CloudCompare 3D entities
Public Types | Public Member Functions | Static Public Member Functions | Static Public Attributes | Protected Types | Protected Member Functions | Protected Attributes | List of all members
ccMesh Class Reference
Triangular mesh. More...
#include <ccMesh.h>
Inheritance diagram for ccMesh:
Inheritance graph
Collaboration diagram for ccMesh:
Public Types
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Shared pointer.
 ~ccMesh () override
 Default destructor.
 Returns class ID. More...
ccMeshcloneMesh (ccGenericPointCloud *vertices=nullptr, ccMaterialSet *clonedMaterials=nullptr, NormsIndexesTableType *clonedNormsTable=nullptr, TextureCoordsContainer *cloneTexCoords=nullptr)
 Clones this entity. More...
const ccGLMatrixgetGLTransformationHistory () const override
ccGenericPointCloudgetAssociatedCloud () const override
void refreshBB () override
 Returns max capacity. More...
void invertNormals ()
void flipTriangles ()
 Flips the triangle. More...
bool reserve (size_t n)
bool resize (size_t n)
void shrinkToFit ()
 Removes unused capacity.
NormsIndexesTableTypegetTriNormsTable () const override
void clearTriNormals ()
 Removes per-triangle normals.
 Invert per-triangle normals.
const ccMaterialSetgetMaterialSet () const override
const triangleMaterialIndexesSetgetTriangleMtlIndexesTable () const
TextureCoordsContainergetTexCoordinatesTable () const override
 Computes normals. More...
 Laplacian smoothing. More...
ccMeshcreateNewMeshFromSelection (bool removeSelectedFaces)
 Swaps two triangles. More...
 Merges duplicated vertices.
 Default constructor. More...
 Destructor.
virtual ccGenericPointCloudgetAssociatedCloud () const =0
virtual void refreshBB ()=0
virtual const ccMaterialSetgetMaterialSet () const =0
virtual TextureCoordsContainergetTexCoordinatesTable () const =0
virtual NormsIndexesTableTypegetTriNormsTable () const =0
 Enables polygon stippling.
ccPointCloudsamplePoints (bool densityBased, double samplingParameter, bool withNormals, bool withRGB, bool withTexture, CCCoreLib::GenericProgressCallback *pDlg=nullptr)
 Samples points on a mesh.
 Copy constructor. More...
bool isShifted () const
template<typename T >
 Copy constructor.
 ~ccHObject () override
 Default destructor.
bool isGroup () const
ccHObjectgetParent () const
 Adds a child. More...
void detachAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns selection behavior.
 Copy constructor.
 Returns object name. More...
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Destructor.
 ccDrawableObject ()
 Copy constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Applies a display state.
static ccMeshTriangulate (ccGenericPointCloud *cloud, CCCoreLib::TRIANGULATION_TYPES type, bool updateNormals=false, PointCoordinateType maxEdgeLength=0, unsigned char dim=2)
static ccMeshTriangulateTwoPolylines (ccPolyline *p1, ccPolyline *p2, CCVector3 *projectionDir=nullptr)
 Static factory. More...
 Sets the unique ID generator.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
Protected Types
 Save own object data. More...
 Serialization helper (output)
 Serialization helper (input)
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
ccMesh_extended_call1(showNormals, bool, showNormals_extended) protected NormsIndexesTableTypem_triNormals
 Per-triangle normals.
 Texture coordinates.
ccMaterialSetm_materials
 Materials.
unsigned m_globalIterator
ccBBox m_bBox
 Bounding-box.
bool m_triNormsShown
bool m_materialsShown
bool m_showWired
 Wireframe display mode.
bool m_stippling
 Polygon stippling state.
CCVector3d m_globalShift
double m_globalScale
ccHObjectm_parent
 Parent.
Container m_children
 Children.
 Selection behavior.
 Dependencies map. More...
ccGLMatrix m_glTransHistory
bool m_isDeleting
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
ccColor::Rgba m_tempColor
 Temporary (unique) color.
bool m_colorIsOverridden
bool m_glTransEnabled
bool m_showNameIn3D
CCVector3d m_nameIn3DPos
bool m_nameIn3DPosIsValid
ccClipPlaneSet m_clipPlanes
Additional Inherited Members
Triangular mesh.
