CloudCompare 3D entities
ccPointCloud Member List
This is the complete list of members for ccPointCloud, including all inherited members.
addColor(const ccColor::Rgba &C)ccPointCloud
addColor(const ccColor::Rgb &C)ccPointCloudinline
addColor(ColorCompType r, ColorCompType g, ColorCompType b, ColorCompType a=ccColor::MAX)ccPointCloudinline
addColorRampInfo(CC_DRAW_CONTEXT &context)ccPointCloud
addGreyColor(ColorCompType g)ccPointCloudinline
addGrid(Grid::Shared grid)ccPointCloudinline
addNorm(const CCVector3 &N)ccPointCloud
addNormAtIndex(const PointCoordinateType *N, unsigned index)ccPointCloud
addNormIndex(CompressedNormType index)ccPointCloud
addScalarField(const char *uniqueName) override (defined in ccPointCloud)ccPointCloud
addScalarField(ccScalarField *sf)ccPointCloud
append(ccPointCloud *cloud, unsigned pointCountBefore, bool ignoreChildren=false)ccPointCloud
applyGLTransformation(const ccGLMatrix &trans) override (defined in ccPointCloud)ccPointCloudprotected
applyRigidTransformation(const ccGLMatrix &trans) override (defined in ccPointCloud)ccPointCloud
BaseClass typedefccPointCloud
ccPointCloud(QString name=QString(), unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)ccPointCloud
clear() overrideccPointCloud
clearFWFData()ccPointCloud
clearLOD()ccPointCloud
clone(ccGenericPointCloud *destCloud=nullptr, bool ignoreChildren=false) override (defined in ccPointCloud)ccPointCloud
CLONE_WARNINGS enum nameccPointCloud
cloneThis(ccPointCloud *destCloud=nullptr, bool ignoreChildren=false)ccPointCloud
colorize(float r, float g, float b, float a=1.0f)ccPointCloud
colorsHaveChanged()ccPointCloudinline
compressFWFData()ccPointCloud
computeCPSet(ccGenericPointCloud &otherCloud, CCCoreLib::GenericProgressCallback *progressCb=nullptr, unsigned char octreeLevel=0)ccPointCloud
computeFWFAmplitude(double &minVal, double &maxVal, ccProgressDialog *pDlg=nullptr) constccPointCloud
computeGravityCenter()ccPointCloud
computeNormalsWithGrids(double minTriangleAngle_deg=1.0, ccProgressDialog *pDlg=nullptr)ccPointCloud
computeNormalsWithOctree(CCCoreLib::LOCAL_MODEL_TYPES model, ccNormalVectors::Orientation preferredOrientation, PointCoordinateType defaultRadius, ccProgressDialog *pDlg=nullptr)ccPointCloud
CONE enum value (defined in ccPointCloud)ccPointCloud
convertCurrentScalarFieldToColors(bool mixWithExistingColor=false)ccPointCloud
convertNormalToDipDirSFs(ccScalarField *dipSF, ccScalarField *dipDirSF)ccPointCloud
convertNormalToRGB()ccPointCloud
convertRGBToGreyScale()ccPointCloud
createNewCloudFromVisibilitySelection(bool removeSelectedPoints=false, VisibilityTableType *visTable=nullptr, bool silent=false) overrideccPointCloud
crop(const ccBBox &box, bool inside=true) override (defined in ccPointCloud)ccPointCloud
crop2D(const ccPolyline *poly, unsigned char orthoDim, bool inside=true)ccPointCloud
CYLINDER enum value (defined in ccPointCloud)ccPointCloud
deleteAllScalarFields() override (defined in ccPointCloud)ccPointCloud
deleteScalarField(int index) override (defined in ccPointCloud)ccPointCloud
drawMeOnly(CC_DRAW_CONTEXT &context) override (defined in ccPointCloud)ccPointCloudprotected
enableVisibilityCheck(bool state)ccPointCloudinline
enhanceRGBWithIntensitySF(int sfIdx, bool useCustomIntensityRange=false, double minI=0.0, double maxI=1.0)ccPointCloud
exportCoordToSF(bool exportDims[3])ccPointCloud
exportNormalToSF(bool exportDims[3])ccPointCloud
filterPointsByScalarValue(ScalarType minVal, ScalarType maxVal, bool outside=false)ccPointCloud
From(const CCCoreLib::GenericIndexedCloud *cloud, const ccGenericPointCloud *sourceCloud=nullptr)ccPointCloudstatic
