CloudCompare 3D entities
Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | Friends | List of all members
ccGenericPointCloud Class Referenceabstract
A 3D cloud interface with associated features (color, normals, octree, etc.) More...
#include <ccGenericPointCloud.h>
Inheritance diagram for ccGenericPointCloud:
Inheritance graph
Collaboration diagram for ccGenericPointCloud:
Public Types
using VisibilityTableType = std::vector< unsigned char >
 Array of "visibility" information for each point. More...
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Shared pointer.
 ccGenericPointCloud (QString name=QString(), unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)
 Default constructor. More...
 ccGenericPointCloud (const ccGenericPointCloud &cloud)
 Copy constructor.
 ~ccGenericPointCloud () override
 Default destructor.
virtual ccGenericPointCloudclone (ccGenericPointCloud *destCloud=nullptr, bool ignoreChildren=false)=0
 Clones this entity. More...
virtual void clear ()
 Clears the entity from all its points and features. More...
virtual ccOctree::Shared computeOctree (CCCoreLib::GenericProgressCallback *progressCb=nullptr, bool autoAddChild=true)
 Computes the cloud octree. More...
virtual ccOctree::Shared getOctree () const
 Returns the associated octree (if any)
virtual void setOctree (ccOctree::Shared octree, bool autoAddChild=true)
 Sets the associated octree.
virtual ccOctreeProxygetOctreeProxy () const
 Returns the associated octree proxy (if any)
virtual void deleteOctree ()
 Erases the octree.
virtual const ccColor::RgbgeScalarValueColor (ScalarType d) const =0
 Returns color corresponding to a given scalar value. More...
virtual const ccColor::RgbgetPointScalarValueColor (unsigned pointIndex) const =0
 Returns color corresponding to a given point associated scalar value. More...
virtual ScalarType getPointDisplayedDistance (unsigned pointIndex) const =0
 Returns scalar value associated to a given point. More...
virtual const ccColor::RgbagetPointColor (unsigned pointIndex) const =0
 Returns color corresponding to a given point. More...
virtual const CompressedNormType & getPointNormalIndex (unsigned pointIndex) const =0
 Returns compressed normal corresponding to a given point. More...
virtual const CCVector3 & getPointNormal (unsigned pointIndex) const =0
 Returns normal corresponding to a given point. More...
virtual VisibilityTableTypegetTheVisibilityArray ()
 Returns associated visibility array.
virtual const VisibilityTableTypegetTheVisibilityArray () const
 Returns associated visibility array (const version)
virtual CCCoreLib::ReferenceCloud * getTheVisiblePoints (const VisibilityTableType *visTable=nullptr, bool silent=false) const
 Returns a ReferenceCloud equivalent to the visibility array. More...
virtual bool isVisibilityTableInstantiated () const
 Returns whether the visibility array is allocated or not.
virtual bool resetVisibilityArray ()
 Resets the associated visibility array. More...
virtual void invertVisibilityArray ()
 Inverts the visibility array.
virtual void unallocateVisibilityArray ()
 Erases the points visibility information.
virtual void refreshBB ()=0
 Forces bounding-box update.
virtual ccGenericPointCloudcreateNewCloudFromVisibilitySelection (bool removeSelectedPoints=false, VisibilityTableType *visTable=nullptr, bool silent=false)=0
 Creates a new point cloud with only the 'visible' points (as defined by the visibility array) More...
virtual void applyRigidTransformation (const ccGLMatrix &trans)=0
 Applies a rigid transformation (rotation + translation)
virtual CCCoreLib::ReferenceCloud * crop (const ccBBox &box, bool inside=true)=0
 Crops the cloud inside (or outside) a bounding box. More...
virtual void scale (PointCoordinateType fx, PointCoordinateType fy, PointCoordinateType fz, CCVector3 center=CCVector3(0, 0, 0))=0
 Multiplies all coordinates by constant factors (one per dimension) More...
void setPointSize (unsigned size=0)
 Sets point size. More...
unsigned char getPointSize () const
 Returns current point size. More...
void importParametersFrom (const ccGenericPointCloud *cloud)
 Imports the parameters from another cloud. More...
bool pointPicking (const CCVector2d &clickPos, const ccGLCameraParameters &camera, int &nearestPointIndex, double &nearestSquareDist, double pickWidth=2.0, double pickHeight=2.0, bool autoComputeOctree=false)
 Point picking (brute force or octree-driven) More...