Member Enumeration Documentation
◆ MESH_SCALAR_FIELD_PROCESS
Mesh scalar field processes.
Enumerator
SMOOTH_MESH_SF
Smooth
ENHANCE_MESH_SF
Enhance
◆ ccMesh() [1/2]
ccMesh::ccMesh ( ccGenericPointCloud vertices,
explicit
Default ccMesh constructor.
verticesthe vertices cloud
◆ ccMesh() [2/2]
ccMesh::ccMesh ( CCCoreLib::GenericIndexedMesh *  giMesh,
ccGenericPointCloud giVertices
explicit
ccMesh constructor (from a CCCoreLib::GenericIndexedMesh)
The GenericIndexedMesh should refer to a known ccGenericPointCloud.
giMeshthe GenericIndexedMesh
giVerticesgiMesh vertices
Member Function Documentation
◆ addTriangle()
void ccMesh::addTriangle ( unsigned  i1,
unsigned  i2,
unsigned  i3
Adds a triangle to the mesh.
Warning
Bounding-box validity is broken after a call to this method. However, for the sake of performance, no call to notifyGeometryUpdate is made automatically. Make sure to do so when all modifications are done!
i1first vertex index (relatively to the vertex cloud)
i2second vertex index (relatively to the vertex cloud)
i3third vertex index (relatively to the vertex cloud)
◆ addTriangleMtlIndex()
void ccMesh::addTriangleMtlIndex ( int  mtlIndex)
Adds triangle material index for next triangle.
Cf. ccMesh::reservePerTriangleMtlIndexes.
mtlIndextriangle material index
◆ addTriangleNormalIndexes()
void ccMesh::addTriangleNormalIndexes ( int  i1,
int  i2,
int  i3
Adds a triplet of normal indexes for next triangle.
Make sure per-triangle normal indexes array is allocated (see reservePerTriangleNormalIndexes)
i1first vertex normal index
i2second vertex normal index
i3third vertex normal index
◆ addTriangleTexCoordIndexes()
void ccMesh::addTriangleTexCoordIndexes ( int  i1,
int  i2,
int  i3
Adds a triplet of tex coords indexes for next triangle.
Make sure per-triangle tex coords indexes array is allocated (see reservePerTriangleTexCoordIndexes)
i1first vertex tex coords index
i2second vertex tex coords index
i3third vertex tex coords index
◆ applyGLTransformation()
void ccMesh::applyGLTransformation ( const ccGLMatrix trans)
overrideprotectedvirtual
Applies a GL transformation to the entity.
this = rotMat*(this-rotCenter)+(rotCenter+trans)
transa ccGLMatrix structure
Reimplemented from ccHObject.
◆ arePerTriangleNormalsEnabled()
bool ccMesh::arePerTriangleNormalsEnabled ( ) const
Returns whether per triangle normals are enabled.
To enable per triangle normals, you should:
  • first, reserve memory for triangles (this is always the first thing to do)
  • associate this mesh to a triangle normals array (see ccMesh::setTriNormsTable)
  • reserve memory to store per-triangle normal indexes with ccMesh::reservePerTriangleNormalIndexes
  • add for each triangle a triplet of indexes (referring to stored normals)
◆ capacity()
unsigned ccMesh::capacity ( ) const
overridevirtual
Implements ccGenericMesh.
◆ cloneMesh()
ccMesh * ccMesh::cloneMesh ( ccGenericPointCloud vertices = nullptr,
ccMaterialSet clonedMaterials = nullptr,
NormsIndexesTableType clonedNormsTable = nullptr,
TextureCoordsContainer cloneTexCoords = nullptr
Clones this entity.
All the main features of the entity are cloned, except from the octree
verticesvertices set to use (will be automatically - AND OPTIMALLY - cloned if nullptr)
clonedMaterialsfor internal use
clonedNormsTablefor internal use
cloneTexCoordsfor internal use
Returns
a copy of this entity
◆ computeInterpolationWeights()
void ccMesh::computeInterpolationWeights ( unsigned  triIndex,
const CCVector3 &  P,
CCVector3d &  weights
) const
overridevirtual
Returns the (barycentric) interpolation weights for a given triangle.
Reimplemented from ccGenericMesh.
