Slope Calculations Question
Posted: Mon Aug 31, 2015 5:55 pm
by orinn
As always thank you for this incredible program.
I'm trying to calculate slope for a parking lot. Basically I'm interested in anything over a 2% slope. I used a height grid to get my lowest Z, calculated normal's, then convert normal's to dip/dip direction SF. When I look at dip (degrees) the numbers seem to be set at intervals. If I look at the values they go
Degree - Slope %
0.6379 = 1.11
0.6482 = 1.13
1.4491 = 2.53
1.4727 = 2.57
1.9755 = 3.45
I'm hoping to better define what falls under and over 2% slope.
I'm not sure why the calculations for degrees jump instead of a smooth transition. Is there a better way to go about this?
Re: Slope Calculations Question
Posted: Mon Aug 31, 2015 7:54 pm
There are two possible causes:
[*] if you are computing the normals on the 2.5D cloud output by the Rasterize tool, then maybe the sampling is the cause?
[*] otherwise it may be due to the normals compression scheme we use (in order to store the normals on 2 bytes instead of 12 ;). This compression scheme works very well for visualization purposes (as the eye can't make the difference) but it may be the cause of those intervals (however I would have expected to see more regularly sampled angles in this case).
Can you maybe share your cloud (or a part) with me?
Posted: Mon Aug 31, 2015 8:05 pm
by orinn
I considered that it might be the Rasterize tool, so I ran normal detection without using it, still have the same problem.
In the link below is the parking lot with normals detected via height. I have tested it with plane and triangulation and see similar results with the numbers.
Link to .bin
https://eco3d.egnyte.com/dl/xIsxyDrTXH
Edit: I also tried running the cloud through meshlab for normal detection, and then back through cloud compare. problem persisted.
Posted: Tue Sep 01, 2015 7:15 pm
Okay, the issue was indeed the limited number of orientations due to the coding of normals on 15 bytes (which only allows for 32K directions).
I've upgraded this to 21 bytes (= 2M directions) so as to get a much finer result:
You can test this with the latest beta version (I've just updated it).
(of course the result also depends on the way you compute normals - the bigger the radius is, the more uniform the normals will be)
Posted: Tue Sep 01, 2015 7:44 pm
by orinn
Wow, that really makes a big difference. It looks amazing, thank you very much sir.
