Page 1 of 2
loading plugins with CC 2.9 beta on ubuntu
Posted: Mon Jul 17, 2017 1:54 pm
by sguinard
I just downloaded the latest beta version (2.9) and compiled it on Ubuntu from the sources,
But when launching CC, it appears that the plugins were not found
A little workaround just proved that the path CC used to find plugins was wrong:
/usr/lib/cloudcompare/plugins instead of /usr/local/lib/cloudcompare/plugins
I don't know if I'm the only one facing this,
But it seems a bit weird as it worked without problem for me on 2.6.1 version
Also keep up the good work on CC :)
Stephane
Re: loading plugins with CC 2.9 beta on ubuntu
Posted: Tue Jul 18, 2017 7:14 am
Can you provide us with your CMake configuration? (one or several screenshots would be good)
Posted: Tue Jul 18, 2017 8:14 am
by sguinard
Thanks for the quick answer
The options are in the cmake-1 & cmake-2 images and the configuration is in cmake-3
Posted: Tue Jul 18, 2017 8:15 am
by sguinard
And the installation is in cmake-4
Posted: Tue Jul 18, 2017 8:50 am
by Romain.Janvier
I'm afraid to not understand the issue here.
the runtime path point to '/usr/local/lib/cloudcompare/plugins' as proved by your last printscreen
Posted: Tue Jul 18, 2017 8:57 am
by sguinard
yes, but CC was searching for the plugins in /usr/lib/cloudcompare/plugins , which is not the place they have been installed,
that's what i wanted to say at first
Posted: Tue Jul 18, 2017 9:01 am
by Romain.Janvier
We just check with Daniel, it should work fine as is.
could you give me the output of "which CloudCompare"?
thanks
Posted: Tue Jul 18, 2017 9:03 am
by sguinard
Here it is
Posted: Tue Jul 18, 2017 9:07 am
by Romain.Janvier
have you another version of CC installed on this computer?
else I must admit that I'm clueless here,
It should just work fine, you are the first to encounter the issue since we changed the whole path system
Posted: Tue Jul 18, 2017 9:41 am
by sguinard
my bad, I just saw that my old 2.6 was still there
may it be the cause ?