◆ computeNormals()
bool ccMesh::computeNormals ( bool  perVertex)
Computes normals.
perVertexwhether normals should be computed per-vertex or per-triangle
Returns
success
◆ computePerVertexNormals()
bool ccMesh::computePerVertexNormals ( )
Computes per-vertex normals.
normalsWereAllocated &&
◆ convertMaterialsToVertexColors()
bool ccMesh::convertMaterialsToVertexColors ( )
Converts materials to vertex colors.
Warning: this method will overwrite colors (if any)
◆ createNewMeshFromSelection()
ccMesh * ccMesh::createNewMeshFromSelection ( bool  removeSelectedFaces)
Creates a new mesh with the selected vertices only.
This method is called after a graphical segmentation. It creates a new mesh structure with the vertices that are tagged as "visible" (see ccGenericPointCloud::visibilityArray). This method will also update this mesh if removeSelectedFaces is true. In this case, all "selected" triangles will be removed from this mesh's instance.
removeSelectedFacesspecifies if the faces composed only of 'selected' vertices should be removed or not
◆ drawMeOnly()
void ccMesh::drawMeOnly ( CC_DRAW_CONTEXT context)
Reimplemented in ccPlane.
◆ flipTriangles()
void ccMesh::flipTriangles ( )
Flips the triangle.
Swaps the second and third vertices indexes
◆ fromFile_MeOnly()
bool ccMesh::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap oldToNewIDMap
Loads own object data.
ininput file
dataVersionfile version
Reimplemented in ccPlane, ccQuadric, ccSphere, and ccTorus.
◆ getAssociatedCloud()
ccGenericPointCloud * ccMesh::getAssociatedCloud ( ) const
inlineoverridevirtual
Returns the vertices cloud.
◆ getClassID()
CC_CLASS_ENUM ccMesh::getClassID ( ) const
Returns class ID.
◆ getColorFromMaterial()
bool ccMesh::getColorFromMaterial ( unsigned  triIndex,
ccColor::Rgba color,
bool  interpolateColorIfNoTexture
overridevirtual
Returns RGB color fom a given triangle material/texture.
triIndextriangle index
Ppoint where to grab color (should be inside the triangle!)
[out]colortexel color
interpolateColorIfNoTexturewhether to return the color interpolated from the RGB field if no texture/material is associated to the given triangles
Returns
success
◆ getGLTransformationHistory()
const ccGLMatrix & ccMesh::getGLTransformationHistory ( ) const
overridevirtual
Returns the transformation 'history' matrix.
◆ getMaterialSet()
const ccMaterialSet * ccMesh::getMaterialSet ( ) const
◆ getOwnBB()
ccBBox ccMesh::getOwnBB ( bool  withGLFeatures = false)
overridevirtual
Returns
bounding-box
◆ getTexCoordinatesTable()
TextureCoordsContainer * ccMesh::getTexCoordinatesTable ( ) const
◆ getTriangleMtlIndex()
int ccMesh::getTriangleMtlIndex ( unsigned  triangleIndex) const
overridevirtual
◆ getTriangleNormalIndexes()
void ccMesh::getTriangleNormalIndexes ( unsigned  triangleIndex,
int &  i1,
int &  i2,
int &  i3
) const
overridevirtual
Returns a triplet of normal indexes for a given triangle (if any)
[in]triangleIndextriangle index
[out]i1first vertex normal index (or -1 if none)
[out]i2second vertex normal index (or -1 if none)
[out]i3third vertex normal index (or -1 if none)
◆ getTriangleNormals()
bool ccMesh::getTriangleNormals ( unsigned  triangleIndex,
CCVector3 &  Na,
CCVector3 &  Nb,
CCVector3 &  Nc
) const
overridevirtual
Returns a given triangle normal.
Mesh must have triangle normals associated (see hasTriNormals)
◆ getTriangleTexCoordinates()
void ccMesh::getTriangleTexCoordinates ( unsigned  triIndex,
TexCoords2D *&  tx1,
TexCoords2D *&  tx2,
TexCoords2D *&  tx3
) const
overridevirtual
◆ getTriangleTexCoordinatesIndexes()
void ccMesh::getTriangleTexCoordinatesIndexes ( unsigned  triangleIndex,
int &  i1,
int &  i2,
int &  i3
) const
overridevirtual
Returns the triplet of tex coords indexes for a given triangle.
