ccSensor Class Reference
Generic sensor interface. More...
#include <ccSensor.h>
Inheritance diagram for ccSensor:
Inheritance graph
Collaboration diagram for ccSensor:
Public Member Functions
 ccSensor (QString name)
 Default constructor.
 Returns class ID. More...
virtual CC_SENSOR_TYPE getType () const
 Returns the sensor type. More...
virtual uchar checkVisibility (const CCVector3 &P) const
 Returns the "visibility type" of a point. More...
ccIndexedTransformationBuffergetPositions ()
 Returns associated positions.
void setPositions (ccIndexedTransformationBuffer *positions)
 Sets associated positions.
bool addPosition (ccGLMatrix &trans, double index)
 Adds a new position (shortcut) More...
bool getAbsoluteTransformation (ccIndexedTransformation &trans, double index) const
 Returns the absolute transformation between the world and the "optical" center (shortcut) More...
bool getActiveAbsoluteTransformation (ccIndexedTransformation &trans) const
 Gets currently active absolute transformation.
bool getActiveAbsoluteCenter (CCVector3 &vec) const
 Gets currently active absolute position.
bool getActiveAbsoluteRotation (ccGLMatrix &rotation) const
 Gets currently active rotation matrix (without translation)
virtual void setRigidTransformation (const ccGLMatrix &mat)
 Sets the rigid transformation between this sensor and its associated positions. More...
virtual ccGLMatrixgetRigidTransformation ()
 Returns the rigid transformation between this sensor and its associated positions.
virtual const ccGLMatrixgetRigidTransformation () const
 Returns the rigid transformation between this sensor and its associated positions (const version)
void getIndexBounds (double &minIndex, double &maxIndex) const
 Gets index boundaries (shortcut)
double getActiveIndex () const
 Sets currently active index (displayed position, etc.)
void setActiveIndex (double index)
void setGraphicScale (PointCoordinateType scale)
 Sets the sensor graphic representation scale.
PointCoordinateType getGraphicScale () const
 Returns the sensor graphic representation scale.
 Default constructor. More...
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
virtual ccBBox getMyOwnBB ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
Protected Member Functions
 Save own object data. More...
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
Protected Attributes
ccIndexedTransformationBufferm_posBuffer
 Positions buffer (optional)
ccGLMatrix m_rigidTransformation
 Rigid transformation between this sensor and its associated positions. More...
double m_activeIndex
 Active index (for displayed position, etc.)
Vector3Tpl< colorType > m_color
 Color of the sensor. More...
PointCoordinateType m_scale
 Sensor graphic representation scale.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
New sensor framework now relies on separate positions (stored in a buffer) as generated by a GPS/IMU. This way, sensor objects only contains intrinsic parameters. They are also associated to a 'rigid transformation' (e.g. a rigid mechanical link between the sensor 'optical' center and the GPS/IMU center position).
Member Function Documentation
bool ccSensor::addPosition ( ccGLMatrix trans,
double  index
Warning
: may be slow as this method may sort the positions after each call (if the new index is lower than the last one pushed)
void ccSensor::applyGLTransformation ( const ccGLMatrix trans)
protectedvirtual
Applies a GL transformation to the entity.
this = rotMat*(this-rotCenter)+(rotCenter+trans)
transa ccGLMatrix structure
Reimplemented from ccHObject.
virtual uchar ccSensor::checkVisibility ( const CCVector3 &  P) const
inlinevirtual
Precise definition of point's visibility can be found in Daniel Girardeau-Montaut's PhD manuscript (Chapter 2, section 2-3-3). In fact it can be anything, assuming that a point that is not POINT_VISIBLE won't be compared during a point-to-cloud distance computation process.
Deprecated:
This method is deprecated and should be ignored.
Pa 3D point
Returns
the visibility of the point
Reimplemented in ccGBLSensor.
bool ccSensor::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
protectedvirtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented in ccCameraSensor, and ccGBLSensor.
bool ccSensor::getAbsoluteTransformation ( ccIndexedTransformation trans,
double  index
) const
Absolute transformation corresponds to the rigid transformation multiplied by the associated transformation interpolated at the given index.
virtual CC_CLASS_ENUM ccSensor::getClassID ( ) const
inlinevirtual
Returns class ID.
Returns
class unique ID
virtual CC_SENSOR_TYPE ccSensor::getType ( ) const
inlinevirtual
Should be re-implemented by sub-classes
Returns
the sensor type
virtual void ccSensor::setRigidTransformation ( const ccGLMatrix mat)
inlinevirtual
Rigid transformation goes from the sensor position(s) to the sensor "optical" center.
bool ccSensor::toFile_MeOnly ( QFile &  out) const
protectedvirtual
Member Data Documentation
Vector3Tpl<colorType> ccSensor::m_color
protected
Default color is green.
ccGLMatrix ccSensor::m_rigidTransformation
protected
The transformation goes from the sensor position(s) to the sensor "optical" center.
