how to Install qAnimation on MacBook Pro?
arielcaine
Re: how to Install qAnimation on MacBook Pro?
Post by arielcaine »
Hi, downloaded and installed beta5.
this is the error I'm getting.
many thanks!!
arielcaine
[23:35:22] [Plugin] File 'libQANIMATION_PLUGIN.dylib' doesn't seem to be a valid plugin (Cannot load library /private/var/folders/8n/zrv89zc11nz9r2b6lyklqmvc0000gn/T/AppTranslocation/0ACCFF03-C6A5-48D1-8948-671C93E6518E/d/CloudCompare.app/Contents/PlugIns/ccPlugins/libQANIMATION_PLUGIN.dylib: (dlopen(/private/var/folders/8n/zrv89zc11nz9r2b6lyklqmvc0000gn/T/AppTranslocation/0ACCFF03-C6A5-48D1-8948-671C93E6518E/d/CloudCompare.app/Contents/PlugIns/ccPlugins/libQANIMATION_PLUGIN.dylib, 5): Library not loaded: /Users/maloney/dev/Cellar/ffmpeg/3.2.1/lib/libavutil.55.dylib
Referenced from: /private/var/folders/8n/zrv89zc11nz9r2b6lyklqmvc0000gn/T/AppTranslocation/0ACCFF03-C6A5-48D1-8948-671C93E6518E/d/CloudCompare.app/Contents/Frameworks/libswscale.4.dylib
Reason: image not found))
asmaloney
Post by asmaloney »
Gah! Missed one. At least I'm on the right track... Don't know how these issues didn't come up with 2.7.
How about beta6?
arielcaine
Works! it crashes immediately as I try to export an animation but i started test on a large cloud so will test later smaller one. I'll post the crash report.
thanks for the help and of course for all the work on the Mac version of CC!!!!!!
Can you try to change the video export format? (just change the extension: mp4 / mpg / etc.) and see if this avoids the crash.
asmaloney
Post by asmaloney »
Can you please open an issue on github for the crash? Please include what format you were trying to write and any other relevant information.
https://github.com/CloudCompare/CloudCompare/issues
It will make it easier to track and other people might have some input.
arielcaine
will do. thanks
