Public Member Functions | Protected Attributes | List of all members
ccDrawableObject Class Referenceabstract
Generic interface for (3D) drawable entities. More...
#include <ccDrawableObject.h>
Inheritance diagram for ccDrawableObject:
Inheritance graph
Collaboration diagram for ccDrawableObject:
 ccDrawableObject ()
 Default constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
virtual ccBBox getBB (bool relative=true, bool withGLfeatures=false, const ccGenericGLDisplay *window=0)=0
 Returns bounding-box. More...
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Member Function Documentation
void ccDrawableObject::enableGLTransformation ( bool  state)
virtual
Enables/disables associated GL transformation.
See ccDrawableObject::setGLTransformation.
virtual ccBBox ccDrawableObject::getBB ( bool  relative = true,
bool  withGLfeatures = false,
const ccGenericGLDisplay window = 0
pure virtual
If bbox is not relative, any active GL transformation (see setGLTransformation) will be applied to it. Moreover, one can compute a full bounding box, taking into acount every children, or only the ones displayed in a given GL window. Eventualy, one can also choose to compute bbox only with geometrical entities, or also with full GL features.
relativespecifies whether bbox is relative or not
withGLfeaturesinclude GL features (example: octree grid display) inside BB or not
windowdisplay to compute bbox only with entities displayed in a given GL window
Returns
bounding-box
Implemented in ccHObject.
void ccDrawableObject::getDrawingParameters ( glDrawParams params) const
virtual
These parameters are deduced from the visiblity states of its different features (points, normals, etc.).
paramsa glDrawParams structure
Reimplemented in ccPointCloud.
ccBBox ccDrawableObject::getFitBB ( ccGLMatrix trans)
virtual
Returns best-fit bounding-box (if available)
WARNING: This method is not supported by all entities! Should be re-implemented whenever possible (returns the axis-aligned bounding-box by default).
[out]transassociated transformation (so that the bounding-box can be displayed in the right position!)
Returns
fit bounding-box
Reimplemented in ccQuadric, and ccPlane.
const ccGLMatrix & ccDrawableObject::getGLTransformation ( ) const
virtual
bool ccDrawableObject::hasScalarFields ( ) const
virtual
Returns whether one or more scalar fields are instantiated.
WARNING: doesn't mean a scalar field is currently displayed (see ccDrawableObject::hasDisplayedScalarField).
Reimplemented in ccPointCloud, ccMesh, and ccSubMesh.
bool ccDrawableObject::isColorOverriden ( ) const
virtual
See ccDrawableObject::setTempColor.
void ccDrawableObject::lockVisibility ( bool  state)
virtual
If visibility is locked, the user won't be able to modify it (via the properties tree for instance).
void ccDrawableObject::prepareDisplayForRefresh ( )
virtual
Sets associated GL display 'refreshable' before global refresh.
Only tagged displays will be refreshed when ccGenericGLDisplay::refresh is called (see also MainWindow::RefreshAllGLWindow, MainWindow::refreshAll and ccDrawableObject::refreshDisplay).
void ccDrawableObject::refreshDisplay ( )
virtual
Refreshes associated GL display.
See ccGenericGLDisplay::refresh.
void ccDrawableObject::resetGLTransformation ( )
virtual
Resets associated GL transformation.
GL transformation is reset to identity. Note: GL transformation is automatically disabled. See ccDrawableObject::setGLTransformation.
void ccDrawableObject::rotateGL ( const ccGLMatrix rotMat)
virtual
'GLtrans = M * GLtrans' Note: GL transformation is automatically enabled. See ccDrawableObject::setGLTransformation.
void ccDrawableObject::setGLTransformation ( const ccGLMatrix trans)
virtual
Associates entity with a GL transformation (rotation + translation)
WARNING: FOR DISPLAY PURPOSE ONLY (i.e. should only be temporary) If the associated GL transformation is enabled (see ccDrawableObject::enableGLTransformation), it will be applied before displaying this entity. It will also be taken into account during computation of a non-relative bounding-box (see ccDrawableObject::getBB). However it will not be taken into account by any CCLib algorithm (distance computation, etc.) for instance. Note: GL transformation is automatically enabled.
void ccDrawableObject::setTempColor ( const colorType *  col,
bool  autoActivate = true
virtual
Sets current temporary (unique)
colrgb color
autoActivateauto activates temporary color
void ccDrawableObject::translateGL ( const CCVector3 &  trans)
virtual
Translates current GL transformation by a rotation matrix.
'GLtrans = GLtrans + T' Note: GL transformation is automatically enabled. See ccDrawableObject::setGLTransformation.
Member Data Documentation
ccGLMatrix ccDrawableObject::m_glTrans
protected
Current GL transformation.
bool ccDrawableObject::m_glTransEnabled
protected
Current GL transformation activation state.
bool ccDrawableObject::m_visible
protected
Specifies whether the object is visible or not.
Note: this does not influence the children visibility
