CloudCompare 3D entities
Public Member Functions | Static Public Attributes | Protected Member Functions | Protected Attributes | List of all members
ccCone Class Reference
Cone (primitive) More...
#include <ccCone.h>
Inheritance diagram for ccCone:
Inheritance graph
Collaboration diagram for ccCone:
 ccCone (PointCoordinateType bottomRadius, PointCoordinateType topRadius, PointCoordinateType height, PointCoordinateType xOff=0, PointCoordinateType yOff=0, const ccGLMatrix *transMat=nullptr, QString name=QString("Cone"), unsigned precision=DEFAULT_DRAWING_PRECISION, unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)
 Default constructor. More...
 ccCone (QString name=QString("Cone"))
 Returns class ID. More...
PointCoordinateType getHeight () const
 Returns height.
void setHeight (PointCoordinateType height)
 Sets height. More...
PointCoordinateType getBottomRadius () const
 Returns bottom radius.
virtual void setBottomRadius (PointCoordinateType radius)
 Sets bottom radius. More...
PointCoordinateType getTopRadius () const
 Returns top radius.
virtual void setTopRadius (PointCoordinateType radius)
 Sets top radius. More...
virtual CCVector3 getBottomCenter () const
 Returns cone axis bottom end point after applying transformation.
virtual CCVector3 getTopCenter () const
 Returns cone axis top end point after applying transformation.
virtual CCVector3 getSmallCenter () const
 Returns cone axis end point associated with whichever radii is smaller.
virtual CCVector3 getLargeCenter () const
 Returns cone axis end point associated with whichever radii is larger.
virtual PointCoordinateType getSmallRadius () const
 Returns whichever cone radii is smaller.
virtual PointCoordinateType getLargeRadius () const
 Returns whichever cone radii is larger.
virtual bool isSnoutMode () const
 Returns true if the Cone was created in snout mode.
virtual QString getTypeName () const override
virtual bool hasDrawingPrecision () const override
virtual ccGenericPrimitiveclone () const override
 Clones primitive. More...
virtual ccGenericPrimitiveclone () const =0
const ccGenericPrimitiveoperator+= (const ccGenericPrimitive &prim)
 Add operator. More...
virtual ccGLMatrixgetTransformation ()
virtual const ccGLMatrixgetTransformation () const
const ccGLMatrixgetGLTransformationHistory () const override
 ~ccMesh () override
 Default destructor.
ccMeshcloneMesh (ccGenericPointCloud *vertices=nullptr, ccMaterialSet *clonedMaterials=nullptr, NormsIndexesTableType *clonedNormsTable=nullptr, TextureCoordsContainer *cloneTexCoords=nullptr)
 Clones this entity. More...
ccGenericPointCloudgetAssociatedCloud () const override
void refreshBB () override
 Returns max capacity. More...
void invertNormals ()
void flipTriangles ()
 Flips the triangle. More...
bool reserve (size_t n)
bool resize (size_t n)
void shrinkToFit ()
 Removes unused capacity.
NormsIndexesTableTypegetTriNormsTable () const override
void clearTriNormals ()
 Removes per-triangle normals.
 Invert per-triangle normals.
const ccMaterialSetgetMaterialSet () const override
const triangleMaterialIndexesSetgetTriangleMtlIndexesTable () const
TextureCoordsContainergetTexCoordinatesTable () const override
 Computes normals. More...
 Laplacian smoothing. More...
ccMeshcreateNewMeshFromSelection (bool removeSelectedFaces)
 Swaps two triangles. More...
 Merges duplicated vertices.
 Destructor.
virtual ccGenericPointCloudgetAssociatedCloud () const =0
virtual void refreshBB ()=0
virtual const ccMaterialSetgetMaterialSet () const =0
virtual TextureCoordsContainergetTexCoordinatesTable () const =0
virtual NormsIndexesTableTypegetTriNormsTable () const =0
 Enables polygon stippling.
ccPointCloudsamplePoints (bool densityBased, double samplingParameter, bool withNormals, bool withRGB, bool withTexture, CCCoreLib::GenericProgressCallback *pDlg=nullptr)
 Samples points on a mesh.
 Copy constructor. More...
bool isShifted () const
template<typename T >
 Copy constructor.
 ~ccHObject () override
 Default destructor.
bool isGroup () const
ccHObjectgetParent () const
 Adds a child. More...
void detachAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns selection behavior.
 Copy constructor.
 Returns object name. More...
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Destructor.
 ccDrawableObject ()
 Copy constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Applies a display state.
static const unsigned DEFAULT_DRAWING_PRECISION = 24
 Default drawing precision. More...
