Set centre point
Richlear
Set centre point
Post by Richlear »
Hi all, new user here!
I have a point cloud which is a laser scan of some sensors on a mounting plate. I need to measure the offsets in X, Y and Z from a reference point which is the centre of one of the sensors to each of the other sensors.
So, I would like to be able to nominate a point or even better, a location I define as 0,0,0 then be able to measure other points as dX, dY, dZ from that.
Any suggestions on the easiest way to achieve this?
thanks very much
rich
Re: Set centre point
If you have a known point (let's assume its coordinates are X0, Y0 and Z0) then you can simply translate the other points so that this point goes to (0, 0, 0): select the cloud, then use 'Edit > Apply transformation' and input (-X0, -Y0, -Z0) as translation in the second tab of the tool.
Once you have translated the cloud, you can simply spawn labels on each point (with SHIFT+left click) or export the cloud as an ASCII file to read all the (shifted) coordinates at once.
Richlear
Post by Richlear »
Thanks Daniel.
is it possible to do a shift like this to a location where there is no physical point? (centre of a cylinder for instance)
rich
As long as you know the coordinates of this point, yes.
For a cylinder, I guess looking at the center of its boudning-box should be sufficient?
