[Solved (debug mode)] built with qPCL, but MLS is 30x slower
All about Windows versions
dcaron05
Postby dcaron05 » Wed Sep 14, 2016 8:10 pm
I successfully built the trunk 2.8 version with the qPcl plugin (the only activated plugin) on windows 7 x64, vs2013.
I used the "PCL 1.7.2 All-in-one Installer MSVC2013 x64" from http://unanancyowen.com/?p=712 and all the dependencies inside (eigen, boost, flann, vtk)
Everything works fine, but when I try to use the MLS smoothing command, it takes 5 minutes for the same command that takes 10 seconds to execute using the official build.
I also tried PCL 1.8 All-in-one with the same result.
Any idea is appreciated.
Re: built with qPCL, but MLS is 30x slower
Postby daniel » Wed Sep 14, 2016 8:52 pm
Be sure to run CC in release mode (and not the default 'debug' mode which is great for debugging but awfully slow).
dcaron05
Postby dcaron05 » Thu Sep 15, 2016 11:06 am
Yep, that's it exactly. I'm still new to c++ compilation. Thanks a lot.
Return to “Windows related topics”
Who is online
Users browsing this forum: No registered users and 1 guest