 Save own object data. More...
virtual bool buildUp () override
 Builds primitive. More...
virtual bool buildUp ()=0
ccGenericPrimitivefinishCloneJob (ccGenericPrimitive *primitive) const
ccPointCloudvertices ()
 Returns vertices.
 Serialization helper (output)
 Serialization helper (input)
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
PointCoordinateType m_bottomRadius
 Bottom radius.
PointCoordinateType m_topRadius
 Top radius.
PointCoordinateType m_xOff
 Displacement of axes along X-axis (Snout mode)
PointCoordinateType m_yOff
 Displacement of axes along Y-axis (Snout mode)
PointCoordinateType m_height
 Height.
ccGLMatrix m_transformation
unsigned m_drawPrecision
ccMesh_extended_call1(showNormals, bool, showNormals_extended) protected NormsIndexesTableTypem_triNormals
 Per-triangle normals.
 Texture coordinates.
ccMaterialSetm_materials
 Materials.
unsigned m_globalIterator
ccBBox m_bBox
 Bounding-box.
bool m_triNormsShown
bool m_materialsShown
bool m_showWired
 Wireframe display mode.
bool m_stippling
 Polygon stippling state.
CCVector3d m_globalShift
double m_globalScale
ccHObjectm_parent
 Parent.
Container m_children
 Children.
 Selection behavior.
 Dependencies map. More...
ccGLMatrix m_glTransHistory
bool m_isDeleting
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
ccColor::Rgba m_tempColor
 Temporary (unique) color.
bool m_colorIsOverridden
bool m_glTransEnabled
bool m_showNameIn3D
CCVector3d m_nameIn3DPos
bool m_nameIn3DPosIsValid
ccClipPlaneSet m_clipPlanes
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Shared pointer.
static ccMeshTriangulate (ccGenericPointCloud *cloud, CCCoreLib::TRIANGULATION_TYPES type, bool updateNormals=false, PointCoordinateType maxEdgeLength=0, unsigned char dim=2)
static ccMeshTriangulateTwoPolylines (ccPolyline *p1, ccPolyline *p2, CCVector3 *projectionDir=nullptr)
 Static factory. More...
 Sets the unique ID generator.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
Cone (primitive)
3D cone primitive
◆ ccCone() [1/2]
ccCone::ccCone ( PointCoordinateType  bottomRadius,
PointCoordinateType  xOff = 0,
PointCoordinateType  yOff = 0,
const ccGLMatrix transMat = nullptr,
QString  name = QString("Cone"),
unsigned  precision = DEFAULT_DRAWING_PRECISION,
Cone axis corresponds to the 'Z' dimension by default
bottomRadiuscone bottom radius
topRadiuscone top radius
heightcone height (transformation should point to the axis center)
xOffdisplacement of axes along X-axis (Snout mode)
yOffdisplacement of axes along Y-axis (Snout mode)
namename
precisiondrawing precision (angular step = 360/precision)
◆ ccCone() [2/2]
ccCone::ccCone ( QString  name = QString("Cone"))
Simplified constructor.
For ccHObject factory only!
Member Function Documentation
◆ buildUp()
bool ccCone::buildUp ( )
overrideprotectedvirtual
Builds primitive.
Returns
success
Implements ccGenericPrimitive.
◆ clone()
ccGenericPrimitive * ccCone::clone ( ) const
overridevirtual
Clones primitive.
Reimplemented in ccCylinder.
◆ fromFile_MeOnly()
bool ccCone::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap oldToNewIDMap
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccHObject.
◆ getClassID()
virtual CC_CLASS_ENUM ccCone::getClassID ( ) const
inlineoverridevirtual
Returns class ID.
Implements ccObject.
◆ getTypeName()
virtual QString ccCone::getTypeName ( ) const
◆ hasDrawingPrecision()
virtual bool ccCone::hasDrawingPrecision ( ) const
Whether drawing is dependent on 'precision' parameter.
Reimplemented from ccGenericPrimitive.
◆ setBottomRadius()
void ccCone::setBottomRadius ( PointCoordinateType  radius)
virtual
Sets bottom radius.
Warning
changes primitive content (calls ccGenericPrimitive::updateRepresentation)
◆ setHeight()
void ccCone::setHeight ( PointCoordinateType  height)
Sets height.
Warning
◆ setTopRadius()
void ccCone::setTopRadius ( PointCoordinateType  radius)
virtual
Sets top radius.
Warning
◆ toFile_MeOnly()
bool ccCone::toFile_MeOnly ( QFile &  out) const
Member Data Documentation
◆ DEFAULT_DRAWING_PRECISION
const unsigned ccCone::DEFAULT_DRAWING_PRECISION = 24
static
Warning
Never pass a 'constant initializer' by reference
