Public Member Functions | Static Public Member Functions | Protected Attributes | List of all members
ccGLMatrix Class Reference
A 4x4 'transformation' matrix (column major order) More...
#include <ccGLMatrix.h>
Inheritance diagram for ccGLMatrix:
Inheritance graph
Collaboration diagram for ccGLMatrix:
 ccGLMatrix ()
 Default constructor. More...
 ccGLMatrix (const float *mat16f)
 Constructor from a float GL matrix array. More...
 ccGLMatrix (const double *mat16d)
 Constructor from a double GL matrix array. More...
 ccGLMatrix (const CCVector3 &X, const CCVector3 &Y, const CCVector3 &Z, const CCVector3 &T)
 Constructor from 4 columns (X,Y,Z,T) More...
 ccGLMatrix (const CCLib::SquareMatrix &R, const CCVector3 &T)
 Constructor from a 3x3 rotation matrix R and a vector T.
 ccGLMatrix (const CCLib::SquareMatrix &R, const CCVector3 &T, PointCoordinateType S)
 Constructor from a 3x3 rotation matrix R, a vector T, a scale S.
 ccGLMatrix (const CCLib::SquareMatrix &R, const CCVector3 &T, const CCVector3 &rotCenter)
 Constructor from a rotation center G, a 3x3 rotation matrix R and a vector T.
 ccGLMatrix (const ccGLMatrix &mat)
 Copy constructor.
QString toString (int precision=12, QChar separator= ' ') const
 Returns matrix as a string. More...
ccGLMatrix xRotation () const
 Returns the rotation component around X only.
ccGLMatrix yRotation () const
 Returns the rotation component around Y only.
ccGLMatrix zRotation () const
 Returns the rotation component around Z only.
virtual void toZero ()
 Clears matrix. More...
virtual void toIdentity ()
 Sets matrix to identity.
void clearTranslation ()
 Clears translation. More...
void initFromParameters (PointCoordinateType alpha_rad, const CCVector3 &axis3D, const CCVector3 &t3D)
 Inits transformation from a rotation axis, an angle and a translation. More...
void initFromParameters (PointCoordinateType phi_rad, PointCoordinateType theta_rad, PointCoordinateType psi_rad, const CCVector3 &t3D)
 Inits transformation from 3 rotation angles and a translation. More...
void getParameters (PointCoordinateType &alpha_rad, CCVector3 &axis3D, CCVector3 &t3D) const
 Returns equivalent parameters: a rotation axis, an angle and a translation. More...
void getParameters (PointCoordinateType &phi_rad, PointCoordinateType &theta_rad, PointCoordinateType &psi_rad, CCVector3 &t3D) const
 Returns equivalent parameters: 3 rotation angles and a translation. More...
float * data ()
 Returns a pointer to internal data.
const float * data () const
 Returns a const pointer to internal data.
float * getTranslation ()
 Retruns a pointer to internal translation. More...
const float * getTranslation () const
 Retruns a const pointer to internal translation. More...
CCVector3 getTranslationAsVec3D () const
 Returns a copy of the translation as a CCVector3. More...
void setTranslation (const CCVector3 &T)
 Sets translation. More...
void setTranslation (const float T[3])
float * getColumn (unsigned index)
 Returns a pointer to a given column. More...
const float * getColumn (unsigned index) const
 Returns a const pointer to a given column. More...
CCVector3 getColumnAsVec3D (unsigned index) const
 Returns a copy of a given column as a CCVector3. More...
ccGLMatrix operator* (const ccGLMatrix &mat) const
 Multiplication by a matrix operator.
CCVector3 operator* (const CCVector3 &vec) const
 Multiplication by a vector operator.
ccGLMatrixoperator*= (const ccGLMatrix &mat)
 (in place) Multiplication operator
ccGLMatrixoperator+= (const CCVector3 &T)
 (in place) Translation operator
ccGLMatrixoperator-= (const CCVector3 &T)
void apply (CCVector3 &vec) const
 Applies transformation to a 3D vector (in place) More...
PointCoordinateType applyX (const CCVector3 &vec) const
 Get the resulting transformation along X dimension.
PointCoordinateType applyY (const CCVector3 &vec) const
 Get the resulting transformation along Y dimension.
PointCoordinateType applyZ (const CCVector3 &vec) const
 Get the resulting transformation along Z dimension.
void applyRotation (CCVector3 &vec) const
 Applies rotation only to a 3D vector (in place) More...
void applyRotation (float vec[3]) const
void shiftRotationCenter (const CCVector3 &vec)
 Shifts rotation center. More...
void transpose ()
 Transposes matrix (in place)
ccGLMatrix transposed () const
 Returns transposed matrix.
void invert ()
 Inverts transformation.
ccGLMatrix inverse () const
 Returns inverse transformation.
virtual bool toAsciiFile (const char *filename) const
 Saves matrix to an ASCII file.
virtual bool fomAsciiFile (const char *filename)
 Loads matrix from an ASCII file.
void scale (float coef)
 Scales the whole matrix. More...
void scaleLine (unsigned lineIndex, float coef)
 Scales one line of the matrix. More...
void scaleColumn (unsigned colIndex, float coef)
 Scales one column of the matrix. More...
 Loads data from binay stream. More...
 Desctructor.
static ccGLMatrix Interpolate (PointCoordinateType coef, const ccGLMatrix &glMat1, const ccGLMatrix &glMat2)
 Interpolates two matrices at relative position 'coef'. More...
static ccGLMatrix FromToRotation (const CCVector3 &from, const CCVector3 &to)
 Creates a transformation matrix that rotates a vector to another. More...
static ccGLMatrix FromQuaternion (const float q[])
 Converts a quaternion to a rotation matrix. More...
static ccGLMatrix FromString (QString matText, bool &success)
 Converts a 'text' matrix to a ccGLMatrix. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
float m_mat [OPENGL_MATRIX_SIZE]
 Internal 4x4 GL-style matrix data.
