Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
ccColorScalesManager Class Reference
Color scales manager/container. More...
#include <ccColorScalesManager.h>
Public Types
enum  DEFAULT_SCALES {
  BGYR = 0, GREY = 1, BWR = 2, RY = 3,
  RW = 4, ABS_NORM_GREY = 5, HSV_360_DEG = 6
 Pre-defined color scales (all relative - i.e. expand to actual SF) More...
typedef QMap< QString,
ccColorScale::Shared
ScalesMap
 Color scales map type.
virtual ~ccColorScalesManager ()
 Destructor.
ccColorScale::Shared getDefaultScale (DEFAULT_SCALES scale)
 Returns a pre-defined color scale.
ccColorScale::Shared getScale (QString UUID) const
 Returns a color scale based on its UUID.
void addScale (ccColorScale::Shared scale)
 Adds a new color scale.
void removeScale (QString UUID)
 Removes a color scale. More...
ScalesMapmap ()
 Access to the internal map.
const ScalesMapmap () const
 Access to the internal map (const)
void fromPersistentSettings ()
 Loads custom color scales from persistent settings.
void toPersistentSettings () const
 Save custom color scales to persistent settings.
static ccColorScalesManagerGetUniqueInstance ()
 Returns unique instance.
static void ReleaseUniqueInstance ()
 Releases unique instance.
static QString GetDefaultScaleUUID (int scale)
 Returns a pre-defined color scale UUID.
static ccColorScale::Shared GetDefaultScale (DEFAULT_SCALES scale=BGYR)
 Returns a pre-defined color scale (static shortcut)
 Default constructor.
static ccColorScale::Shared Create (DEFAULT_SCALES scaleType)
 Creates a pre-defined color scale.
ScalesMap m_scales
 Color scales.
Member Enumeration Documentation
Enumerator
BGYR
Blue-Green-Yellow-Red ramp (default for distances display)
GREY
Grey ramp (default for Global Illumination)
BWR
Blue-White-Red ramp (for signed SF)
RY
Red-Yellow ramp
RW
Red-White ramp
ABS_NORM_GREY
Absolute normalized grey ramp (intensities between 0 and 1)
HSV_360_DEG
HSV colors between 0 and 360 degrees
Member Function Documentation
void ccColorScalesManager::removeScale ( QString  UUID)
Warning: can't remove default scales!
