterwards, see setAbsolute). On construction they already have the two extreme steps defined (at position 0.0 and 1.0).
Member Function Documentation
◆ clear()
void ccColorScale::clear ( )
Clears all steps.
There should be at least 2 steps for the scale to be valid! Scale must not be locked.
◆ Create()
ccColorScale::Shared ccColorScale::Create ( const QString &  name)
static
Warning: color scale is relative by default.
◆ fromFile()
bool ccColorScale::fromFile ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap oldToNewIDMap
overridevirtual
Loads data from binary stream.
ininput file (already opened)
dataVersionfile version
Returns
success
◆ getAbsoluteBoundaries()
void ccColorScale::getAbsoluteBoundaries ( double &  minVal,
double &  maxVal
) const
Warning: only valid with absolute scales!
◆ getColorByIndex()
const ccColor::Rgb & ccColorScale::getColorByIndex ( unsigned  index) const
inline
indexcolor index in m_rgbaScale array (must be below MAX_STEPS)
Returns
corresponding color
◆ getColorByRelativePos() [1/2]
const ccColor::Rgb * ccColorScale::getColorByRelativePos ( double  relativePos,
const ccColor::Rgb outOfRangeColor = nullptr
) const
inline
relativePosrelative position (should be in [0;1])
outOfRangeColordefault color to return if relativePos if out of [0;1]
Returns
corresponding color
◆ getColorByRelativePos() [2/2]
unsigned  steps,
) const
inline
relativePosrelative position (must be between 0 and 1!)
stepsdesired resolution (must be greater than 1 and smaller than MAX_STEPS)
Returns
corresponding color
◆ getColorByValue()
const ccColor::Rgb * ccColorScale::getColorByValue ( double  value,
) const
inline
valuevalue
Returns
corresponding color
◆ getRelativePosition()
double ccColorScale::getRelativePosition ( double  value) const
inline
Warning: only valid with absolute scales! Use 'getColorByRelativePos' otherwise.
◆ insert()
void ccColorScale::insert ( const ccColorScaleElement step,
bool  autoUpdate = true
Adds a step.
◆ isRelative()
bool ccColorScale::isRelative ( ) const
inline
Relative means that internal 'values' are percentage.
◆ isSerializable()
bool ccColorScale::isSerializable ( ) const
inlineoverridevirtual
◆ remove()
void ccColorScale::remove ( int  index,
The first and last index shouldn't be deleted! Scale must not be locked.
◆ setCustomLabels()
void ccColorScale::setCustomLabels ( const LabelSet labels)
inline
Warning
May throw std::bad_alloc exception)
◆ stepCount()
int ccColorScale::stepCount ( ) const
inline
A valid scale should always have at least 2 steps!
◆ toFile()
bool ccColorScale::toFile ( QFile &  out) const
overridevirtual
Saves data to binary stream.
outoutput file (already opened)
Returns
success
◆ update()
void ccColorScale::update ( )
Must be called at least once after any modification (before using this scale).
Member Data Documentation
◆ m_absoluteMinValue
double ccColorScale::m_absoluteMinValue
protected
Only used if scale is 'absolute' (i.e. not relative). 'Absolute' should not be taken in its mathematical meaning!
◆ m_absoluteRange
double ccColorScale::m_absoluteRange
protected
'Absolute' range