From(CCCoreLib::GenericCloud *cloud, const ccGenericPointCloud *sourceCloud=nullptr)ccPointCloudstatic
fromFile_MeOnly(QFile &in, short dataVersion, int flags, LoadedIDMap &oldToNewIDMap) override (defined in ccPointCloud)ccPointCloudprotected
fwfData()ccPointCloudinline
fwfData() constccPointCloudinline
FWFDataContainer typedefccPointCloud
fwfDescriptors()ccPointCloudinline
fwfDescriptors() constccPointCloudinline
FWFDescriptorSet typedefccPointCloud
geScalarValueColor(ScalarType d) const override (defined in ccPointCloud)ccPointCloud
getClassID() const overrideccPointCloudinline
getCurrentDisplayedScalarField() constccPointCloud
getCurrentDisplayedScalarFieldIndex() constccPointCloud
getDrawingParameters(glDrawParams &params) const override (defined in ccPointCloud)ccPointCloud
getNormal(unsigned pointIndex) const override (defined in ccPointCloud)ccPointCloud
getPointColor(unsigned pointIndex) const override (defined in ccPointCloud)ccPointCloud
getPointDisplayedDistance(unsigned pointIndex) const override (defined in ccPointCloud)ccPointCloud
getPointNormal(unsigned pointIndex) const override (defined in ccPointCloud)ccPointCloud
getPointNormalIndex(unsigned pointIndex) const override (defined in ccPointCloud)ccPointCloud
getPointScalarValueColor(unsigned pointIndex) const override (defined in ccPointCloud)ccPointCloud
getUniqueIDForDisplay() const override (defined in ccPointCloud)ccPointCloud
glChunkColorPointer(const CC_DRAW_CONTEXT &context, size_t chunkIndex, unsigned decimStep, bool useVBOs) (defined in ccPointCloud)ccPointCloudprotected
glChunkNormalPointer(const CC_DRAW_CONTEXT &context, size_t chunkIndex, unsigned decimStep, bool useVBOs) (defined in ccPointCloud)ccPointCloudprotected
glChunkSFPointer(const CC_DRAW_CONTEXT &context, size_t chunkIndex, unsigned decimStep, bool useVBOs) (defined in ccPointCloud)ccPointCloudprotected
glChunkVertexPointer(const CC_DRAW_CONTEXT &context, size_t chunkIndex, unsigned decimStep, bool useVBOs) (defined in ccPointCloud)ccPointCloudprotected
grid(size_t gridIndex)ccPointCloudinline
grid(size_t gridIndex) constccPointCloudinline
gridCount() constccPointCloudinline
hasColors() const override (defined in ccPointCloud)ccPointCloud
hasDisplayedScalarField() const override (defined in ccPointCloud)ccPointCloud
hasFWF() constccPointCloud
hasNormals() const override (defined in ccPointCloud)ccPointCloud
hasScalarFields() const override (defined in ccPointCloud)ccPointCloud
hasSensor() constccPointCloud
hidePointsByScalarValue(ScalarType minVal, ScalarType maxVal)ccPointCloud
initLOD()ccPointCloud
interpolateColorsFrom(ccGenericPointCloud *cloud, CCCoreLib::GenericProgressCallback *progressCb=nullptr, unsigned char octreeLevel=0)ccPointCloud
invalidateBoundingBox() override (defined in ccPointCloud)ccPointCloud
invertNormals()ccPointCloud
m_currentDisplayedScalarFieldccPointCloudprotected
m_currentDisplayedScalarFieldIndexccPointCloudprotected
m_fwfDataccPointCloudprotected
m_fwfDescriptorsccPointCloudprotected
m_fwfWaveformsccPointCloudprotected
m_gridsccPointCloudprotected
m_lodccPointCloudprotected
m_normalsccPointCloudprotected
m_rgbaColorsccPointCloudprotected
m_sfColorScaleDisplayedccPointCloudprotected
m_vboManagerccPointCloudprotected
m_visibilityCheckEnabledccPointCloudprotected
normals() constccPointCloudinline
normalsAvailable() const override (defined in ccPointCloud)ccPointCloudinline
normalsHaveChanged()ccPointCloudinline
notifyGeometryUpdate() override (defined in ccPointCloud)ccPointCloudprotected
operator+=(ccPointCloud *)ccPointCloud
orientNormalsTowardViewPoint(CCVector3 &VP, ccProgressDialog *pDlg=nullptr)ccPointCloud
