ccIndexedTransformationBuffer Class Reference
Indexed Transformation buffer. More...
#include <ccIndexedTransformationBuffer.h>
Inheritance diagram for ccIndexedTransformationBuffer:
Inheritance graph
Collaboration diagram for ccIndexedTransformationBuffer:
Public Member Functions
 ccIndexedTransformationBuffer (QString name=QString("Trans. buffer"))
 Default constructor.
 Returns class ID. More...
void sort ()
 Sorts transformations based on their index. More...
bool findNearest (double index, const ccIndexedTransformation *&trans1, const ccIndexedTransformation *&trans2, size_t *trans1IndexInBuffer=0, size_t *trans2IndexInBuffer=0) const
 Returns the nearest indexed transformation(s) to a given index. More...
bool getInterpolatedTransformation (double index, ccIndexedTransformation &trans, double maxIndexDistForInterpolation=DBL_MAX) const
 Returns the indexed transformation at a given index (interpolates it if necessary) More...
bool triherdonsShown ()
 [Display option] Returns whether trihedrons should be displayed or not (otherwise only points or a polyline)
void showTriherdons (bool state)
 [Display option] Sets whether trihedrons should be displayed or not (otherwise only points or a polyline)
float triherdonsDisplayScale ()
 [Display option] Returns trihedron display size
void setTriherdonsDisplayScale (float scale)
 [Display option] Sets trihedron display size
bool isPathShonwAsPolyline ()
 [Display option] Returns whether the path should be displayed as a polyline or not (otherwise only points)
void showPathAsPolyline (bool state)
 [Display option] Sets whether the path should be displayed as a polyline or not (otherwise only points)
void invalidateBoundingBox ()
 Invalidates the bounding box. More...
virtual ccBBox getMyOwnBB ()
 Default constructor. More...
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
Protected Member Functions
 Save own object data. More...
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
Protected Attributes
ccBBox m_bBox
 Bounding box.
size_t m_bBoxValidSize
 Bounding box last 'validity' size.
bool m_showAsPolyline
 Whether the path should be displayed as a polyline or not.
bool m_showTrihedrons
 Whether trihedrons should be displayed or not.
float m_trihedronsScale
 Trihedrons display scale.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
Member Function Documentation
bool ccIndexedTransformationBuffer::findNearest ( double  index,
const ccIndexedTransformation *&  trans1,
const ccIndexedTransformation *&  trans2,
size_t *  trans1IndexInBuffer = 0,
size_t *  trans2IndexInBuffer = 0
) const
This method returns the preceding and following transformations.
\warning Binary search: buffer must be sorted! (see ccIndexedTransformationBuffer::sort)
\param index query index (e.g. timestamp)
\param trans1 directly preceding transformation (if any - null otherwise)
\param trans2 directly following transformation (if any - null otherwise)
\param trans1IndexInBuffer (optional) index of trans1 in buffer
\param trans2IndexInBuffer (optional) index of trans2 in buffer
\return success
bool ccIndexedTransformationBuffer::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
protectedvirtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccHObject.
virtual CC_CLASS_ENUM ccIndexedTransformationBuffer::getClassID ( ) const
inlinevirtual
Returns class ID.
Returns
class unique ID
ccBBox ccIndexedTransformationBuffer::getDisplayBB ( )
virtual
Children bboxes are ignored. The bounding-box should take into account entity geometrical data and any other 3D displayed elements.
Returns
bounding-box
bool ccIndexedTransformationBuffer::getInterpolatedTransformation ( double  index,
ccIndexedTransformation trans,
double  maxIndexDistForInterpolation = DBL_MAX
) const
Warning
\param trans output transformation (if successful)
\param maxIndexDistForInterpolation max 'distance' between query index and existing indexes to actually interpolate/output a transformation
\return success
ccBBox ccIndexedTransformationBuffer::getMyOwnBB ( )
virtual
Returns
bounding-box
void ccIndexedTransformationBuffer::invalidateBoundingBox ( )
Should be called whenever the content of this structure changes!
void ccIndexedTransformationBuffer::sort ( )
Ascending sort.
bool ccIndexedTransformationBuffer::toFile_MeOnly ( QFile &  out) const
protectedvirtual
