CloudCompare 3D entities
Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ccGBLSensor Class Reference
Ground-based Laser sensor. More...
#include <ccGBLSensor.h>
Inheritance diagram for ccGBLSensor:
Inheritance graph
Collaboration diagram for ccGBLSensor:
Public Types
enum  ROTATION_ORDER { YAW_THEN_PITCH = 0 , PITCH_THEN_YAW = 1 }
 The order of inner-rotations of the sensor (body/mirrors) More...
using NormalGrid = std::vector< CCVector3 >
 2D grid of normals
using ColorGrid = std::vector< ccColor::Rgb >
 2D grid of colors
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Shared pointer.
 ccGBLSensor (ROTATION_ORDER rotOrder=YAW_THEN_PITCH)
 Default constructor. More...
 ccGBLSensor (const ccGBLSensor &sensor)
 Copy constructor. More...
 ~ccGBLSensor () override=default
 Destructor.
 Returns class ID. More...
ccBBox getOwnFitBB (ccGLMatrix &trans) override
bool applyViewport (ccGenericGLDisplay *win=nullptr) override
 Apply sensor 'viewport' to a 3D view. More...
unsigned char checkVisibility (const CCVector3 &P) const override
 Determines a 3D point "visibility" relatively to the sensor field of view. More...
bool computeAutoParameters (CCCoreLib::GenericCloud *theCloud)
 Computes angular parameters automatically (all but the angular steps!) More...
void setPitchRange (PointCoordinateType minPhi, PointCoordinateType maxPhi)
 Sets the pitch scanning limits. More...
PointCoordinateType getMinPitch () const
 Returns the minimal pitch limit (in radians)
PointCoordinateType getMaxPitch () const
 Returns the maximal pitch limit (in radians)
void setPitchStep (PointCoordinateType dPhi)
 Sets the pitch step. More...
PointCoordinateType getPitchStep () const
 Returns the lateral pitch step (in radians)
bool pitchIsShifted () const
 Returns whether the pitch angles are shifted (i.e. between [0 ; 2pi] instead of [-pi ; pi])
void setYawRange (PointCoordinateType minTheta, PointCoordinateType maxTheta)
 Sets the yaw scanning limits. More...
PointCoordinateType getMinYaw () const
 Returns the minimal yaw limit (in radians)
PointCoordinateType getMaxYaw () const
 Returns the maximal yaw limit (in radians)
void setYawStep (PointCoordinateType dTheta)
 Sets the yaw step. More...
PointCoordinateType getYawStep () const
 Returns the yaw step (in radians)
bool yawIsShifted () const
 Returns whether the yaw angles are shifted (i.e. between [0 ; 2pi] instead of [-pi ; pi])
PointCoordinateType getSensorRange () const
 Returns the sensor max. range.
void setSensorRange (PointCoordinateType range)
 Sets the sensor max. range. More...
PointCoordinateType getUncertainty () const
 Returns the Z-buffer uncertainty on depth values.
void setUncertainty (PointCoordinateType u)
 Sets the Z-buffer uncertainty on depth values. More...
ROTATION_ORDER getRotationOrder () const
 Returns the sensor internal rotations order.
void setRotationOrder (ROTATION_ORDER rotOrder)
 Sets the sensor internal rotations order. More...
void projectPoint (const CCVector3 &sourcePoint, CCVector2 &destPoint, PointCoordinateType &depth, double posIndex=0) const
 Projects a point in the sensor world. More...
NormalGridprojectNormals (CCCoreLib::GenericCloud *cloud, const NormalGrid &norms, double posIndex=0) const
 Projects a set of point cloud normals in the sensor world. More...
ColorGridprojectColors (CCCoreLib::GenericCloud *cloud, const ColorGrid &rgbColors) const
 Projects a set of point cloud colors in the sensor frame defined by this instance. More...
bool computeDepthBuffer (CCCoreLib::GenericCloud *cloud, int &errorCode, ccPointCloud *projectedCloud=nullptr)
 Projects a point cloud along the sensor point of view defined by this instance. More...
const ccDepthBuffergetDepthBuffer () const
 Returns the associated depth buffer. More...
void clearDepthBuffer ()
 Removes the associated depth buffer.
