qCC_io version 2.13.alpha (Qt) - 31 May 2022
CloudCompare standard I/O filters (file readers & writers)
This is the complete list of members for FileIOFilter, including all inherited members.
BuiltIn enum value (defined in FileIOFilter) | FileIOFilter | |
canSave(CC_CLASS_ENUM type, bool &multiple, bool &exclusive) const | FileIOFilter | inlinevirtual |
CheckForSpecialChars(const QString &filename) | FileIOFilter | static |
DEFAULT_PRIORITY (defined in FileIOFilter) | FileIOFilter | protectedstatic |
DisplayErrorMessage(CC_FILE_ERROR err, const QString &action, const QString &filename) | FileIOFilter | static |
DynamicInfo enum value (defined in FileIOFilter) | FileIOFilter | |
Export enum value (defined in FileIOFilter) | FileIOFilter | |
exportSupported() const | FileIOFilter | |
FileIOFilter(const FilterInfo &info) (defined in FileIOFilter) | FileIOFilter | explicitprotected |
FilterContainer typedef | FileIOFilter | |
FilterFeature enum name (defined in FileIOFilter) | FileIOFilter | |
FindBestFilterForExtension(const QString &ext) | FileIOFilter | static |
getDefaultExtension() const | FileIOFilter | |
getFileFilters(bool onImport) const | FileIOFilter | |
GetFilter(const QString &fileFilter, bool onImport) | FileIOFilter | static |
GetFilters() | FileIOFilter | static |
HandleGlobalShift(const CCVector3d &P, CCVector3d &Pshift, bool &preserveCoordinateShift, LoadParameters &loadParameters, bool useInputCoordinatesShiftIfPossible=false) | FileIOFilter | static |
Import enum value (defined in FileIOFilter) | FileIOFilter | |
ImportFilterList() | FileIOFilter | static |
importSupported() const | FileIOFilter | |
IncreaseSesionCounter() | FileIOFilter | static |
InitInternalFilters() | FileIOFilter | static |
loadFile(const QString &filename, ccHObject &container, LoadParameters ¶meters) | FileIOFilter | inlinevirtual |
LoadFromFile(const QString &filename, LoadParameters ¶meters, Shared filter, CC_FILE_ERROR &result) | FileIOFilter | static |
LoadFromFile(const QString &filename, LoadParameters ¶meters, CC_FILE_ERROR &result, const QString &fileFilter=QString()) | FileIOFilter | static |
NoFeatures enum value (defined in FileIOFilter) | FileIOFilter | |
Register(Shared filter) | FileIOFilter | static |
ResetSesionCounter() | FileIOFilter | static |
SaveToFile(ccHObject *entities, const QString &filename, const SaveParameters ¶meters, Shared filter) | FileIOFilter | static |
SaveToFile(ccHObject *entities, const QString &filename, const SaveParameters ¶meters, const QString &fileFilter) | FileIOFilter | static |
saveToFile(ccHObject *entity, const QString &filename, const SaveParameters ¶meters) | FileIOFilter | inlinevirtual |
setExportFileFilterStrings(const QStringList &filterStrings) | FileIOFilter | protected |
setImportExtensions(const QStringList &extensions) | FileIOFilter | protected |
setImportFileFilterStrings(const QStringList &filterStrings) | FileIOFilter | protected |
Shared typedef | FileIOFilter | |
unregister() | FileIOFilter | inlinevirtual |
UnregisterAll() | FileIOFilter | static |
~FileIOFilter()=default (defined in FileIOFilter) | FileIOFilter | virtual |