orientNormalsWithFM(unsigned char level, ccProgressDialog *pDlg=nullptr)ccPointCloud
orientNormalsWithGrids(ccProgressDialog *pDlg=nullptr)ccPointCloud
orientNormalsWithMST(unsigned kNN=6, ccProgressDialog *pDlg=nullptr)ccPointCloud
partialClone(const CCCoreLib::ReferenceCloud *selection, int *warnings=nullptr) constccPointCloud
pointsHaveChanged()ccPointCloudinline
refreshBB() override (defined in ccPointCloud)ccPointCloudinline
releaseVBOs()ccPointCloud
removeFromDisplay(const ccGenericGLDisplay *win) override (defined in ccPointCloud)ccPointCloud
removeGrids()ccPointCloudinline
reserve(unsigned numberOfPoints) overrideccPointCloud
reserveTheFWFTable()ccPointCloud
reserveTheNormsTable()ccPointCloud
reserveThePointsTable(unsigned _numberOfPoints)ccPointCloud
reserveTheRGBTable()ccPointCloud
resize(unsigned numberOfPoints) overrideccPointCloud
resizeTheFWFTable()ccPointCloud
resizeTheNormsTable()ccPointCloud
resizeTheRGBTable(bool fillWithWhite=false)ccPointCloud
rgbaColors() constccPointCloudinline
scale(PointCoordinateType fx, PointCoordinateType fy, PointCoordinateType fz, CCVector3 center=CCVector3(0, 0, 0)) override (defined in ccPointCloud)ccPointCloud
setColor(ColorCompType r, ColorCompType g, ColorCompType b, ColorCompType a=ccColor::MAX)ccPointCloudinline
setColor(const ccColor::Rgb &col)ccPointCloudinline
setColor(const ccColor::Rgba &col)ccPointCloud
setCurrentDisplayedScalarField(int index)ccPointCloud
setDisplay(ccGenericGLDisplay *win) override (defined in ccPointCloud)ccPointCloud
setNormsTable(NormsIndexesTableType *norms)ccPointCloud
setPointColor(unsigned pointIndex, const ccColor::Rgba &col)ccPointCloud
setPointColor(unsigned pointIndex, const ccColor::Rgb &col)ccPointCloudinline
setPointNormal(unsigned pointIndex, const CCVector3 &N)ccPointCloud
setPointNormalIndex(unsigned pointIndex, CompressedNormType norm)ccPointCloud
setRGBColorByBanding(unsigned char dim, double freq)ccPointCloud
setRGBColorByHeight(unsigned char heightDim, ccColorScale::Shared colorScale)ccPointCloud
sfColorScaleShown() constccPointCloud
SharedFWFDataContainer typedef (defined in ccPointCloud)ccPointCloud
showSFColorsScale(bool state)ccPointCloud
shrinkToFit()ccPointCloudinline
STRAIGHTENED_CONE enum value (defined in ccPointCloud)ccPointCloud
STRAIGHTENED_CONE2 enum value (defined in ccPointCloud)ccPointCloud
swapPoints(unsigned firstIndex, unsigned secondIndex) overrideccPointCloudprotected
testVisibility(const CCVector3 &P) const override (defined in ccPointCloud)ccPointCloud
toFile_MeOnly(QFile &out) const override (defined in ccPointCloud)ccPointCloudprotected
translate(const CCVector3 &T)ccPointCloud
triangulateGrid(const Grid &grid, double minTriangleAngle_deg=0.0) constccPointCloud
unallocateColors()ccPointCloud
unallocateNorms()ccPointCloud
unallocatePoints()ccPointCloud
unroll(UnrollMode mode, UnrollBaseParams *params, bool exportDeviationSF=false, double startAngle_deg=0.0, double stopAngle_deg=360.0, CCCoreLib::GenericProgressCallback *progressCb=nullptr) constccPointCloud
UnrollMode enum name (defined in ccPointCloud)ccPointCloud
updateVBOs(const CC_DRAW_CONTEXT &context, const glDrawParams &glParams)ccPointCloudprotected
vboSize() constccPointCloud
waveformProxy(unsigned index) constccPointCloud
waveforms()ccPointCloudinline
waveforms() constccPointCloudinline
WRN_OUT_OF_MEM_FOR_COLORS enum value (defined in ccPointCloud)ccPointCloud
WRN_OUT_OF_MEM_FOR_FWF enum value (defined in ccPointCloud)ccPointCloud
WRN_OUT_OF_MEM_FOR_NORMALS enum value (defined in ccPointCloud)ccPointCloud
WRN_OUT_OF_MEM_FOR_SFS enum value (defined in ccPointCloud)ccPointCloud
~ccPointCloud() overrideccPointCloud