◆ getTriNormsTable()
NormsIndexesTableType * ccMesh::getTriNormsTable ( ) const
◆ getUniqueIDForDisplay()
unsigned ccMesh::getUniqueIDForDisplay ( ) const
overridevirtual
Returns object unique ID used for display.
◆ getVertexColorFromMaterial()
bool ccMesh::getVertexColorFromMaterial ( unsigned  triIndex,
unsigned char  vertIndex,
bool  returnColorIfNoTexture
overridevirtual
Returns RGB color of a vertex fom a given triangle material/texture.
vertIndexvertex index inside triangle (i.e. 0, 1 or 2!)
returnColorIfNoTexturewhether to return the color from the vertex RGB field if no texture/material is associated to the given triangle
Returns
success
◆ hasColors()
bool ccMesh::hasColors ( ) const
overridevirtual
Reimplemented from ccDrawableObject.
◆ hasDisplayedScalarField()
bool ccMesh::hasDisplayedScalarField ( ) const
overridevirtual
◆ hasMaterials()
bool ccMesh::hasMaterials ( ) const
overridevirtual
◆ hasNormals()
bool ccMesh::hasNormals ( ) const
overridevirtual
◆ hasPerTriangleTexCoordIndexes()
bool ccMesh::hasPerTriangleTexCoordIndexes ( ) const
◆ hasScalarFields()
bool ccMesh::hasScalarFields ( ) const
overridevirtual
Returns whether one or more scalar fields are instantiated.
Warning
doesn't mean a scalar field is currently displayed (see ccDrawableObject::hasDisplayedScalarField).
◆ hasTextures()
bool ccMesh::hasTextures ( ) const
overridevirtual
◆ hasTriNormals()
bool ccMesh::hasTriNormals ( ) const
overridevirtual
◆ interpolateColors() [1/2]
bool ccMesh::interpolateColors ( unsigned  triIndex,
ccColor::Rgb color
overridevirtual
Interpolates RGB colors inside a given triangle.
Ppoint where to interpolate (should be inside the triangle!)
[out]colorinterpolated color
Returns
success
◆ interpolateColors() [2/2]
ccColor::Rgba color
overridevirtual
Interpolates RGBA colors inside a given triangle.
Returns
success
◆ interpolateColorsBC() [1/2]
bool ccMesh::interpolateColorsBC ( unsigned  triIndex,
const CCVector3d &  w,
ccColor::Rgb color
overridevirtual
wbarycentric coordinates
Returns
success
◆ interpolateColorsBC() [2/2]
ccColor::Rgba color
overridevirtual
Returns
success
◆ interpolateNormalsBC()
bool ccMesh::interpolateNormalsBC ( unsigned  triIndex,
CCVector3 &  N
overridevirtual
Interpolates normal(s) inside a given triangle.
[out]Ninterpolated normal
Returns
success
◆ invertNormals()
void ccMesh::invertNormals ( )
Inverts normals (if any)
Either the per-triangle normals, or the per-vertex ones
◆ isSerializable()
bool ccMesh::isSerializable ( ) const
◆ laplacianSmooth()
bool ccMesh::laplacianSmooth ( unsigned  nbIteration = 100,
PointCoordinateType  factor = static_cast<PointCoordinateType>(0.01),
ccProgressDialog progressCb = nullptr
nbIterationsmoothing iterations
factorsmoothing 'force'
progressCbprogress dialog callback
◆ merge()
bool ccMesh::merge ( const ccMesh mesh,
bool  createSubMesh
Merges another mesh into this one.
meshmesh to be merged in this one
createSubMeshwhether to create a submesh entity corresponding to the added mesh
Returns
success
◆ normalsShown()
bool ccMesh::normalsShown ( ) const
overridevirtual
◆ onDeletionOf()
void ccMesh::onDeletionOf ( const ccHObject obj)
This method is called when another object is deleted.
For internal use.
◆ onUpdateOf()
void ccMesh::onUpdateOf ( ccHObject obj)
This method is called when another object (geometry) is updated.
For internal use.
