CloudCompare 3D entities
Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ccPolyline Class Reference
Colored polyline. More...
#include <ccPolyline.h>
Inheritance diagram for ccPolyline:
Inheritance graph
Collaboration diagram for ccPolyline:
 ccPolyline (GenericIndexedCloudPersist *associatedCloud, unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID)
 Default constructor. More...
 ccPolyline (const ccPolyline &poly)
 Copy constructor. More...
virtual ~ccPolyline () override=default
 Destructor.
 Returns class ID. More...
ccPolylineclone () const
 Clones this polyline.
void set2DMode (bool state)
 Defines if the polyline is considered as 2D or 3D. More...
bool is2DMode () const
 Returns whether the polyline is considered as 2D or 3D.
void setForeground (bool state)
 Defines if the polyline is drawn in background or foreground. More...
void setColor (const ccColor::Rgb &col)
 Sets the polyline color. More...
void setWidth (PointCoordinateType width)
 Sets the width of the line. More...
PointCoordinateType getWidth () const
 Returns the width of the line. More...
const ccColor::RgbgetColor () const
 Returns the polyline color. More...
virtual ccBBox getOwnBB (bool withGLFeatures=false) override
virtual void drawBB (CC_DRAW_CONTEXT &context, const ccColor::Rgb &col) override
bool split (PointCoordinateType maxEdgeLength, std::vector< ccPolyline * > &parts)
 Splits the polyline into several parts based on a maximum edge length. More...
PointCoordinateType computeLength () const
 Computes the polyline length.
void showVertices (bool state)
 Sets whether to display or hide the polyline vertices.
bool verticesShown () const
 Whether the polyline vertices should be displayed or not.
void setVertexMarkerWidth (int width)
 Sets the width of vertex markers.
int getVertexMarkerWidth () const
 Returns the width of vertex markers.
bool initWith (ccPointCloud *&vertices, const ccPolyline &poly)
 Initializes the polyline with a given set of vertices and the parameters of another polyline. More...
void importParametersFrom (const ccPolyline &poly)
 Copy the parameters from another polyline.
void showArrow (bool state, unsigned vertIndex, PointCoordinateType length)
 Shows an arrow in place of a given vertex.
unsigned segmentCount () const
 Returns the number of segments.
ccPointCloudsamplePoints (bool densityBased, double samplingParameter, bool withRGB)
 Samples points on the polyline.
ccPolylinesmoothChaikin (PointCoordinateType ratio, unsigned iterationCount) const
 Smoothes the polyline (Chaikin algorithm) More...
bool createNewPolylinesFromSelection (std::vector< ccPolyline * > &output)
 Creates a polyline mesh with the selected vertices only. More...
bool isShifted () const
template<typename T >
 Copy constructor.
 ~ccHObject () override
 Default destructor.
bool isGroup () const
ccHObjectgetParent () const
 Adds a child. More...
void detachAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns selection behavior.
 Copy constructor.
 Returns object name. More...
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Destructor.
 ccDrawableObject ()
 Copy constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Applies a display state.
static bool IsCloudVerticesOfPolyline (ccGenericPointCloud *cloud, ccPolyline **polyline=nullptr)
 Helper to determine if the input cloud acts as vertices of a polyline.
static QString MetaKeyUpDir ()
 Meta data key: vertical direction (for 2D polylines, contour plots, etc.) More...
static QString MetaKeyConstAltitude ()
 Meta data key: contour plot constant altitude (for contour plots, etc.) More...
static QString MetaKeyAbscissa ()
 Meta data key: profile abscissa along generatrix.
static QString MetaKeyPrefixCenter ()
 Meta data key (prefix): intersection point between profile and its generatrix. More...
static QString MetaKeyPrefixDirection ()
 Meta data key (prefix): generatrix orientation at the point of intersection with the profile. More...
 Static factory. More...
 Sets the unique ID generator.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
 Save own object data. More...
 Serialization helper (output)
 Serialization helper (input)
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
ccColor::Rgb m_rgbColor
 Unique RGB color.
PointCoordinateType m_width
 Width of the line.
bool m_mode2D
 Whether polyline should be considered as 2D (true) or 3D (false)
bool m_foreground
 Whether polyline should draws itself in background (false) or foreground (true)
bool m_showVertices
 Whether vertices should be displayed or not.
int m_vertMarkWidth
 Vertex marker width.
bool m_showArrow
 Whether to show an arrow or not.
PointCoordinateType m_arrowLength
 Arrow length.
unsigned m_arrowIndex
 Arrow index.
CCVector3d m_globalShift
double m_globalScale
ccHObjectm_parent
 Parent.
Container m_children
 Children.
 Selection behavior.
 Dependencies map. More...
ccGLMatrix m_glTransHistory
bool m_isDeleting
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
ccColor::Rgba m_tempColor
 Temporary (unique) color.
bool m_colorIsOverridden
bool m_glTransEnabled
bool m_showNameIn3D
CCVector3d m_nameIn3DPos
bool m_nameIn3DPosIsValid
ccClipPlaneSet m_clipPlanes
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Shared pointer.
Colored polyline.
