ccImage Class Reference
Generic image. More...
#include <ccImage.h>
Inheritance diagram for ccImage:
Inheritance graph
Collaboration diagram for ccImage:
Public Member Functions
 ccImage ()
 Default constructor.
 ccImage (const QImage &image, const QString &name=QString("unknown"))
 Constructor from QImage.
 Returns unique class ID.
bool load (const QString &filename, QString &error)
 Loads image from file. More...
virtual void setImage (const QImage &image)
 Sets image. More...
unsigned getW () const
 Returns image width.
unsigned getH () const
 Returns image height.
virtual void setAlpha (float value)
 Sets image texture transparency.
virtual float getAlpha () const
 Returns image texture transparency.
virtual const QImage & data () const
 Returns coresponding QImage.
void setAspectRatio (float ar)
 Manually sets aspect ratio.
float getAspectRatio () const
 Returns aspect ratio.
 Default constructor. More...
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
virtual ccBBox getMyOwnBB ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
Protected Member Functions
virtual bool unbindTexture ()
 Unbinds texture from currently associated GL context.
virtual bool bindToGlTexture (ccGenericGLDisplay *win, bool pow2Texture=false)
 Binds texture to a GL context (and creates texture if necessary) More...
 Sets parent object.
 Save own object data. More...
 Returns flag state.
 Sets flag state. More...
Protected Attributes
unsigned m_width
 Image width (in pixels)
unsigned m_height
 Image height (in pixels)
float m_aspectRatio
 Aspect ratio w/h. More...
float m_texU
 Texture coordinate (width) of bottom-right pixel.
float m_texV
 Texture coordinate (height) of bottom-right pixel.
float m_texAlpha
 Texture transparency.
unsigned m_textureID
 Texture GL ID.
ccGenericGLDisplaym_boundWin
 Currently bound GL window.
QImage m_image
 Image data.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
Generic image.
Member Function Documentation
bool ccImage::bindToGlTexture ( ccGenericGLDisplay win,
bool  pow2Texture = false
protectedvirtual
win3D display to which to bind the texture
pow2Texturewhether a texture with power of 2 dimensions is requested (OpenGL version < 2.0)
Returns
success
bool ccImage::load ( const QString &  filename,
QString &  error
filenameimage filename
errora human readable description of what went wrong (if method fails)
Returns
success
void ccImage::setImage ( const QImage &  image)
virtual
Sets image.
Returns
success
Member Data Documentation
float ccImage::m_aspectRatio
protected
Aspect ratio w/h.
Default is m_width/m_height. Should be changed if pixels are not square.
