Bad visualization points BIG Coordinates
Posted: Thu Feb 02, 2017 2:33 pm
by geolux
Hi Guys
in the last recent versions I noticed a visualization problem with a lot of digits, like WGS UTM 84. In the past versions if I chose to applicate a Global shift/scale (coordinates are too big) the viewer of the points was correct. Now, the visualization is sliced like the attach photo. Is the same if I answer yes, yes to all or No
Thank you
Re: Bad visualization points BIG Coordinates
Posted: Thu Feb 02, 2017 2:40 pm
Is your original file already truncated maybe?
Posted: Thu Feb 02, 2017 3:06 pm
by geolux
Hi Daniel
It is directly exported from Photogrammetry software in WGS 84 UTM 33N.In Photoscan it is correctly viewed. How I can see if is a problem of exporting file?
Posted: Thu Feb 02, 2017 3:47 pm
by Aarie
Hey geolux,
AFAIK it's an issue with the export of PLY files generated in Agisoft. Try using the shift settings when exporting from agisoft, that should solve the issue.
Cheers!
Posted: Thu Feb 02, 2017 3:53 pm
by geolux
Ok Aarie, but I need the correct coordinates and not in local. I knowed that in Local coordinate there was not problem, but I did not think in a exporting problem
