ICP zoom
CloudyCloud
ICP zoom
Post by CloudyCloud »
This is a small thing, but I find it annoying. Maybe I'm the only one ;)
Each time the alignment is finished, the app resets zoom to show the whole scene. And that makes comparing results before/after quite difficult while working wit large objects.
Would it be easy to add an option (similar to 3-points alignment dialog) to freeze the view?
Re: ICP zoom
With the ICP tool or the manual transformation?
And at least you can save the viewpoint (with CTRL+V or 'Display > Save viewport'). Then restore it by clicking on the 'Apply' button of the saved viewport entity.
CloudyCloud
Re: ICP zoom
I meant the ICP tool.
I didn't know the 'Save Viewport' feature, thanks a lot for bringing it up. It's going to make things a bit easier :) But being able to freeze the viewport would still make verifying alignment results way easier.
