Public Member Functions | Protected Member Functions | List of all members
IcmFilter Class Reference
Calibrated images and cloud meta-file I/O filter. More...
#include <IcmFilter.h>
Inheritance diagram for IcmFilter:
Inheritance graph
Collaboration diagram for IcmFilter:
int loadCalibratedImages (ccHObject *entities, const QString &path, const QString &imageDescFilename)
Additional Inherited Members
Member Function Documentation
CC_FILE_ERROR IcmFilter::loadFile ( const char *  filename,
ccHObject &  container,
virtual
filenamefile to load
Returns
error
Implements FileIOFilter.
CC_FILE_ERROR IcmFilter::saveToFile ( ccHObject *  entity,
virtual
filenamefilename
Returns
error
