Public Types | Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
ccSubMesh Class Reference
A sub-mesh. More...
#include <ccSubMesh.h>
Inheritance diagram for ccSubMesh:
Inheritance graph
Collaboration diagram for ccSubMesh:
Public Types
typedef GenericChunkedArray
< 1, unsigned >
IndexMap
 Indexes map for createNewSubMeshFromSelection.
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 ccSubMesh (ccMesh *parentMesh)
 Default constructor.
 Returns class ID.
virtual ccBBox getMyOwnBB ()
virtual ccGenericPointCloudgetAssociatedCloud () const
 Returns the vertices cloud.
virtual void refreshBB ()
 Forces bounding-box update.
virtual bool interpolateNormals (unsigned triIndex, const CCVector3 &P, CCVector3 &N)
virtual bool interpolateColors (unsigned triIndex, const CCVector3 &P, colorType rgb[])
virtual bool getColorFromMaterial (unsigned triIndex, const CCVector3 &P, colorType rgb[], bool interpolateColorIfNoTexture)
virtual bool getVertexColorFromMaterial (unsigned triIndex, unsigned char vertIndex, colorType rgb[], bool returnColorIfNoTexture)
virtual bool hasMaterials () const
virtual const ccMaterialSetgetMaterialSet () const
virtual int getTriangleMtlIndex (unsigned triangleIndex) const
virtual bool hasTextures () const
virtual TextureCoordsContainergetTexCoordinatesTable () const
virtual void getTriangleTexCoordinates (unsigned triIndex, float *&tx1, float *&tx2, float *&tx3) const
virtual bool hasPerTriangleTexCoordIndexes () const
virtual void getTriangleTexCoordinatesIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const
virtual bool hasTriNormals () const
virtual void getTriangleNormalIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const
virtual bool getTriangleNormals (unsigned triangleIndex, CCVector3 &Na, CCVector3 &Nb, CCVector3 &Nc) const
virtual NormsIndexesTableTypegetTriNormsTable () const
virtual unsigned maxSize () const
 Returns max capacity.
virtual unsigned size () const
virtual void forEach (genericTriangleAction &anAction)
virtual void placeIteratorAtBegining ()
virtual CCLib::GenericTriangle * _getNextTriangle ()
virtual CCLib::GenericTriangle * _getTriangle (unsigned index)
virtual
CCLib::TriangleSummitsIndexes *
getNextTriangleIndexes ()
virtual
getTriangleIndexes (unsigned triangleIndex)
virtual void getTriangleSummits (unsigned triangleIndex, CCVector3 &A, CCVector3 &B, CCVector3 &C)
virtual void getBoundingBox (PointCoordinateType bbMin[], PointCoordinateType bbMax[])
virtual unsigned getTriGlobalIndex (unsigned localIndex) const
 Returns global index (i.e. relative to the associated mesh) of a given element. More...
virtual unsigned getCurrentTriGlobalIndex () const
 Returns the global index of the triangle pointed by the current element.
virtual void forwardIterator ()
 Forwards the local element iterator.
virtual void clear (bool releaseMemory)
 Clears the mesh.
virtual bool addTriangleIndex (unsigned globalIndex)
 Triangle global index insertion mechanism. More...
virtual bool addTriangleIndex (unsigned firstIndex, unsigned lastIndex)
 Triangle global index insertion mechanism (range) More...
virtual void setTriangleIndex (unsigned localIndex, unsigned globalIndex)
 Sets global index for a given element. More...
virtual bool reserve (unsigned n)
 Reserves some memory for hosting the triangle references. More...
virtual bool resize (unsigned n)
 Presets the size of the vector used to store triangle references. More...
virtual ccMeshgetAssociatedMesh ()
 Returns the associated mesh.
virtual const ccMeshgetAssociatedMesh () const
 Returns the associated mesh (const version)
virtual void setAssociatedMesh (ccMesh *mesh)
 Sets the associated mesh.
virtual ccSubMeshcreateNewSubMeshFromSelection (bool removeSelectedFaces, IndexMap *indexMap=0)
 Creates a new sub mesh with the selected vertices only. More...
 Default constructor. More...
virtual ~ccGenericMesh ()
 Destructor.
 Sets normals visibility.
 Enables polygon stippling.
 Samples points on a mesh.
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
Protected Types
< 1, unsigned >
ReferencesContainer
 Container of 3D triangles indexes.
 Save own object data. More...
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
ccMeshm_associatedMesh
 Associated mesh.
ReferencesContainerm_triIndexes
 Indexes of (some of) the associated mesh triangles.
unsigned m_globalIterator
 Iterator on the triangles references container.
ccBBox m_bBox
 Bounding-box.
bool m_triNormsShown
bool m_materialsShown
bool m_showWired
 Wireframe display mode.
bool m_stippling
 Polygon stippling state.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
A sub-mesh.
