Classes | Public Types | Public Slots | Public Member Functions | Static Public Member Functions | Protected Slots | Protected Attributes | List of all members
AsciiOpenDlg Class Reference
Dialog for configuration of ASCII files opening sequence. More...
#include <AsciiOpenDlg.h>
Inheritance diagram for AsciiOpenDlg:
Inheritance graph
Collaboration diagram for AsciiOpenDlg:
Classes
struct  SequenceItem
 ASCII open sequence item. More...
Public Types
typedef std::vector< SequenceItemSequence
 ASCII open sequence.
Public Slots
void updateTable (const QString &separator)
 AsciiOpenDlg (QString filename, QWidget *parent=0)
 Default constructor.
virtual ~AsciiOpenDlg ()
 Default destructor.
Sequence getOpenSequence ()
 Returns the whole "opening" sequence as set by the user.
unsigned getSkippedLinesCount () const
 Returns number of lines to skip.
uchar getSeparator () const
 Returns user selected separator.
double getAverageLineSize () const
 Returns roughly estimated average line size (in bytes)
unsigned getColumnsCount () const
 Returns columns count per line.
unsigned getMaxCloudSize () const
 Returns the max number of points per cloud.
static bool CheckOpenSequence (const Sequence &sequence, QString &errorMessage)
 Checks the "opening" sequence as set by the user. More...
Protected Slots
void testBeforeAccept ()
void setSkippedLines (int linesCount)
void columnsTypeHasChanged (int index)
void shortcutButtonPressed ()
void checkSelectedColumnsValidity ()
Ui_AsciiOpenDialog * m_ui
unsigned m_skippedLines
QChar m_separator
double m_averageLineSize
QString m_filename
QString m_headerLine
std::vector< bool > m_columnsValidty
 Identifies columns with numbers only [mandatory].
unsigned m_columnsCount
Member Function Documentation
bool AsciiOpenDlg::CheckOpenSequence ( const Sequence sequence,
QString &  errorMessage
static
Returns
validity (+ error message if not)
