Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
ccOctree Class Reference
Octree structure. More...
#include <ccOctree.h>
Inheritance diagram for ccOctree:
Inheritance graph
Collaboration diagram for ccOctree:
 ccOctree (ccGenericPointCloud *aCloud)
 Default constructor. More...
virtual ~ccOctree ()
 Destructor.
void multiplyBoundingBox (const PointCoordinateType multFactor)
 Multiplies the bounding-box of the octree. More...
void translateBoundingBox (const CCVector3 &T)
 Translates the bounding-box of the octree. More...
 Returns class ID.
int getDisplayedLevel () const
void setDisplayedLevel (int level)
CC_OCTREE_DISPLAY_TYPE getDisplayType () const
void setDisplayType (CC_OCTREE_DISPLAY_TYPE type)
virtual void clear ()
virtual ccBBox getMyOwnBB ()
bool intersectWithFrustrum (ccCameraSensor *sensor, std::vector< unsigned > &inCameraFrustrum)
 Intersects octree with a camera sensor.
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
static void RenderOctreeAs (CC_OCTREE_DISPLAY_TYPE octreeDisplayType, ccOctree *theOctree, unsigned char level, ccGenericPointCloud *theAssociatedCloud, int &octreeGLListID, bool updateOctreeGLDisplay=true)
static void ComputeAverageColor (CCLib::ReferenceCloud *subset, ccGenericPointCloud *sourceCloud, colorType meanCol[])
static CCVector3 ComputeAverageNorm (CCLib::ReferenceCloud *subset, ccGenericPointCloud *sourceCloud)
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
void drawMeOnly (CC_DRAW_CONTEXT &context)
 Sets parent object.
 Save own object data. More...
 Returns flag state.
 Sets flag state. More...
static bool DrawCellAsABox (const CCLib::DgmOctree::octreeCell &cell, void **additionalParameters, CCLib::NormalizedProgress *nProgress=0)
static bool DrawCellAsAPoint (const CCLib::DgmOctree::octreeCell &cell, void **additionalParameters, CCLib::NormalizedProgress *nProgress=0)
static bool DrawCellAsAPrimitive (const CCLib::DgmOctree::octreeCell &cell, void **additionalParameters, CCLib::NormalizedProgress *nProgress=0)
ccGenericPointCloudm_associatedCloud
CC_OCTREE_DISPLAY_TYPE m_displayType
int m_displayedLevel
int m_glListID
bool m_shouldBeRefreshed
ccOctreeFrustrumIntersectorm_frustrumIntersector
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
Octree structure.
Extends the CCLib::DgmOctree class.
ccOctree::ccOctree ( ccGenericPointCloud aCloud)
aClouda point cloud
Member Function Documentation
ccBBox ccOctree::getDisplayBB ( )
virtual
Children bboxes are ignored. The bounding-box should take into account entity geometrical data and any other 3D displayed elements.
Returns
bounding-box
Reimplemented from ccHObject.
ccBBox ccOctree::getMyOwnBB ( )
virtual
Returns
bounding-box
void ccOctree::multiplyBoundingBox ( const PointCoordinateType  multFactor)
If the cloud coordinates are simply multiplied by the same factor, there is no use to recompute the octree structure. It's sufficient to update its bounding-box.
multFactormultiplication factor
void ccOctree::translateBoundingBox ( const CCVector3 &  T)
If the cloud has been simply translated, there is no use to recompute the octree structure. It's sufficient to update its bounding-box.
Ttranslation vector
