Extract meaniningful values from .prm file
everydayduffy
Post by everydayduffy »
The first stage of CANUPO classification in CC involves the creation of a .prm file. Is there anyway to extract information from this file, to obtain the range of R,G and B values that fall within each class?
Thank you
James
Re: Extract meaniningful values from .prm file
Well, the open-source version of canupo gives you the description of this prm file (http://nicolas.brodu.net/code/canupo).
However in the standard version the RGB information is not used.
