Public Member Functions | Protected Member Functions | List of all members
STLFilter Class Reference
StereoLithography file I/O filter. More...
#include <STLFilter.h>
Inheritance diagram for STLFilter:
Inheritance graph
Collaboration diagram for STLFilter:
CC_FILE_ERROR saveToASCIIFile (ccGenericMesh *mesh, FILE *theFile)
 Custom save method.
CC_FILE_ERROR saveToBINFile (ccGenericMesh *mesh, FILE *theFile)
CC_FILE_ERROR loadASCIIFile (QFile &fp, ccMesh *mesh, ccPointCloud *vertices, bool alwaysDisplayLoadDialog, bool *coordinatesShiftEnabled=0, CCVector3d *coordinatesShift=0)
 Custom load method for ASCII files.
CC_FILE_ERROR loadBinaryFile (QFile &fp, ccMesh *mesh, ccPointCloud *vertices, bool alwaysDisplayLoadDialog, bool *coordinatesShiftEnabled=0, CCVector3d *coordinatesShift=0)
 Custom load method for binary files.
Additional Inherited Members
See http://www.ennex.com/~fabbers/StL.asp
Member Function Documentation
CC_FILE_ERROR STLFilter::loadFile ( const char *  filename,
ccHObject &  container,
virtual
filenamefile to load
Returns
error
Implements FileIOFilter.
CC_FILE_ERROR STLFilter::saveToFile ( ccHObject *  entity,
virtual
filenamefilename
Returns
error
