Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ccMaterialSet Class Reference
Mesh (triangle) material. More...
#include <ccMaterialSet.h>
Inheritance diagram for ccMaterialSet:
Inheritance graph
Collaboration diagram for ccMaterialSet:
 ccMaterialSet (QString name=QString())
 Default constructor.
 Returns class ID. More...
int findMaterial (QString mtlName)
 Finds material by name. More...
bool addMaterial (const ccMaterial &mat)
 Adds a material. More...
bool saveAsMTL (QString path, const QString &baseFilename, QStringList &errors) const
 Saves to an MTL file (+ associated texture images)
void associateTo (ccGenericGLDisplay *display)
 Associates to a given context.
const ccGenericGLDisplaygetAssociatedDisplay ()
 Returns associated display.
ccMaterialSetclone () const
 Clones materials set.
bool append (const ccMaterialSet &source)
 Appends materials from another set.
 Default constructor. More...
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
virtual ccBBox getMyOwnBB ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
static bool ParseMTL (QString path, const QString &filename, ccMaterialSet &materials, QStringList &errors)
 MTL (material) file parser. More...
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
 Save own object data. More...
virtual ~ccMaterialSet ()
 Default destructor (protected: use 'release' instead)
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
ccGenericGLDisplaym_display
 Associated display.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
Member Function Documentation
bool ccMaterialSet::addMaterial ( const ccMaterial mat)
Adds a material.
Ensures unicity of material names.
int ccMaterialSet::findMaterial ( QString  mtlName)
Returns
material index or -1 if not found
bool ccMaterialSet::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
protectedvirtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccHObject.
virtual CC_CLASS_ENUM ccMaterialSet::getClassID ( ) const
inlinevirtual
Returns class ID.
Returns
class unique ID
virtual bool ccMaterialSet::isShareable ( ) const
inlinevirtual
Returns whether object is shareable or not.
If object is father dependent and 'shared', it won't be deleted but 'released' instead.
bool ccMaterialSet::ParseMTL ( QString  path,
const QString &  filename,
ccMaterialSet materials,
QStringList &  errors
static
Inspired from KIXOR.NET "objloader" (http://www.kixor.net/dev/objloader/)
bool ccMaterialSet::toFile_MeOnly ( QFile &  out) const
protectedvirtual
