Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ccPlane Class Reference
Plane (primitive) More...
#include <ccPlane.h>
Inheritance diagram for ccPlane:
Inheritance graph
Collaboration diagram for ccPlane:
 ccPlane (PointCoordinateType xWidth, PointCoordinateType yWidth, const ccGLMatrix *transMat=0, QString name=QString("Plane"))
 Default constructor. More...
 ccPlane (QString name=QString("Plane"))
 Returns class ID.
virtual QString getTypeName () const
virtual ccGenericPrimitiveclone () const
 Clones primitive.
PointCoordinateType getXWidth () const
 Returns 'X' width.
PointCoordinateType getYWidth () const
 Returns 'Y' width.
CCVector3 getNormal () const
 Returns normal.
bool setAsTexture (QImage image)
 Sets an image as texture.
 ccGenericPrimitive (QString name=QString(), const ccGLMatrix *transMat=0)
virtual void setColor (const colorType *col)
const ccGenericPrimitiveoperator+= (const ccGenericPrimitive &prim)
 Add operator. More...
 Whether drawing is dependent on 'precision' parameter.
virtual ccGLMatrixgetTransformation ()
virtual const ccGLMatrixgetTransformation () const
 ccMesh (ccGenericPointCloud *vertices)
 ccMesh (CCLib::GenericIndexedMesh *giMesh, ccGenericPointCloud *giVertices)
 ccMesh constructor (from a CCLib::GenericIndexedMesh) More...
virtual ~ccMesh ()
 Default destructor.
virtual void setAssociatedCloud (ccGenericPointCloud *cloud)
virtual ccMeshclone (ccGenericPointCloud *vertices=0, ccMaterialSet *clonedMaterials=0, NormsIndexesTableType *clonedNormsTable=0, TextureCoordsContainer *cloneTexCoords=0)
 Clones this entity. More...
virtual ccGenericPointCloudgetAssociatedCloud () const
 Returns the vertices cloud.
virtual void refreshBB ()
 Forces bounding-box update.
virtual bool interpolateNormals (unsigned triIndex, const CCVector3 &P, CCVector3 &N)
virtual bool interpolateColors (unsigned triIndex, const CCVector3 &P, colorType rgb[])
virtual bool getColorFromMaterial (unsigned triIndex, const CCVector3 &P, colorType rgb[], bool interpolateColorIfNoTexture)
virtual bool getVertexColorFromMaterial (unsigned triIndex, unsigned char vertIndex, colorType rgb[], bool returnColorIfNoTexture)
virtual unsigned maxSize () const
 Returns max capacity.
virtual void forEach (genericTriangleAction &anAction)
virtual void placeIteratorAtBegining ()
virtual CCLib::GenericTriangle * _getNextTriangle ()
virtual CCLib::GenericTriangle * _getTriangle (unsigned triangleIndex)
virtual
CCLib::TriangleSummitsIndexes *
getNextTriangleIndexes ()
virtual
getTriangleIndexes (unsigned triangleIndex)
virtual void getTriangleSummits (unsigned triangleIndex, CCVector3 &A, CCVector3 &B, CCVector3 &C)
virtual unsigned size () const
virtual void getBoundingBox (PointCoordinateType bbMin[], PointCoordinateType bbMax[])
virtual const
getTriangleIndexes (unsigned triangleIndex) const
virtual ccBBox getMyOwnBB ()
 Sets associated GL display.
virtual void shiftTriangleIndexes (unsigned shift)
bool reserve (unsigned n)
bool resize (unsigned n)
virtual bool hasTriNormals () const
virtual void getTriangleNormalIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const
virtual bool getTriangleNormals (unsigned triangleIndex, CCVector3 &Na, CCVector3 &Nb, CCVector3 &Nc) const
virtual NormsIndexesTableTypegetTriNormsTable () const
virtual void setTriNormsTable (NormsIndexesTableType *triNormsTable, bool autoReleaseOldTable=true)
virtual void clearTriNormals ()
 Removes per-triangle normals.