 Copy constructor. More...
bool isShifted () const
template<typename T >
 Copy constructor.
 ~ccHObject () override
 Default destructor.
 Returns class ID. More...
bool isGroup () const
ccHObjectgetParent () const
 Adds a child. More...
void detachAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns selection behavior.
 Copy constructor.
 Returns object name. More...
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Destructor.
 ccDrawableObject ()
 Copy constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Applies a display state.
 Save own object data. More...
 Serialization helper (output)
 Serialization helper (input)
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
VisibilityTableType m_pointsVisibility
 Per-point visibility table. More...
unsigned char m_pointSize
 Point size (won't be applied if 0)
CCVector3d m_globalShift
double m_globalScale
ccHObjectm_parent
 Parent.
Container m_children
 Children.
 Selection behavior.
 Dependencies map. More...
ccGLMatrix m_glTransHistory
bool m_isDeleting
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
ccColor::Rgba m_tempColor
 Temporary (unique) color.
bool m_colorIsOverridden
bool m_glTransEnabled
bool m_showNameIn3D
CCVector3d m_nameIn3DPos
bool m_nameIn3DPosIsValid
ccClipPlaneSet m_clipPlanes
Friends
class ccMesh
Additional Inherited Members
 Static factory. More...
 Sets the unique ID generator.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
A generic point cloud can have multiples features:
Member Typedef Documentation
◆ VisibilityTableType
using ccGenericPointCloud::VisibilityTableType = std::vector<unsigned char>
See <CCConst.h>
◆ ccGenericPointCloud()
ccGenericPointCloud::ccGenericPointCloud ( QString  name = QString(),
namecloud name (optional)
Member Function Documentation
◆ clear()
void ccGenericPointCloud::clear ( )
virtual
Display parameters are also reset to their default values.
◆ clone()
virtual ccGenericPointCloud * ccGenericPointCloud::clone ( ccGenericPointCloud destCloud = nullptr,
bool  ignoreChildren = false
pure virtual
Clones this entity.
All the main features of the entity are cloned, except from the octree and the points visibility information.
destClouddestination cloud can be provided here (must be of the exact same type as the cloned cloud!)
ignoreChildren[optional] whether to ignore the cloud's children or not (in which case they will be cloned as well)
Returns
a copy of this entity
◆ computeOctree()
ccOctree::Shared ccGenericPointCloud::computeOctree ( CCCoreLib::GenericProgressCallback *  progressCb = nullptr,
bool  autoAddChild = true
virtual
The octree bounding-box is automatically defined as the smallest 3D cube that totally encloses the cloud.
Warning
any previously attached octree will be deleted, even if the new octree computation failed.
progressCbthe caller can get some notification of the process progress through this callback mechanism (see CCCoreLib documentation)
autoAddChildwhether to automatically add the computed octree as child of this cloud or not
Returns
the computed octree
◆ createNewCloudFromVisibilitySelection()
virtual ccGenericPointCloud * ccGenericPointCloud::createNewCloudFromVisibilitySelection ( bool  removeSelectedPoints = false,
VisibilityTableType visTable = nullptr,
bool  silent = false
pure virtual
removeSelectedPointsif true, exported point are also removed from the current point cloud
visTablevisibility table (optional, otherwise the cloud's default one will be used)
silentdon't issue a warning message if there's no point to keep
Returns
new point cloud with selected points
◆ crop()
virtual CCCoreLib::ReferenceCloud * ccGenericPointCloud::crop ( const ccBBox box,
bool  inside = true
pure virtual
Warning
Always returns a selection (potentially empty) if successful.
boxcropping box
insidewhether selected points are inside or outside the box
Returns
points falling inside (or outside) as a selection
◆ fromFile_MeOnly()
bool ccGenericPointCloud::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap oldToNewIDMap
overrideprotectedvirtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccHObject.
