M3C2 Plugin
LiDoom
Re: M3C2 Plugin
Post by LiDoom »
HeadLess wrote: Thu Apr 11, 2024 8:13 pm Well just an idea,
1. Export the two cloud Z coordinate to SF
2. Flatten the two cloud by setting Z coord to zero (create a new SF with static zero, then set coordinate from sf
3. Interpolate one of the cloud Z sf to the other one ( do not overwrite original.
4. Interpolate one of the cloud Z SF from the other one.
5. Convert SF to coord (the calculated distance)
6. Use rasterize tool to calculate 2.5d volume. If the clouds dense enough it will create a good enough calculation.
Thank you for this, but I am struggling with step 2-5.
I went ahead and just ran the 2.5d calculation. Is the volume result in meters cubed?
HeadLess
Re: M3C2 Plugin
Post by HeadLess »
It is in your cloud's unit cubed, so if your cloud is in meter then the volume is m^3