Additional Inherited Members
Transformation (M) is composed by a rotation (R) and a translation (T): M*X = R*X + T
ccGLMatrix::ccGLMatrix ( )
Matrix is set to identity (see toIdentity) by default.
ccGLMatrix::ccGLMatrix ( const float *  mat16f)
mat16fa 16 elements array (column major order)
ccGLMatrix::ccGLMatrix ( const double *  mat16d)
Warning
Will implicitly cast the elements to float!
mat16da 16 elements array (column major order)
ccGLMatrix::ccGLMatrix ( const CCVector3 &  X,
const CCVector3 &  Y,
const CCVector3 &  Z,
const CCVector3 &  T
X3 first elements of the 1st column (last one is 0)
Y3 first elements of the 2nd column (last one is 0)
Z3 first elements of the 3rd column (last one is 0)
T3 first elements of the last column (last one is 1)
Member Function Documentation
void ccGLMatrix::apply ( CCVector3 &  vec) const
inline
Input vector is directly modified after calling this method
void ccGLMatrix::applyRotation ( CCVector3 &  vec) const
inline
void ccGLMatrix::applyRotation ( float  vec[3]) const
inline
Input array is directly modified after calling this method
void ccGLMatrix::clearTranslation ( )
Clears translation.
Translation is set to (0,0,0).
bool ccGLMatrix::fromFile ( QFile &  in,
short  dataVersion,
int  flags
virtual
ininput file (already opened)
dataVersionfile version
Returns
success
Reimplemented in ccIndexedTransformation.
ccGLMatrix ccGLMatrix::FromQuaternion ( const float  q[])
static
qquaternion (4 values: w,x,y,z)
Returns
corresponding rotation matrix
ccGLMatrix ccGLMatrix::FromString ( QString  matText,
bool &  success
static
[in]matTextmatrix text
[out]successwhether input matrix text is valid or not
ccGLMatrix ccGLMatrix::FromToRotation ( const CCVector3 &  from,
const CCVector3 &  to
static
Adapted from "Efficiently Building a Matrix to Rotate One Vector to Another" By Tomas Möller, John Hughes, Journal of Graphics Tools, 4(4):1-4, 1999
fromnormalized non-zero source vector
tonormalized non-zero destination vector
float* ccGLMatrix::getColumn ( unsigned  index)
inline
indexcolumn index (between 0 and 3)
Returns
pointer to the first element of the corresponding column
const float* ccGLMatrix::getColumn ( unsigned  index) const
inline
Returns
CCVector3 ccGLMatrix::getColumnAsVec3D ( unsigned  index) const
inline
4th value is ignored.
Returns
copy of the three first elements of the corresponding column
void ccGLMatrix::getParameters ( PointCoordinateType &  alpha_rad,
CCVector3 &  axis3D,
CCVector3 &  t3D
) const
[out]alpha_radrotation angle (in radians)
[out]axis3Drotation axis
[out]t3Dtranslation
void ccGLMatrix::getParameters ( PointCoordinateType &  phi_rad,
PointCoordinateType &  theta_rad,
PointCoordinateType &  psi_rad,
CCVector3 &  t3D
) const
See http://en.wikipedia.org/wiki/Euler_angles
[out]phi_radPhi angle (in radians)
[out]theta_radTheta angle (in radians)
[out]psi_radPsi angle (in radians)
[out]t3Dtranslation
float* ccGLMatrix::getTranslation ( )
inline
Translation corresponds to the begining of the third column of the matrix.
const float* ccGLMatrix::getTranslation ( ) const
inline
CCVector3 ccGLMatrix::getTranslationAsVec3D ( ) const
inline
Returns
translation vector
void ccGLMatrix::initFromParameters ( PointCoordinateType  alpha_rad,
const CCVector3 &  axis3D,
const CCVector3 &  t3D
[in]alpha_radrotation angle (in radians)
[in]axis3Drotation axis
[in]t3Dtranslation
void ccGLMatrix::initFromParameters ( PointCoordinateType  phi_rad,
[in]phi_radPhi angle (in radians)
[in]theta_radTheta angle (in radians)
[in]psi_radPsi angle (in radians)
[in]t3Dtranslation
ccGLMatrix ccGLMatrix::Interpolate ( PointCoordinateType  coef,
const ccGLMatrix glMat1,
const ccGLMatrix glMat2
static
coefinterpolation position (should be between 0 and 1).
glMat1'left' matrix
glMat2'right' matrix
void ccGLMatrix::scale ( float  coef)
coefscaling coef.
void ccGLMatrix::scaleColumn ( unsigned  colIndex,
float  coef
colIndex(0-3)
coefscaling coef.
void ccGLMatrix::scaleLine ( unsigned  lineIndex,
float  coef
lineIndex(0-3)
coefscaling coef.
void ccGLMatrix::setTranslation ( const CCVector3 &  T)
Sets translation.
T3D vector
void ccGLMatrix::setTranslation ( const float  T[3])
Sets translation.
T3D vector as a float array
void ccGLMatrix::shiftRotationCenter ( const CCVector3 &  vec)
Warning, this method only applies a shift (i.e. relatively to the current rotation center). This is not a way to set an absolute rotation center 'directly'.
bool ccGLMatrix::toFile ( QFile &  out) const
virtual
outoutput file (already opened)
Returns
success
QString ccGLMatrix::toString ( int  precision = 12,
QChar  separator = ' '
) const
precisionnumerical precision
separatorseparator
Returns
string
void ccGLMatrix::toZero ( )
virtual
Clears matrix.
Matrix is set to 0.