- Public Member Functions inherited from ccSensor
 ccSensor (const QString &name)
 ccSensor (const ccSensor &sensor)
 Copy constructor.
virtual CC_SENSOR_TYPE getType () const
 Returns the sensor type. More...
virtual unsigned char checkVisibility (const CCVector3 &P) const
 Returns the "visibility type" of a point. More...
ccIndexedTransformationBuffergetPositions ()
 Returns associated positions.
const ccIndexedTransformationBuffergetPositions () const
void setPositions (ccIndexedTransformationBuffer *positions)
 Sets associated positions.
bool addPosition (ccGLMatrix &trans, double index)
 Adds a new position (shortcut) More...
bool getAbsoluteTransformation (ccIndexedTransformation &trans, double index) const
 Returns the absolute transformation between the world and the "optical" center (shortcut) More...
bool getActiveAbsoluteTransformation (ccIndexedTransformation &trans) const
 Gets currently active absolute transformation.
bool getActiveAbsoluteCenter (CCVector3 &vec) const
 Gets currently active absolute position.
bool getActiveAbsoluteRotation (ccGLMatrix &rotation) const
 Gets currently active rotation matrix (without translation)
virtual void setRigidTransformation (const ccGLMatrix &mat)
 Sets the rigid transformation between this sensor and its associated positions. More...
virtual ccGLMatrixgetRigidTransformation ()
 Returns the rigid transformation between this sensor and its associated positions.
virtual const ccGLMatrixgetRigidTransformation () const
 Returns the rigid transformation between this sensor and its associated positions (const version)
void getIndexBounds (double &minIndex, double &maxIndex) const
 Gets index boundaries (shortcut)
double getActiveIndex () const
 Sets currently active index (displayed position, etc.)
void setActiveIndex (double index)
void setGraphicScale (PointCoordinateType scale)
 Sets the sensor graphic representation scale.
PointCoordinateType getGraphicScale () const
 Returns the sensor graphic representation scale.
virtual bool applyViewport (ccGenericGLDisplay *win=nullptr)
 Copy constructor.
 ~ccHObject () override
 Default destructor.
bool isGroup () const
ccHObjectgetParent () const
 Adds a child. More...
void detachAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns selection behavior.
 Copy constructor.
 Returns object name. More...
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Destructor.
 ccDrawableObject ()
 Copy constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Applies a display state.
static QString GetErrorString (int errorCode)
 Returns the error string corresponding to an error code. More...
 Static factory. More...
 Sets the unique ID generator.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
 Save own object data. More...
bool convertToDepthMapCoords (PointCoordinateType yaw, PointCoordinateType pitch, unsigned &i, unsigned &j) const
 Converts 2D angular coordinates (yaw,pitch) in integer depth buffer coordinates.
- Protected Member Functions inherited from ccSensor
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
PointCoordinateType m_phiMin
 Minimal pitch limit (in radians) More...
PointCoordinateType m_phiMax
 Maximal pitch limit (in radians) More...
PointCoordinateType m_deltaPhi
 Pitch step (in radians)
bool m_pitchAnglesAreShifted
 Whether the pitch angular range is shifted (i.e in [0 ; 2pi] instead of [-pi ; pi])
PointCoordinateType m_thetaMin
 Minimal yaw limit (in radians) More...
PointCoordinateType m_thetaMax
 Maximal yaw limit (in radians) More...
PointCoordinateType m_deltaTheta
 Yaw step (in radians)
bool m_yawAnglesAreShifted
 Whether the yaw range is shifted (i.e in [0 ; 2pi] instead of [-pi ; pi]))
ROTATION_ORDER m_rotationOrder
 Mirrors rotation order.
PointCoordinateType m_sensorRange
 Sensor max range.
PointCoordinateType m_uncertainty
 Z-buffer uncertainty.
ccDepthBuffer m_depthBuffer
 Associated Z-buffer.
