Public Member Functions | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
ccGenericMesh Class Referenceabstract
Generic mesh interface. More...
#include <ccGenericMesh.h>
Inheritance diagram for ccGenericMesh:
Inheritance graph
Collaboration diagram for ccGenericMesh:
 Default constructor. More...
virtual ~ccGenericMesh ()
 Destructor.
 Sets normals visibility.
virtual ccGenericPointCloudgetAssociatedCloud () const =0
 Returns the vertices cloud.
virtual void refreshBB ()=0
 Forces bounding-box update.
virtual unsigned maxSize () const =0
 Returns max capacity.
virtual const ccMaterialSetgetMaterialSet () const =0
virtual TextureCoordsContainergetTexCoordinatesTable () const =0
virtual void getTriangleTexCoordinates (unsigned triIndex, float *&tx1, float *&tx2, float *&tx3) const =0
virtual NormsIndexesTableTypegetTriNormsTable () const =0
virtual bool interpolateNormals (unsigned triIndex, const CCVector3 &P, CCVector3 &N)=0
virtual bool interpolateColors (unsigned triIndex, const CCVector3 &P, colorType rgb[])=0
virtual bool getColorFromMaterial (unsigned triIndex, const CCVector3 &P, colorType rgb[], bool interpolateColorIfNoTexture)=0
virtual bool getVertexColorFromMaterial (unsigned triIndex, unsigned char vertIndex, colorType rgb[], bool returnColorIfNoTexture)=0
 Enables polygon stippling.
 Samples points on a mesh.
virtual ~ccHObject ()
 Default destructor.
 Returns class ID. More...
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
virtual ccBBox getMyOwnBB ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Save own object data. More...
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
bool m_triNormsShown
bool m_materialsShown
bool m_showWired
 Wireframe display mode.
bool m_stippling
 Polygon stippling state.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
ccGenericMesh::ccGenericMesh ( QString  name = QString())
nameobject name
Member Function Documentation
bool ccGenericMesh::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
protectedvirtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccHObject.
Reimplemented in ccMesh, ccSubMesh, ccQuadric, ccPlane, ccGenericPrimitive, ccCone, ccTorus, ccExtru, ccDish, ccSphere, ccBox, and ccMeshGroup.
virtual bool ccGenericMesh::getColorFromMaterial ( unsigned  triIndex,
const CCVector3 &  P,
colorType  rgb[],
pure virtual
Returns RGB color fom a given triangle material/texture.
triIndextriangle index
Ppoint where to grab color (should be inside the triangle!)
[out]rgbtexel color
interpolateColorIfNoTexturewhether to return the color interpolated from the RGB field if no texture/material is associated to the given triangles
Returns
success
Implemented in ccMesh, ccSubMesh, and ccMeshGroup.
virtual void ccGenericMesh::getTriangleNormalIndexes ( unsigned  triangleIndex,
int &  i1,
int &  i2,
int &  i3
) const
pure virtual
Returns a triplet of normal indexes for a given triangle (if any)
[in]triangleIndextriangle index
[out]i1first summit normal index (or -1 if none)
[out]i2second summit normal index (or -1 if none)
[out]i3third summit normal index (or -1 if none)
virtual bool ccGenericMesh::getTriangleNormals ( unsigned  triangleIndex,
CCVector3 &  Na,
CCVector3 &  Nb,
CCVector3 &  Nc
) const
pure virtual
Returns a given triangle normal.
Mesh must have triangle normals associated (see hasTriNormals)
virtual void ccGenericMesh::getTriangleTexCoordinatesIndexes ( unsigned  triangleIndex,
int &  i1,
int &  i2,
int &  i3
) const
pure virtual
Returns the triplet of tex coords indexes for a given triangle.
i1first summit tex coords index
i2second summit tex coords index
i3third summit tex coords index
virtual bool ccGenericMesh::getVertexColorFromMaterial ( unsigned  triIndex,
colorType  rgb[],
pure virtual
Returns RGB color of a vertex fom a given triangle material/texture.
vertIndexvertex index inside triangle (i.e. 0, 1 or 2!)
[out]rgbtexel color
returnColorIfNoTexturewhether to return the color from the vertex RGB field if no texture/material is associated to the given triangle
Returns
success
unsigned * ccGenericMesh::GetWireVertexIndexes ( )
staticprotected
Returns a pre-initialized array of vertex indexes for wired display.
Array size is MAX_NUMBER_OF_ELEMENTS_PER_CHUNK*6 by default
virtual bool ccGenericMesh::interpolateColors ( unsigned  triIndex,
colorType  rgb[]
pure virtual
Interpolates RGB colors inside a given triangle.
Ppoint where to interpolate (should be inside the triangle!)
[out]rgbinterpolated color
Returns
success
virtual bool ccGenericMesh::interpolateNormals ( unsigned  triIndex,
CCVector3 &  N
pure virtual
Interpolates normal(s) inside a given triangle.
[out]Ninterpolated normal
Returns
success
bool ccGenericMesh::toFile_MeOnly ( QFile &  out) const
protectedvirtual