virtual bool hasMaterials () const
virtual const ccMaterialSetgetMaterialSet () const
virtual int getTriangleMtlIndex (unsigned triangleIndex) const
virtual bool convertMaterialsToVertexColors ()
virtual void setMaterialSet (ccMaterialSet *materialSet, bool autoReleaseOldMaterialSet=true)
virtual bool hasTextures () const
virtual TextureCoordsContainergetTexCoordinatesTable () const
virtual void getTriangleTexCoordinates (unsigned triIndex, float *&tx1, float *&tx2, float *&tx3) const
virtual bool hasPerTriangleTexCoordIndexes () const
virtual void getTriangleTexCoordinatesIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const
virtual void setTexCoordinatesTable (TextureCoordsContainer *texCoordsTable, bool autoReleaseOldTable=true)
virtual bool computeNormals (bool perVertex)
 Computes normals. More...
virtual bool computePerVertexNormals ()
virtual bool computePerTriangleNormals ()
bool laplacianSmooth (unsigned nbIteration=100, PointCoordinateType factor=static_cast< PointCoordinateType >(0.01), CCLib::GenericProgressCallback *progressCb=0)
 Laplacian smoothing. More...
virtual ccMeshcreateNewMeshFromSelection (bool removeSelectedFaces)
 Swaps two triangles. More...
virtual ~ccGenericMesh ()
 Destructor.
 Sets normals visibility.
 Enables polygon stippling.
 Samples points on a mesh.
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
virtual void redrawDisplay ()
static ccPlaneFit (CCLib::GenericIndexedCloudPersist *cloud, double *rms=0)
 Fits a plane primitive on a cloud. More...
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
 Save own object data. More...
virtual bool buildUp ()
 Builds primitive. More...
 Inherited from ccGenericMesh.
ccGenericPrimitivefinishCloneJob (ccGenericPrimitive *primitive) const
ccPointCloudvertices ()
 Returns vertices.
bool interpolateNormals (unsigned i1, unsigned i2, unsigned i3, const CCVector3 &P, CCVector3 &N, const int *triNormIndexes=0)
bool interpolateColors (unsigned i1, unsigned i2, unsigned i3, const CCVector3 &P, colorType rgb[])
 ccMesh_extended_call1 (showNormals, bool, showNormals_extended)
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
PointCoordinateType m_xWidth
 Width along 'X' dimension.
PointCoordinateType m_yWidth
 Width along 'Y' dimension.
ccGLMatrix m_transformation
unsigned m_drawPrecision
ccGenericPointCloudm_associatedCloud
 associated cloud (vertices)
NormsIndexesTableTypem_triNormals
 Per-triangle normals.
 Texture coordinates.
ccMaterialSetm_materials
 Materials.
unsigned m_globalIterator
 Iterator on the list of triangle summits indexes.
CCLib::SimpleRefTriangle m_currentTriangle
ccBBox m_bBox
 Bounding-box.
bool m_triNormsShown
bool m_materialsShown
bool m_showWired
 Wireframe display mode.
bool m_stippling
 Polygon stippling state.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  MESH_SCALAR_FIELD_PROCESS { SMOOTH_MESH_SF, ENHANCE_MESH_SF }
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
typedef GenericChunkedArray
< 3, unsigned >
< 1, int >
< 3, int >
< 3, int >
Plane (primitive)
3D plane primitive
ccPlane::ccPlane ( PointCoordinateType  xWidth,
const ccGLMatrix transMat = 0,
QString  name = QString("Plane")
Plane normal corresponds to 'Z' dimension
xWidthplane width along 'X' dimension
yWidthplane width along 'Y' dimension
namename
ccPlane::ccPlane ( QString  name = QString("Plane"))
Simplified constructor.
For ccHObject factory only!
Member Function Documentation
bool ccPlane::buildUp ( )
protectedvirtual
Builds primitive.
Returns
success
Implements ccGenericPrimitive.
ccPlane * ccPlane::Fit ( CCLib::GenericIndexedCloudPersist *  cloud,
double *  rms = 0
static
The cloud can be any CCLib::GenericIndexedCloudPersist-derived object, i.e. even a ccPolyline object for instance.
[in]cloudinput cloud
[out]rmsplane fitting rms (optional)
Returns
plane primitive (if successful)
bool ccPlane::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
protectedvirtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccGenericPrimitive.
ccBBox ccPlane::getFitBB ( ccGLMatrix trans)
virtual
Returns best-fit bounding-box (if available)
WARNING: This method is not supported by all entities! Should be re-implemented whenever possible (returns the axis-aligned bounding-box by default).
[out]transassociated transformation (so that the bounding-box can be displayed in the right position!)
Returns
fit bounding-box
Reimplemented from ccDrawableObject.
bool ccPlane::toFile_MeOnly ( QFile &  out) const
protectedvirtual
