Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ccFacet Class Reference
Facet. More...
#include <ccFacet.h>
Inheritance diagram for ccFacet:
Inheritance graph
Collaboration diagram for ccFacet:
 ccFacet (PointCoordinateType maxEdgeLength=0, QString name=QString("Facet"))
 Default constructor. More...
virtual ~ccFacet ()
 Destructor.
 Returns class ID.
void setColor (const colorType rgb[])
 Sets the facet unique color. More...
double getRMS () const
 Returns associated RMS.
double getSurface () const
 Returns associated surface.
const PointCoordinateType * getPlaneEquation () const
 Returns plane equation.
CCVector3 getNormal () const
 Returns normal.
void invertNormal ()
 Inverts normal.
const CCVector3 & getCenter () const
 Returns center.
ccMeshgetPolygon ()
 Returns polygon mesh (if any)
ccPolylinegetContour ()
 Returns contour polyline (if any)
ccPointCloudgetContourVertices ()
 Returns contour vertices (if any)
ccPointCloudgetOriginPoints ()
 Returns origin points (if any)
void setPolygon (ccMesh *mesh)
 Sets polygon mesh.
void setContour (ccPolyline *poly)
 Sets contour polyline.
void setContourVertices (ccPointCloud *cloud)
 Sets contour vertices.
void setOriginPoints (ccPointCloud *cloud)
 Sets origin points.
void showNormalVector (bool state)
 Show normal vector.
bool normalVectorIsShown () const
 Whether normal vector is shown or not.
ccFacetclone () const
 Clones this facet.
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
virtual ccBBox getMyOwnBB ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
static ccFacetCreate (CCLib::GenericIndexedCloudPersist *cloud, PointCoordinateType maxEdgeLength=0, bool transferOwnership=false, const PointCoordinateType *planeEquation=0)
 Creates a facet from a set of points. More...
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
void drawMeOnly (CC_DRAW_CONTEXT &context)
bool createInternalRepresentation (CCLib::GenericIndexedCloudPersist *points, const PointCoordinateType *planeEquation=0)
 Creates internal representation (polygon, polyline, etc.)
 Save own object data. More...
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
ccMeshm_polygonMesh
 Facet.
ccPolylinem_contourPolyline
 Facet contour.
ccPointCloudm_contourVertices
 Shared vertices (between polygon and contour)
ccPointCloudm_originPoints
 Origin points.
PointCoordinateType m_planeEquation [4]
 Plane equation.
CCVector3 m_center
 Facet centroid.
double m_rms
 RMS (relatively to m_associatedPoints)
double m_surface
 Surface (m_polygon)
PointCoordinateType m_maxEdgeLength
 Max length.
bool m_showNormalVector
 Whether the facet normal vector should be displayed or not.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
Facet.
Composite object: point cloud + 2D1/2 contour polyline + 2D1/2 surface mesh
ccFacet::ccFacet ( PointCoordinateType  maxEdgeLength = 0,
QString  name = QString("Facet")
maxEdgeLengthmax edge length (if possible - ignored if 0)
namename
Member Function Documentation
ccFacet * ccFacet::Create ( CCLib::GenericIndexedCloudPersist *  cloud,
bool  transferOwnership = false,
const PointCoordinateType *  planeEquation = 0
static
The facet boundary can either be the convex hull (maxEdgeLength = 0) or the concave hull (maxEdgeLength > 0).
cloudcloud from which to create the facet
transferOwnershipif true and the input cloud is a ccPointCloud, it will be 'kept' as 'origin points'
planeEquationto input a custom plane equation
Returns
a facet (or 0 if an error occurred)
bool ccFacet::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
protectedvirtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccHObject.
void ccFacet::setColor ( const colorType  rgb[])
rgbRGB color
bool ccFacet::toFile_MeOnly ( QFile &  out) const
protectedvirtual
