ccCylinder Class Reference
Cylinder (primitive) More...
#include <ccCylinder.h>
Inheritance diagram for ccCylinder:
Inheritance graph
Collaboration diagram for ccCylinder:
 ccCylinder (PointCoordinateType radius, PointCoordinateType height, const ccGLMatrix *transMat=0, QString name=QString("Cylinder"), unsigned precision=24)
 Default constructor. More...
 ccCylinder (QString name=QString("Cylinder"))
 Returns class ID.
virtual QString getTypeName () const
virtual ccGenericPrimitiveclone () const
 Clones primitive.
- Public Member Functions inherited from ccCone
 ccCone (PointCoordinateType bottomRadius, PointCoordinateType topRadius, PointCoordinateType height, PointCoordinateType xOff=0, PointCoordinateType yOff=0, const ccGLMatrix *transMat=0, QString name=QString("Cone"), unsigned precision=24)
 ccCone (QString name=QString("Cone"))
 Whether drawing is dependent on 'precision' parameter.
 ccGenericPrimitive (QString name=QString(), const ccGLMatrix *transMat=0)
virtual void setColor (const colorType *col)
const ccGenericPrimitiveoperator+= (const ccGenericPrimitive &prim)
 Add operator. More...
virtual ccGLMatrixgetTransformation ()
virtual const ccGLMatrixgetTransformation () const
 ccMesh (ccGenericPointCloud *vertices)
 ccMesh (CCLib::GenericIndexedMesh *giMesh, ccGenericPointCloud *giVertices)
 ccMesh constructor (from a CCLib::GenericIndexedMesh) More...
virtual ~ccMesh ()
 Default destructor.
virtual void setAssociatedCloud (ccGenericPointCloud *cloud)
virtual ccMeshclone (ccGenericPointCloud *vertices=0, ccMaterialSet *clonedMaterials=0, NormsIndexesTableType *clonedNormsTable=0, TextureCoordsContainer *cloneTexCoords=0)
 Clones this entity. More...
virtual ccGenericPointCloudgetAssociatedCloud () const
 Returns the vertices cloud.
virtual void refreshBB ()
 Forces bounding-box update.
virtual bool interpolateNormals (unsigned triIndex, const CCVector3 &P, CCVector3 &N)
virtual bool interpolateColors (unsigned triIndex, const CCVector3 &P, colorType rgb[])
virtual bool getColorFromMaterial (unsigned triIndex, const CCVector3 &P, colorType rgb[], bool interpolateColorIfNoTexture)
virtual bool getVertexColorFromMaterial (unsigned triIndex, unsigned char vertIndex, colorType rgb[], bool returnColorIfNoTexture)
virtual unsigned maxSize () const
 Returns max capacity.
virtual void forEach (genericTriangleAction &anAction)
virtual void placeIteratorAtBegining ()
virtual CCLib::GenericTriangle * _getNextTriangle ()
virtual CCLib::GenericTriangle * _getTriangle (unsigned triangleIndex)
virtual
CCLib::TriangleSummitsIndexes *
getNextTriangleIndexes ()
virtual
getTriangleIndexes (unsigned triangleIndex)
virtual void getTriangleSummits (unsigned triangleIndex, CCVector3 &A, CCVector3 &B, CCVector3 &C)
virtual unsigned size () const
virtual void getBoundingBox (PointCoordinateType bbMin[], PointCoordinateType bbMax[])
virtual const
getTriangleIndexes (unsigned triangleIndex) const
virtual ccBBox getMyOwnBB ()
 Sets associated GL display.
virtual void shiftTriangleIndexes (unsigned shift)
bool reserve (unsigned n)
bool resize (unsigned n)
virtual bool hasTriNormals () const
virtual void getTriangleNormalIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const
virtual bool getTriangleNormals (unsigned triangleIndex, CCVector3 &Na, CCVector3 &Nb, CCVector3 &Nc) const
virtual NormsIndexesTableTypegetTriNormsTable () const
virtual void setTriNormsTable (NormsIndexesTableType *triNormsTable, bool autoReleaseOldTable=true)
virtual void clearTriNormals ()
 Removes per-triangle normals.
