BundlerFilter Class Reference
Noah Snavely's Bundler output file filter. More...
#include <BundlerFilter.h>
Inheritance diagram for BundlerFilter:
Inheritance graph
Collaboration diagram for BundlerFilter:
CC_FILE_ERROR loadFileExtended (const char *filename, ccHObject &container, bool displayLoadDialog, const QString &altKeypointsFilename=QString(), bool undistortImages=false, bool generateColoredDTM=false, unsigned coloredDTMVerticesCount=1000000, float scaleFactor=1.0f)
 Specific load method.
Additional Inherited Members
See http://phototour.cs.washington.edu/
Member Function Documentation
CC_FILE_ERROR BundlerFilter::loadFile ( const char *  filename,
ccHObject &  container,
virtual
filenamefile to load
Returns
error
Implements FileIOFilter.
virtual CC_FILE_ERROR BundlerFilter::saveToFile ( ccHObject *  entity,
inlinevirtual
filenamefilename
Returns
error
