Postby daniel » Thu Jun 15, 2017 4:01 pm
Well, the plugin do compute this statistics in 'training mode' (when you create your classifier, when you see it's 2D equivalent, there's a button to show all these pieces of information. However that's easy here because the user has provided the right subsets to the trainer.
Once you have applied the classifier... not sure what you can do apart from what you did...
Dimitri
Postby Dimitri » Thu Jun 15, 2017 7:42 pm
Hi Lena,
to evaluate the quality of your classifier you need to apply it on a dataset that you have manually labelled (and not your training dataset). Once you have applied your classifier on all your data, you extract only class1 from the Canupo classification. From this dataset you extract the two classes that you have manually labelled and you'll be able to compute your precentage of success and error 1. You do the same for the class1 predicted by Canupo.
It's a tedious process. If your dataset is not too large you could export it after the qCanupo classif to matlab (or python) to easily extract the percentage of error much faster.
Hope this helps
Dimitri (Lague, from Brodu and Lague ;-))
Lena
Postby Lena » Tue Jun 20, 2017 7:54 am
Hi Daniel and Dimitri,
thank you very much for the fast answers! Fortunately, my dataset is quite small. So the way to export it to matlab will be the best one, I didn't think about something like this - so thanks :)
murraynairn
Postby murraynairn » Tue Aug 08, 2017 12:39 pm
Hi Daniel & Dimitri
I have been using the Canupo plugin for my MSc Project. One of the things I have been asked in review of one of my chapters is exactly what the X & Y axes show on the graph which displays when you train a classifier?
I have attached a picture below so you know exactly what graph I am talking about. There are no X and Y axes labels included. It would be good to have an understanding of exactly what the graph is showing.
Many Thanks,
Murray
1A - Boundary.PNG (21.33 KiB) Viewed 98 times
Postby daniel » Wed Aug 09, 2017 9:25 am
If I remember well, the two main axes are obtained by a kind of PCA analysis (https://en.wikipedia.org/wiki/Principal_component_analysis). The Canupo descriptors are corresponding to vectors with a lot of elements (2*N, where N = number of scales). The classification is therefore done in a 2N dimension space. This would be impossible to display it in 2D, so the plugin projects the vectors along the two main components (obtained by PCA) .
It may be a bit simplified, but that's the spirit ;)
murraynairn
Postby murraynairn » Thu Aug 10, 2017 4:20 pm
Many thanks Daniel.
So am I right reading the graph I posted that there is greater variation in the Principal Component 1 (along the X-Axis) than along Principal Component 2 (along the Y-Axis), hence a more vertical plane of separation, or the other way around?
Furthermore, Once classified, how is the Class Confidence calculated? And I take it the value essentially means the classifier is (e.g.) 95% (0.95) confident that this point is classified correctly?
Thanks for your help.
Murray
Postby daniel » Thu Aug 10, 2017 7:23 pm
The difference between the two first principal components may be very small (as they are the two most important ones), but I guess it's right to say that the first one is bigger than the second one.
Mind that they are internally computed and you don't have access to the Eigen vectors, so it's a bit 'arbitrary' in a way. It's mostly a way to represent things in a user friendly way, and to let the user update the boundary manually (you can add and move the vertices boundaries in this 'plane').
And for the confidence, your interpretation of the meaning is right. For the exact way it is computed, I fear you'll have to dig into the Canupo article ;).
Return to “Plugins”
Who is online
Users browsing this forum: No registered users and 1 guest
