Public Member Functions | Protected Member Functions | List of all members
ccMeshGroup Class Reference
[DEPRECATED] A group of meshes sharing vertices (and associated properties) in a unique cloud More...
#include <ccMeshGroup.h>
Inheritance diagram for ccMeshGroup:
Inheritance graph
Collaboration diagram for ccMeshGroup:
 ccMeshGroup ()
 Default constructor.
 Returns class ID.
virtual ccGenericPointCloudgetAssociatedCloud () const
 Returns the vertices cloud.
virtual ccGenericMeshclone (ccGenericPointCloud *vertices=0, ccMaterialSet *clonedMaterials=0, NormsIndexesTableType *clonedNormsTable=0, TextureCoordsContainer *cloneTexCoords=0)
virtual void refreshBB ()
 Forces bounding-box update.
virtual bool interpolateNormals (unsigned triIndex, const CCVector3 &P, CCVector3 &N)
virtual bool interpolateColors (unsigned triIndex, const CCVector3 &P, colorType rgb[])
virtual bool getColorFromMaterial (unsigned triIndex, const CCVector3 &P, colorType rgb[], bool interpolateColorIfNoTexture)
virtual bool getVertexColorFromMaterial (unsigned triIndex, unsigned char vertIndex, colorType rgb[], bool returnColorIfNoTexture)
virtual bool hasMaterials () const
const ccMaterialSetgetMaterialSet () const
virtual int getTriangleMtlIndex (unsigned triangleIndex) const
virtual bool hasTextures () const
virtual TextureCoordsContainergetTexCoordinatesTable () const
virtual void getTriangleTexCoordinates (unsigned triIndex, float *&tx1, float *&tx2, float *&tx3) const
virtual bool hasPerTriangleTexCoordIndexes () const
virtual void getTriangleTexCoordinatesIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const
virtual bool hasTriNormals () const
virtual void getTriangleNormalIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const
virtual bool getTriangleNormals (unsigned triangleIndex, CCVector3 &Na, CCVector3 &Nb, CCVector3 &Nc) const
virtual NormsIndexesTableTypegetTriNormsTable () const
virtual unsigned maxSize () const
 Returns max capacity.
 Save own object data. More...
virtual unsigned size () const
virtual void forEach (genericTriangleAction &anAction)
virtual void placeIteratorAtBegining ()
virtual CCLib::GenericTriangle * _getNextTriangle ()
virtual CCLib::GenericTriangle * _getTriangle (unsigned index)
virtual
CCLib::TriangleSummitsIndexes *
getNextTriangleIndexes ()
virtual
getTriangleIndexes (unsigned triangleIndex)
virtual void getTriangleSummits (unsigned triangleIndex, CCVector3 &A, CCVector3 &B, CCVector3 &C)
virtual void getBoundingBox (PointCoordinateType bbMin[], PointCoordinateType bbMax[])
 Default constructor. More...
virtual ~ccGenericMesh ()
 Destructor.
 Sets normals visibility.
 Enables polygon stippling.
 Samples points on a mesh.
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
virtual ccBBox getMyOwnBB ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
bool m_triNormsShown
bool m_materialsShown
bool m_showWired
 Wireframe display mode.
bool m_stippling
 Polygon stippling state.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
This is an empty shell for backward compatibility. Shouldn't be used anymore.
Member Function Documentation
bool ccMeshGroup::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
virtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccGenericMesh.
virtual bool ccMeshGroup::getColorFromMaterial ( unsigned  triIndex,
const CCVector3 &  P,
colorType  rgb[],
inlinevirtual
Returns RGB color fom a given triangle material/texture.
triIndextriangle index
Ppoint where to grab color (should be inside the triangle!)
[out]rgbtexel color
interpolateColorIfNoTexturewhether to return the color interpolated from the RGB field if no texture/material is associated to the given triangles
Returns
success
Implements ccGenericMesh.
virtual void ccMeshGroup::getTriangleNormalIndexes ( unsigned  triangleIndex,
int &  i1,
int &  i2,
int &  i3
) const
inlinevirtual
Returns a triplet of normal indexes for a given triangle (if any)
[in]triangleIndextriangle index
[out]i1first summit normal index (or -1 if none)
[out]i2second summit normal index (or -1 if none)
[out]i3third summit normal index (or -1 if none)
virtual bool ccMeshGroup::getTriangleNormals ( unsigned  triangleIndex,
CCVector3 &  Na,
CCVector3 &  Nb,
CCVector3 &  Nc
) const
inlinevirtual
Returns a given triangle normal.
Mesh must have triangle normals associated (see hasTriNormals)
virtual void ccMeshGroup::getTriangleTexCoordinatesIndexes ( unsigned  triangleIndex,
int &  i1,
int &  i2,
int &  i3
) const
inlinevirtual
Returns the triplet of tex coords indexes for a given triangle.
i1first summit tex coords index
i2second summit tex coords index
i3third summit tex coords index
virtual bool ccMeshGroup::getVertexColorFromMaterial ( unsigned  triIndex,
colorType  rgb[],
inlinevirtual
Returns RGB color of a vertex fom a given triangle material/texture.
vertIndexvertex index inside triangle (i.e. 0, 1 or 2!)
[out]rgbtexel color
returnColorIfNoTexturewhether to return the color from the vertex RGB field if no texture/material is associated to the given triangle
Returns
success
virtual bool ccMeshGroup::interpolateColors ( unsigned  triIndex,
colorType  rgb[]
inlinevirtual
Interpolates RGB colors inside a given triangle.
Ppoint where to interpolate (should be inside the triangle!)
[out]rgbinterpolated color
Returns
success
virtual bool ccMeshGroup::interpolateNormals ( unsigned  triIndex,
CCVector3 &  N
inlinevirtual
Interpolates normal(s) inside a given triangle.
[out]Ninterpolated normal
Returns
success
bool ccMeshGroup::toFile_MeOnly ( QFile &  out) const
virtual