virtual bool hasMaterials () const
virtual const ccMaterialSetgetMaterialSet () const
virtual int getTriangleMtlIndex (unsigned triangleIndex) const
virtual bool convertMaterialsToVertexColors ()
virtual void setMaterialSet (ccMaterialSet *materialSet, bool autoReleaseOldMaterialSet=true)
virtual bool hasTextures () const
virtual TextureCoordsContainergetTexCoordinatesTable () const
virtual void getTriangleTexCoordinates (unsigned triIndex, float *&tx1, float *&tx2, float *&tx3) const
virtual bool hasPerTriangleTexCoordIndexes () const
virtual void getTriangleTexCoordinatesIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const
virtual void setTexCoordinatesTable (TextureCoordsContainer *texCoordsTable, bool autoReleaseOldTable=true)
virtual bool computeNormals (bool perVertex)
 Computes normals. More...
virtual bool computePerVertexNormals ()
virtual bool computePerTriangleNormals ()
bool laplacianSmooth (unsigned nbIteration=100, PointCoordinateType factor=static_cast< PointCoordinateType >(0.01), CCLib::GenericProgressCallback *progressCb=0)
 Laplacian smoothing. More...
virtual ccMeshcreateNewMeshFromSelection (bool removeSelectedFaces)
 Swaps two triangles. More...
virtual ~ccGenericMesh ()
 Destructor.
 Sets normals visibility.
 Enables polygon stippling.
 Samples points on a mesh.
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
virtual void redrawDisplay ()
Additional Inherited Members
enum  MESH_SCALAR_FIELD_PROCESS { SMOOTH_MESH_SF, ENHANCE_MESH_SF }
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
typedef GenericChunkedArray
< 3, unsigned >
triangleIndexesContainer
< 1, int >
triangleMaterialIndexesSet
< 3, int >
triangleTexCoordIndexesSet
< 3, int >
triangleNormalsIndexesSet
- Protected Member Functions inherited from ccCone
 Save own object data. More...
virtual bool buildUp ()
 Builds primitive. More...
 Inherited from ccGenericMesh.
ccGenericPrimitivefinishCloneJob (ccGenericPrimitive *primitive) const
ccPointCloudvertices ()
 Returns vertices.
bool interpolateNormals (unsigned i1, unsigned i2, unsigned i3, const CCVector3 &P, CCVector3 &N, const int *triNormIndexes=0)
bool interpolateColors (unsigned i1, unsigned i2, unsigned i3, const CCVector3 &P, colorType rgb[])
 ccMesh_extended_call1 (showNormals, bool, showNormals_extended)
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
- Protected Attributes inherited from ccCone
PointCoordinateType m_bottomRadius
 Bottom radius.
PointCoordinateType m_topRadius
 Top radius.
PointCoordinateType m_xOff
 Displacement of axes along X-axis (Snout mode)
PointCoordinateType m_yOff
 Displacement of axes along Y-axis (Snout mode)
PointCoordinateType m_height
 Height.
ccGLMatrix m_transformation
unsigned m_drawPrecision
ccGenericPointCloudm_associatedCloud
 associated cloud (vertices)
NormsIndexesTableTypem_triNormals
 Per-triangle normals.
 Texture coordinates.
ccMaterialSetm_materials
 Materials.
unsigned m_globalIterator
 Iterator on the list of triangle summits indexes.
CCLib::SimpleRefTriangle m_currentTriangle
ccBBox m_bBox
 Bounding-box.
bool m_triNormsShown
bool m_materialsShown
bool m_showWired
 Wireframe display mode.
bool m_stippling
 Polygon stippling state.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
3D cylinder primitive
ccCylinder::ccCylinder ( PointCoordinateType  radius,
const ccGLMatrix transMat = 0,
QString  name = QString("Cylinder"),
unsigned  precision = 24
Cylinder axis corresponds to the 'Z' dimension. Internally represented by a cone with the same top and bottom radius.
radiuscylinder radius
heightcylinder height (transformation should point to the axis center)
namename
precisiondrawing precision (angular step = 360/precision)
ccCylinder::ccCylinder ( QString  name = QString("Cylinder"))
Simplified constructor.
For ccHObject factory only!
