Page 3 of 3
Re: MinGW Assertion Runtime:Assertion Failed
Posted: Mon Aug 14, 2017 9:03 am
by Hritika
Ok Thank You.
Can you give some suggestion if colorrampshader gets failed to load, what should be done.In console it is giving colorrampshader failed to load.
Thank you
Hritika Mehta
Posted: Wed Aug 16, 2017 9:03 pm
It means that your graphic card is pretty old... maybe if you update its driver it may help, otherwise you won't fix this error.
You can disable the feature in the Display settings (so that the error is not displayed again).