◆ processScalarField()
bool ccMesh::processScalarField ( MESH_SCALAR_FIELD_PROCESS  process)
Applies process to the mesh scalar field (the one associated to its vertices in fact)
A very simple smoothing/enhancement algorithm based on each vertex direct neighbours. Prior to calling this method, one should check first that the vertices are associated to a scalar field. Warning: the processed scalar field must be enabled for both INPUT & OUTPUT! (see ccGenericCloud::setCurrentScalarField)
processeither 'smooth' or 'enhance'
◆ refreshBB()
void ccMesh::refreshBB ( )
overridevirtual
Forces bounding-box update.
◆ reserve()
bool ccMesh::reserve ( size_t  n)
Reserves the memory to store the vertex indexes (3 per triangle)
nthe number of triangles to reserve
Returns
true if the method succeeds, false otherwise
◆ reservePerTriangleMtlIndexes()
bool ccMesh::reservePerTriangleMtlIndexes ( )
Reserves memory to store per-triangle material index.
Before adding per-triangle material index to the mesh (with ccMesh::addTriangleMtlIndex()) be sure to reserve the necessary amount of memory with this method. This method reserves memory for as many material descriptors as the number of triangles in the mesh (effectively stored or reserved - a call to ccMesh::reserve prior to this one is mandatory).
Returns
true if ok, false if there's not enough memory
◆ reservePerTriangleNormalIndexes()
bool ccMesh::reservePerTriangleNormalIndexes ( )
Reserves memory to store per-triangle triplets of normal indexes.
Before adding per-triangle normal indexes triplets to the mesh (with ccMesh::addTriangleNormalsIndexes()) be sure to reserve the necessary amount of memory with this method. This method reserves memory for as many normals indexes triplets as the number of triangles in the mesh (effectively stored or reserved - a call to ccMesh::reserve prior to this one is mandatory).
Returns
◆ reservePerTriangleTexCoordIndexes()
bool ccMesh::reservePerTriangleTexCoordIndexes ( )
Reserves memory to store per-triangle triplets of tex coords indexes.
Before adding per-triangle tex coords indexes triplets to the mesh (with ccMesh::addTriangleTexCoordIndexes()) be sure to reserve the necessary amount of memory with this method. This method reserves memory for as many tex coords indexes triplets as the number of triangles in the mesh (effectively stored or reserved - a call to ccMesh::reserve prior to this one is mandatory).
Returns
◆ resize()
bool ccMesh::resize ( size_t  n)
Resizes the array of vertex indexes (3 per triangle)
If the new number of elements is smaller than the actual size, the overflooding elements will be deleted.
nthe new number of triangles
Returns
◆ setTriangleMtlIndex()
void ccMesh::setTriangleMtlIndex ( unsigned  triangleIndex,
int  mtlIndex
Sets triangle material indexes.
◆ setTriangleNormalIndexes()
void ccMesh::setTriangleNormalIndexes ( unsigned  triangleIndex,
int  i1,
int  i2,
int  i3
Sets a triplet of normal indexes for a given triangle.
◆ setTriangleTexCoordIndexes()
void ccMesh::setTriangleTexCoordIndexes ( unsigned  triangleIndex,
int  i1,
int  i2,
int  i3
Sets a triplet of tex coords indexes for a given triangle.
◆ shiftTriangleIndexes()
void ccMesh::shiftTriangleIndexes ( unsigned  shift)
Shifts all triangles indexes.
shiftindex shift (positive)
◆ subdivide()
ccMesh * ccMesh::subdivide ( PointCoordinateType  maxArea) const
Subdivides mesh (so as to ensure that all triangles are falls below 'maxArea')
Returns
subdivided mesh (if successful)
◆ swapTriangles()
void ccMesh::swapTriangles ( unsigned  index1,
unsigned  index2
Automatically updates internal structures (i.e. lookup tables for material, normals, etc.).
◆ toFile_MeOnly()
bool ccMesh::toFile_MeOnly ( QFile &  out) const
◆ toggleMaterials()
void ccMesh::toggleMaterials ( )
◆ Triangulate()
ccMesh * ccMesh::Triangulate ( ccGenericPointCloud cloud,
bool  updateNormals = false,
PointCoordinateType  maxEdgeLength = 0,
unsigned char  dim = 2
static
Creates a Delaunay 2.5D mesh from a point cloud.
See CCCoreLib::PointProjectionTools::computeTriangulation.