Extends the CCCoreLib::Polyline class
◆ ccPolyline() [1/2]
ccPolyline::ccPolyline ( GenericIndexedCloudPersist *  associatedCloud,
explicit
associatedCloudthe associated point cloud (i.e. the vertices)
◆ ccPolyline() [2/2]
ccPolyline::ccPolyline ( const ccPolyline poly)
Copy constructor.
polypolyline to copy/clone
Member Function Documentation
◆ applyGLTransformation()
void ccPolyline::applyGLTransformation ( const ccGLMatrix trans)
overridevirtual
Applies a GL transformation to the entity.
this = rotMat*(this-rotCenter)+(rotCenter+trans)
transa ccGLMatrix structure
Reimplemented from ccHObject.
◆ createNewPolylinesFromSelection()
bool ccPolyline::createNewPolylinesFromSelection ( std::vector< ccPolyline * > &  output)
This method is called after a graphical segmentation. It creates one or several new polylines with the segments having their two vertices tagged as "visible" (see ccGenericPointCloud::visibilityArray).
◆ drawBB()
virtual void ccPolyline::drawBB ( CC_DRAW_CONTEXT context,
const ccColor::Rgb col
inlineoverridevirtual
Draws the entity (and its children) bounding-box.
◆ drawMeOnly()
void ccPolyline::drawMeOnly ( CC_DRAW_CONTEXT context)
overrideprotectedvirtual
◆ fromFile_MeOnly()
bool ccPolyline::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap oldToNewIDMap
Loads own object data.
ininput file
dataVersionfile version
◆ getClassID()
CC_CLASS_ENUM ccPolyline::getClassID ( ) const
Returns class ID.
◆ getColor()
const ccColor::Rgb & ccPolyline::getColor ( ) const
inline
Returns
a pointer to the polyline RGB color
◆ getGlobalScale()
double ccPolyline::getGlobalScale ( ) const
overridevirtual
Returns the scale applied to original coordinates.
Reimplemented from ccShiftedObject.
◆ getGlobalShift()
const CCVector3d & ccPolyline::getGlobalShift ( ) const
overridevirtual
Returns the shift applied to original coordinates.
See ccGenericPointCloud::setOriginalShift
◆ getOwnBB()
ccBBox ccPolyline::getOwnBB ( bool  withGLFeatures = false)
overridevirtual
Returns
bounding-box
◆ getUniqueIDForDisplay()
unsigned ccPolyline::getUniqueIDForDisplay ( ) const
overridevirtual
Returns object unique ID used for display.
◆ getWidth()
PointCoordinateType ccPolyline::getWidth ( ) const
inline
Returns
the width of the line in pixels
◆ hasColors()
bool ccPolyline::hasColors ( ) const
overridevirtual
Reimplemented from ccDrawableObject.
◆ initWith()
bool ccPolyline::initWith ( ccPointCloud *&  vertices,
Warning
Even the 'closed' state is copied as is!
verticesset of vertices (can be null, in which case the polyline vertices will be cloned)
polypolyline
Returns
success
◆ isSerializable()
bool ccPolyline::isSerializable ( ) const
◆ MetaKeyConstAltitude()
static QString ccPolyline::MetaKeyConstAltitude ( )
inlinestatic
Expected value: altitude as double
◆ MetaKeyPrefixCenter()
static QString ccPolyline::MetaKeyPrefixCenter ( )
inlinestatic
Expected value: 3D vector
Warning
must be followed by '.x', '.y' or '.z'
◆ MetaKeyPrefixDirection()
static QString ccPolyline::MetaKeyPrefixDirection ( )
inlinestatic
Warning
◆ MetaKeyUpDir()
static QString ccPolyline::MetaKeyUpDir ( )
inlinestatic
Expected value: 0(=X), 1(=Y) or 2(=Z) as int
◆ set2DMode()
void ccPolyline::set2DMode ( bool  state)
stateif true, the polyline is 2D
◆ setColor()
void ccPolyline::setColor ( const ccColor::Rgb col)
inline
colRGB color
◆ setForeground()
void ccPolyline::setForeground ( bool  state)
stateif true, the polyline is drawn in foreground
◆ setGlobalScale()
void ccPolyline::setGlobalScale ( double  scale)
overridevirtual
Sets the scale applied to original coordinates (information storage only)
◆ setGlobalShift()
void ccPolyline::setGlobalShift ( const CCVector3d &  shift)
overridevirtual
Sets shift applied to original coordinates (information storage only)
Such a shift can typically be applied at loading time. Original coordinates are equal to '(P/scale - shift)'
◆ setWidth()
void ccPolyline::setWidth ( PointCoordinateType  width)
widththe desired width
◆ smoothChaikin()
ccPolyline * ccPolyline::smoothChaikin ( PointCoordinateType  ratio,
) const
ratiobetween 0 and 0.5 (excluded)
iterationCountof iteration
Returns
smoothed polyline
◆ split()
bool ccPolyline::split ( PointCoordinateType  maxEdgeLength,
std::vector< ccPolyline * > &  parts
Warning
output polylines set (parts) may be empty if all the vertices are too far from each other!
[in]maxEdgeLengthmaximum edge length
[out]partsoutput polyline parts
Returns
success
◆ toFile_MeOnly()
bool ccPolyline::toFile_MeOnly ( QFile &  out) const
