Static Public Member Functions | Static Protected Member Functions | List of all members
ccSerializationHelper Class Reference
Serialization helpers. More...
#include <ccSerializableObject.h>
static void CoordsFromDataStream (QDataStream &stream, int flags, PointCoordinateType *out, unsigned count=1)
 Reads one or several 'PointCoordinateType' values from a QDataStream either in float or double format depending on the 'flag' value.
static void ScalarsFromDataStream (QDataStream &stream, int flags, ScalarType *out, unsigned count=1)
 Reads one or several 'ScalarType' values from a QDataStream either in float or double format depending on the 'flag' value.
template<int N, class ElementType >
static bool GenericArrayToFile (const GenericChunkedArray< N, ElementType > &chunkArray, QFile &out)
 Helper: saves a GenericChunkedArray structure to file. More...
static bool GenericArrayFromFile (GenericChunkedArray< N, ElementType > &chunkArray, QFile &in, short dataVersion)
 Helper: loads a GenericChunkedArray structure from file. More...
template<int N, class ElementType , class FileElementType >
static bool GenericArrayFromTypedFile (GenericChunkedArray< N, ElementType > &chunkArray, QFile &in, short dataVersion)
 Helper: loads a GenericChunkedArray structure from a file stored with a different type. More...
static bool ReadArrayHeader (QFile &in, short dataVersion,::uint8_t &componentCount,::uint32_t &elementCount)
Member Function Documentation
static bool ccSerializationHelper::GenericArrayFromFile ( GenericChunkedArray< N, ElementType > &  chunkArray,
QFile &  in,
short  dataVersion
inlinestatic
chunkArrayGenericChunkedArray structure to load
ininput file (must be already opened)
dataVersionversion current data version
Returns
success
static bool ccSerializationHelper::GenericArrayFromTypedFile ( GenericChunkedArray< N, ElementType > &  chunkArray,
QFile &  in,
short  dataVersion
inlinestatic
Returns
success
static bool ccSerializationHelper::GenericArrayToFile ( const GenericChunkedArray< N, ElementType > &  chunkArray,
QFile &  out
inlinestatic
chunkArrayGenericChunkedArray structure to save (must be allocated)
outoutput file (must be already opened)
Returns
success