◆ geScalarValueColor()
virtual const ccColor::Rgb * ccGenericPointCloud::geScalarValueColor ( ScalarType  d) const
pure virtual
The returned value depends on the current scalar field display parameters. It may even be 0 if the value shouldn't be displayed.
Warning
scalar field must be enabled! (see ccDrawableObject::hasDisplayedScalarField)
◆ getOwnBB()
ccBBox ccGenericPointCloud::getOwnBB ( bool  withGLFeatures = false)
overridevirtual
Returns
bounding-box
◆ getPointColor()
virtual const ccColor::Rgba & ccGenericPointCloud::getPointColor ( unsigned  pointIndex) const
pure virtual
Warning
color array must be enabled! (see ccDrawableObject::hasColors)
◆ getPointDisplayedDistance()
virtual ScalarType ccGenericPointCloud::getPointDisplayedDistance ( unsigned  pointIndex) const
pure virtual
The returned value is taken from the current displayed scalar field
Warning
◆ getPointNormal()
virtual const CCVector3 & ccGenericPointCloud::getPointNormal ( unsigned  pointIndex) const
pure virtual
Warning
normals array must be enabled! (see ccDrawableObject::hasNormals)
◆ getPointNormalIndex()
virtual const CompressedNormType & ccGenericPointCloud::getPointNormalIndex ( unsigned  pointIndex) const
pure virtual
Warning
◆ getPointScalarValueColor()
virtual const ccColor::Rgb * ccGenericPointCloud::getPointScalarValueColor ( unsigned  pointIndex) const
pure virtual
Warning
◆ getPointSize()
unsigned char ccGenericPointCloud::getPointSize ( ) const
inline
0 means that the cloud will use current OpenGL value (see glPointSize).
◆ getTheVisiblePoints()
CCCoreLib::ReferenceCloud * ccGenericPointCloud::getTheVisiblePoints ( const VisibilityTableType visTable = nullptr,
bool  silent = false
) const
virtual
silentdon't issue warnings if no visible point is present
Returns
the visible points as a ReferenceCloud
◆ importParametersFrom()
void ccGenericPointCloud::importParametersFrom ( const ccGenericPointCloud cloud)
Only the specific parameters are imported.
◆ isSerializable()
bool ccGenericPointCloud::isSerializable ( ) const
inlineoverridevirtual
◆ pointPicking()
bool ccGenericPointCloud::pointPicking ( const CCVector2d &  clickPos,
const ccGLCameraParameters camera,
int &  nearestPointIndex,
double &  nearestSquareDist,
double  pickWidth = 2.0,
double  pickHeight = 2.0,
bool  autoComputeOctree = false
Warning
the octree-driven method only works if pickWidth == pickHeight
◆ resetVisibilityArray()
bool ccGenericPointCloud::resetVisibilityArray ( )
virtual
Warning: allocates the array if it was not done yet!
◆ scale()
virtual void ccGenericPointCloud::scale ( PointCoordinateType  fx,
CCVector3  center = CCVector3(0, 0, 0)
pure virtual
Warning
attached octree may be deleted.
fxmultiplication factor along the X dimension
fymultiplication factor along the Y dimension
fzmultiplication factor along the Z dimension
centerscaling center (0,0,0) by default
◆ setPointSize()
void ccGenericPointCloud::setPointSize ( unsigned  size = 0)
inline
Sets point size.
Overrides default value one if superior than 0 (see glPointSize).
◆ toFile_MeOnly()
bool ccGenericPointCloud::toFile_MeOnly ( QFile &  out) const
Member Data Documentation
◆ m_pointsVisibility
VisibilityTableType ccGenericPointCloud::m_pointsVisibility
protected
If this table is allocated, only values set to POINT_VISIBLE will be considered as visible/selected.
