Classes | Public Member Functions | Protected Member Functions | Static Protected Member Functions | List of all members
PCDFilter Class Reference
PCD point cloud I/O filter. More...
#include <PCDFilter.h>
Inheritance diagram for PCDFilter:
Inheritance graph
Collaboration diagram for PCDFilter:
Classes
struct  PCDHeader
 (Binary) PCD file header More...
CC_FILE_ERROR loadFileBinaryMemMap (const char *filename, ccHObject &container, const PCDHeader &header)
CC_FILE_ERROR readFileHeader (const char *filename, PCDHeader &header)
static int ReadScalarFieldMemMap (const QString &fieldname, const InputMemoryFile &mem_file, const PCDHeader &header, ccScalarField &field, size_t count=0)
static int ReadRGBMemMap (const InputMemoryFile &mem_file, const PCDHeader &header, ccPointCloud &cloud)
static int ReadNormalsMemMap (const InputMemoryFile &mem_file, const PCDHeader &header, ccPointCloud &cloud)
static int GetIDOfField (const QString &fieldName, const PCDFilter::PCDHeader &header)
static size_t GetSizeOfField (int fieldID, const PCDFilter::PCDHeader &header)
static size_t GetOffsetOfField (int fieldID, const PCDFilter::PCDHeader &header)
Additional Inherited Members
Member Function Documentation
CC_FILE_ERROR PCDFilter::loadFile ( const char *  filename,
ccHObject &  container,
virtual
filenamefile to load
Returns
error
Implements FileIOFilter.
CC_FILE_ERROR PCDFilter::saveToFile ( ccHObject *  entity,
virtual
filenamefilename
Returns
error
