Public Member Functions | Public Attributes | List of all members
ccGBLSensor::DepthBuffer Struct Reference
Sensor "depth map". More...
#include <ccGBLSensor.h>
 DepthBuffer ()
 Default constructor.
 ~DepthBuffer ()
 Destructor.
int fillHoles ()
 Applies a mean filter to fill the small holes (lack of information) of the depth map. More...
Public Attributes
ScalarType * zBuff
 Z-Buffer grid.
unsigned width
 Buffer width.
unsigned height
 Buffer height.
Sensor "depth map".
Contains an array of depth values (along each scanned direction) and its dimensions. This array corresponds roughly to what have been "seen" by the sensor during acquisition (the 3D points are simply projected in the sensor frame).
Member Function Documentation
int ccGBLSensor::DepthBuffer::fillHoles ( )
The depth buffer must have been created before (see GroundBasedLidarSensor::project).
Returns
a negative value if an error occurs, 0 otherwise
The documentation for this struct was generated from the following files:
