Export Clouds with given filename
Posted: Thu Feb 22, 2018 10:07 am
by Ingsayyad
I am trying to save merge cloud as TEST.e57. How can I do it?
"C:\Program Files\CloudCompare\CloudCompare" -AUTO_SAVE OFF -o C:\CloudComparetest\r02.las -C_EXPORT_FMT E57 -SAVE_CLOUDS  % ---WHERE CAN I ADD NAME OF FILE---%
Re: Export Clouds with given filename
Posted: Fri Feb 23, 2018 11:26 am
For now there's no option to specify the output filename in the command line tool of CloudCompare. You can only choose whether the timestamp should be added or not (see the -NO_TIMESTAMP option).