Equivalent to a CCLib::ReferenceCloud for a mesh
Member Function Documentation
bool ccSubMesh::addTriangleIndex ( unsigned  globalIndex)
virtual
globalIndexa triangle global index
Returns
false if not enough memory
bool ccSubMesh::addTriangleIndex ( unsigned  firstIndex,
unsigned  lastIndex
virtual
firstIndexfirst triangle global index of range
lastIndexlast triangle global index of range (excluded)
Returns
ccSubMesh * ccSubMesh::createNewSubMeshFromSelection ( bool  removeSelectedFaces,
IndexMap indexMap = 0
virtual
This method is called after a graphical segmentation or by ccMesh::createNewMeshFromSelection. It creates a new sub-mesh structure with the vertices that are tagged as "visible" (see ccGenericPointCloud::visibilityArray). This method will also update this sub-mesh if removeSelectedFaces is true. In this case, all "selected" triangles will be removed from this sub-mesh's instance.
removeSelectedFacesspecifies if the faces composed only of 'selected' vertices should be removed or not
indexMapif an index map is provided, it will be used to 'translate' global indexes
bool ccSubMesh::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
protectedvirtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccGenericMesh.
bool ccSubMesh::getColorFromMaterial ( unsigned  triIndex,
const CCVector3 &  P,
colorType  rgb[],
virtual
Returns RGB color fom a given triangle material/texture.
triIndextriangle index
Ppoint where to grab color (should be inside the triangle!)
[out]rgbtexel color
interpolateColorIfNoTexturewhether to return the color interpolated from the RGB field if no texture/material is associated to the given triangles
Returns
success
Implements ccGenericMesh.
ccBBox ccSubMesh::getMyOwnBB ( )
virtual
Children bboxes are ignored.
Returns
bounding-box
Reimplemented from ccHObject.
void ccSubMesh::getTriangleNormalIndexes ( unsigned  triangleIndex,
int &  i1,
int &  i2,
int &  i3
) const
virtual
Returns a triplet of normal indexes for a given triangle (if any)
[in]triangleIndextriangle index
[out]i1first summit normal index (or -1 if none)
[out]i2second summit normal index (or -1 if none)
[out]i3third summit normal index (or -1 if none)
bool ccSubMesh::getTriangleNormals ( unsigned  triangleIndex,
CCVector3 &  Na,
CCVector3 &  Nb,
CCVector3 &  Nc
) const
virtual
Returns a given triangle normal.
Mesh must have triangle normals associated (see hasTriNormals)
void ccSubMesh::getTriangleTexCoordinatesIndexes ( unsigned  triangleIndex,
int &  i1,
int &  i2,
int &  i3
) const
virtual
Returns the triplet of tex coords indexes for a given triangle.
i1first summit tex coords index
i2second summit tex coords index
i3third summit tex coords index
virtual unsigned ccSubMesh::getTriGlobalIndex ( unsigned  localIndex) const
inlinevirtual
localIndexlocal index (i.e. relative to the internal index container)
bool ccSubMesh::getVertexColorFromMaterial ( unsigned  triIndex,
colorType  rgb[],
virtual
Returns RGB color of a vertex fom a given triangle material/texture.
vertIndexvertex index inside triangle (i.e. 0, 1 or 2!)
[out]rgbtexel color
returnColorIfNoTexturewhether to return the color from the vertex RGB field if no texture/material is associated to the given triangle
Returns
success
virtual bool ccSubMesh::hasScalarFields ( ) const
virtual
Returns whether one or more scalar fields are instantiated.
WARNING: doesn't mean a scalar field is currently displayed (see ccDrawableObject::hasDisplayedScalarField).
Reimplemented from ccDrawableObject.
bool ccSubMesh::interpolateColors ( unsigned  triIndex,
colorType  rgb[]
virtual
Interpolates RGB colors inside a given triangle.
Ppoint where to interpolate (should be inside the triangle!)
[out]rgbinterpolated color
Returns
success
bool ccSubMesh::interpolateNormals ( unsigned  triIndex,
CCVector3 &  N
virtual
Interpolates normal(s) inside a given triangle.
[out]Ninterpolated normal
Returns
success
void ccSubMesh::onUpdateOf ( ccHObject obj)
protectedvirtual
This method is called when another object (geometry) is updated.
For internal use.
bool ccSubMesh::reserve ( unsigned  n)
virtual
nthe number of triangles (references)
bool ccSubMesh::resize ( unsigned  n)
virtual
void ccSubMesh::setTriangleIndex ( unsigned  localIndex,
virtual
globalIndexglobal index
bool ccSubMesh::toFile_MeOnly ( QFile &  out) const
protectedvirtual
