Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ccKdTree Class Reference
KD-tree structure. More...
#include <ccKdTree.h>
Inheritance diagram for ccKdTree:
Inheritance graph
Collaboration diagram for ccKdTree:
Public Types
typedef std::set< Leaf * > LeafSet
 A set of leaves.
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 ccKdTree (ccGenericPointCloud *aCloud)
 Default constructor. More...
void multiplyBoundingBox (const PointCoordinateType multFactor)
 Multiplies the bounding-box of the tree. More...
void translateBoundingBox (const CCVector3 &T)
 Translates the bounding-box of the tree. More...
 Returns class ID.
virtual ccBBox getMyOwnBB ()
bool convertCellIndexToSF ()
 Flag points with cell index (as a scalar field)
bool convertCellIndexToRandomColor ()
 Flag points with a random color per leaf.
ccBBox getCellBBox (BaseNode *node) const
 Returns the bounding-box of a given cell.
bool getNeighborLeaves (BaseNode *cell, ccKdTree::LeafSet &neighbors, const int *userDataFilter=0)
 Returns the neighbor leaves around a given cell.
ccGenericPointCloudassociatedGenericCloud () const
 Returns associated (generic) point cloud.
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
void drawMeOnly (CC_DRAW_CONTEXT &context)
 Sets parent object.
 Save own object data. More...
 Returns flag state.
 Sets flag state. More...
ccGenericPointCloudm_associatedGenericCloud
 Associated cloud.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
KD-tree structure.
Extends the CCLib::TrueKdTree class.
ccKdTree::ccKdTree ( ccGenericPointCloud aCloud)
aClouda point cloud
Member Function Documentation
ccBBox ccKdTree::getDisplayBB ( )
virtual
Children bboxes are ignored. The bounding-box should take into account entity geometrical data and any other 3D displayed elements.
Returns
bounding-box
Reimplemented from ccHObject.
ccBBox ccKdTree::getMyOwnBB ( )
virtual
Returns
bounding-box
void ccKdTree::multiplyBoundingBox ( const PointCoordinateType  multFactor)
If the cloud coordinates are simply multiplied by the same factor, there is no use to recompute the tree structure. It's sufficient to update its bounding-box.
multFactormultiplication factor
void ccKdTree::translateBoundingBox ( const CCVector3 &  T)
If the cloud has simply been translated, there is no use to recompute the tree structure. It's sufficient to update its bounding-box.
Ttranslation vector