- Protected Attributes inherited from ccSensor
ccIndexedTransformationBufferm_posBuffer
 Positions buffer (optional)
ccGLMatrix m_rigidTransformation
 Rigid transformation between this sensor and its associated positions. More...
double m_activeIndex
 Active index (for displayed position, etc.)
ccColor::Rgb m_color
 Color of the sensor. More...
PointCoordinateType m_scale
 Sensor graphic representation scale.
ccHObjectm_parent
 Parent.
Container m_children
 Children.
 Selection behavior.
 Dependencies map. More...
ccGLMatrix m_glTransHistory
bool m_isDeleting
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
ccColor::Rgba m_tempColor
 Temporary (unique) color.
bool m_colorIsOverridden
bool m_glTransEnabled
bool m_showNameIn3D
CCVector3d m_nameIn3DPos
bool m_nameIn3DPosIsValid
ccClipPlaneSet m_clipPlanes
Additional Inherited Members
An implementation of the ccSensor interface that can be used to represent a depth sensor relying on 2 rotations relatively to two perpendicular axes, such as ground based laser scanners typically.
Member Enumeration Documentation
◆ ROTATION_ORDER
Either the first rotation is made around the Z axis (yaw) then around the lateral axis (pitch) as most scanners do today (Leica, Riegl, Faro, etc.). Otherwise the opposite order is used (as the very old Mensi Soisic).
◆ ccGBLSensor() [1/2]
ccGBLSensor::ccGBLSensor ( ROTATION_ORDER  rotOrder = YAW_THEN_PITCH)
explicit
rotOrderinner rotations order
◆ ccGBLSensor() [2/2]
ccGBLSensor::ccGBLSensor ( const ccGBLSensor sensor)
Copy constructor.
Warning
The depth buffer is not copied!
sensorsensor structure to copy
Member Function Documentation
◆ applyViewport()
bool ccGBLSensor::applyViewport ( ccGenericGLDisplay win = nullptr)
overridevirtual
win3D view to which to apply the sensor viewport (or the associated 'display' if 0)
Returns
success
Reimplemented from ccSensor.
◆ checkVisibility()
unsigned char ccGBLSensor::checkVisibility ( const CCVector3 &  P) const
overridevirtual
Relies on the sensor associated depth map (see ccGBLSensor::computeDepthBuffer). The depth map is used to determine the "visibility" of a 3D point relatively to the laser scanner field of view. This can be useful for filtering out points that shouldn't be compared while computing the distances between two point clouds for instance (for more information on this particular topic, refer to Daniel Girardeau-Montaut's PhD manuscript - Chapter 2, section 2.3.3).
Pthe point to test
Returns
the point's visibility (POINT_VISIBLE, POINT_HIDDEN, POINT_OUT_OF_RANGE or POINT_OUT_OF_FOV)
◆ computeAutoParameters()
bool ccGBLSensor::computeAutoParameters ( CCCoreLib::GenericCloud *  theCloud)
Warning
this method uses the cloud global iterator.
◆ computeDepthBuffer()
bool ccGBLSensor::computeDepthBuffer ( CCCoreLib::GenericCloud *  cloud,
int &  errorCode,
ccPointCloud projectedCloud = nullptr
Warning
clouda point cloud
errorCodeerror code in case the returned cloud is 0
projectedCloudoptional (empty) cloud to store the projected points
Returns
whether the depth buffer was successfully created or not
◆ drawMeOnly()
void ccGBLSensor::drawMeOnly ( CC_DRAW_CONTEXT context)
overrideprotectedvirtual
Reimplemented from ccHObject.
◆ fromFile_MeOnly()
bool ccGBLSensor::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap oldToNewIDMap
Loads own object data.
ininput file
dataVersionfile version
◆ getClassID()
CC_CLASS_ENUM ccGBLSensor::getClassID ( ) const
inlineoverridevirtual
Returns class ID.
Implements ccObject.
◆ getDepthBuffer()
const ccDepthBuffer & ccGBLSensor::getDepthBuffer ( ) const
inline
Call ccGBLSensor::computeDepthBuffer first otherwise the returned buffer will be 0.
