CloudCompare core dump when rotate multiple imports
timcoddington
Post by timcoddington »
CloudCompare V2, 2.4 Qt/Linux/32 bits - 03/18/2013, per About...
When import (i.e. load in, Open, etc) several (e.g. 5) point clouds from ascii and then select them all in the tree view on the left then select Rotate/Translate CloudCompare core dumps immediately. This happened everytime I tried to do this operation.
I'm running Ubuntu 12.04 on a lenovo T520 laptop with max memory.
Re: CloudCompare core dump when rotate multiple imports
I'll try to reproduce it asap! Thanks for the feedback.
Ok I've fixed the bug (it happens when you try to apply the tool to an entity and its parent at the same time).
Meanwhile you 'simply' have to make sure that it doesn't happen ;)
