qCC_io version 2.13.alpha (Qt) - 31 May 2022
CloudCompare standard I/O filters (file readers & writers)
AsciiFilter Member List
This is the complete list of members for AsciiFilter, including all inherited members.
AsciiFilter() (defined in AsciiFilter)AsciiFilter
BuiltIn enum value (defined in FileIOFilter)FileIOFilter
canSave(CC_CLASS_ENUM type, bool &multiple, bool &exclusive) const overrideAsciiFiltervirtual
CheckForSpecialChars(const QString &filename)FileIOFilterstatic
DEFAULT_PRIORITY (defined in FileIOFilter)FileIOFilterprotectedstatic
DisplayErrorMessage(CC_FILE_ERROR err, const QString &action, const QString &filename)FileIOFilterstatic
DynamicInfo enum value (defined in FileIOFilter)FileIOFilter
Export enum value (defined in FileIOFilter)FileIOFilter
exportSupported() constFileIOFilter
FileIOFilter(const FilterInfo &info) (defined in FileIOFilter)FileIOFilterexplicitprotected
FilterContainer typedefFileIOFilter
FilterFeature enum name (defined in FileIOFilter)FileIOFilter
FindBestFilterForExtension(const QString &ext)FileIOFilterstatic
getDefaultExtension() constFileIOFilter
GetFileFilter() (defined in AsciiFilter)AsciiFilterinlinestatic
getFileFilters(bool onImport) constFileIOFilter
GetFilter(const QString &fileFilter, bool onImport)FileIOFilterstatic
GetFilters()FileIOFilterstatic
HandleGlobalShift(const CCVector3d &P, CCVector3d &Pshift, bool &preserveCoordinateShift, LoadParameters &loadParameters, bool useInputCoordinatesShiftIfPossible=false)FileIOFilterstatic
Import enum value (defined in FileIOFilter)FileIOFilter
ImportFilterList()FileIOFilterstatic
importSupported() constFileIOFilter
IncreaseSesionCounter()FileIOFilterstatic
InitInternalFilters()FileIOFilterstatic
loadAsciiData(const QByteArray &data, QString sourceName, ccHObject &container, LoadParameters &parameters)AsciiFilter
loadCloudFromFormatedAsciiStream(QTextStream &stream, QString filenameOrTitle, ccHObject &container, const AsciiOpenDlg::Sequence &openSequence, char separator, bool commaAsDecimal, unsigned approximateNumberOfLines, qint64 fileSize, unsigned maxCloudSize, unsigned skipLines, LoadParameters &parameters, bool showLabelsIn2D=false)AsciiFilterprotected
loadFile(const QString &filename, ccHObject &container, LoadParameters &parameters) overrideAsciiFiltervirtual
LoadFromFile(const QString &filename, LoadParameters &parameters, Shared filter, CC_FILE_ERROR &result)FileIOFilterstatic
LoadFromFile(const QString &filename, LoadParameters &parameters, CC_FILE_ERROR &result, const QString &fileFilter=QString())FileIOFilterstatic
loadStream(QTextStream &stream, QString filenameOrTitle, qint64 dataSize, ccHObject &container, LoadParameters &parameters)AsciiFilterprotected
NoFeatures enum value (defined in FileIOFilter)FileIOFilter
Register(Shared filter)FileIOFilterstatic
ResetSesionCounter()FileIOFilterstatic
SaveColumnsNamesHeader(bool state)AsciiFilterstatic
SavePointCountHeader(bool state)AsciiFilterstatic
SaveSFBeforeColor(bool state)AsciiFilterstatic
SaveToFile(ccHObject *entities, const QString &filename, const SaveParameters &parameters, Shared filter)FileIOFilterstatic
SaveToFile(ccHObject *entities, const QString &filename, const SaveParameters &parameters, const QString &fileFilter)FileIOFilterstatic
saveToFile(ccHObject *entity, const QString &filename, const SaveParameters &parameters) overrideAsciiFiltervirtual
SetDefaultSkippedLineCount(int count)AsciiFilterstatic
setExportFileFilterStrings(const QStringList &filterStrings)FileIOFilterprotected
setImportExtensions(const QStringList &extensions)FileIOFilterprotected
setImportFileFilterStrings(const QStringList &filterStrings)FileIOFilterprotected
SetOutputCoordsPrecision(int prec)AsciiFilterstatic
SetOutputSeparatorIndex(int separatorIndex)AsciiFilterstatic
SetOutputSFPrecision(int prec)AsciiFilterstatic
Shared typedefFileIOFilter
unregister()FileIOFilterinlinevirtual
UnregisterAll()FileIOFilterstatic
~FileIOFilter()=default (defined in FileIOFilter)FileIOFiltervirtual