◆ GetErrorString()
QString ccGBLSensor::GetErrorString ( int  errorCode)
static
Errors codes are returned by ccGBLSensor::computeDepthBuffer or ccDepthBuffer::fillHoles for instance.
◆ getOwnBB()
ccBBox ccGBLSensor::getOwnBB ( bool  withGLFeatures = false)
overridevirtual
Returns
bounding-box
◆ getOwnFitBB()
ccBBox ccGBLSensor::getOwnFitBB ( ccGLMatrix trans)
overridevirtual
Returns best-fit bounding-box (if available)
Warning
Only suitable for leaf objects (i.e. without children) Therefore children bboxes are always ignored.
This method is not supported by all entities! (returns the axis-aligned bounding-box by default).
[out]transassociated transformation (so that the bounding-box can be displayed in the right position!)
Returns
fit bounding-box
◆ isSerializable()
bool ccGBLSensor::isSerializable ( ) const
◆ projectColors()
ccGBLSensor::ColorGrid * ccGBLSensor::projectColors ( CCCoreLib::GenericCloud *  cloud,
const ColorGrid rgbColors
) const
Warning
clouda point cloud
rgbColorsthe RGB colors (should have the same size and order as the point cloud)
Returns
a set of RGB colors organized as a bidimensional grid (same size as the depth buffer)
◆ projectNormals()
ccGBLSensor::NormalGrid * ccGBLSensor::projectNormals ( CCCoreLib::GenericCloud *  cloud,
const NormalGrid norms,
double  posIndex = 0
) const
Warning
clouda point cloud
normsthe normals vectors (should have the same size and order as the point cloud)
posIndex(optional) sensor position index (see ccIndexedTransformationBuffer)
Returns
a bidimensional array of 3D vectors (same size as the depth buffer)
◆ projectPoint()
void ccGBLSensor::projectPoint ( const CCVector3 &  sourcePoint,
CCVector2 &  destPoint,
PointCoordinateType &  depth,
double  posIndex = 0
) const
[in]sourcePoint3D point to project
[out]destPointprojected point in polar coordinates: (theta,phi) = (yaw,pitch) (angles between [-pi,+pi] or [0 ; 2pi] if the corresponding angle is 'shifted')
[out]depthdistance between the sensor optical center and the 3D point
[in]posIndex(optional) sensor position index (see ccIndexedTransformationBuffer)
◆ setPitchRange()
void ccGBLSensor::setPitchRange ( PointCoordinateType  minPhi,
minPhimin pitch angle (in radians)
maxPhimax pitch angle (in radians)
◆ setPitchStep()
void ccGBLSensor::setPitchStep ( PointCoordinateType  dPhi)
dPhipitch step (in radians)
◆ setRotationOrder()
void ccGBLSensor::setRotationOrder ( ROTATION_ORDER  rotOrder)
inline
rotOrderinternal rotations order
◆ setSensorRange()
void ccGBLSensor::setSensorRange ( PointCoordinateType  range)
inline
rangemax. range of the sensor
◆ setUncertainty()
void ccGBLSensor::setUncertainty ( PointCoordinateType  u)
inline
The uncertainty is used to handle numerical inaccuracies
uthe Z-buffer uncertainty
◆ setYawRange()
void ccGBLSensor::setYawRange ( PointCoordinateType  minTheta,
minThetamin yaw angle (in radians)
maxThetamax yaw angle (in radians)
◆ setYawStep()
void ccGBLSensor::setYawStep ( PointCoordinateType  dTheta)
Sets the yaw step.
dThetayaw step (in radians)
◆ toFile_MeOnly()
bool ccGBLSensor::toFile_MeOnly ( QFile &  out) const
Member Data Documentation
◆ m_phiMax
PointCoordinateType ccGBLSensor::m_phiMax
protected
Phi = 0 corresponds to the scanner vertical direction (upward)
◆ m_phiMin
PointCoordinateType ccGBLSensor::m_phiMin
protected
◆ m_thetaMax
PointCoordinateType ccGBLSensor::m_thetaMax
protected
Theta = 0 corresponds to the scanner X direction
◆ m_thetaMin
PointCoordinateType ccGBLSensor::m_thetaMin
protected
